# JavaScript Scripting
This add-on provides support for JavaScript (ECMAScript 2025+) that can be used as a scripting language within automation rules. It is based on GraalJS (opens new window) from the GraalVM project (opens new window).
This add-on includes a version of the openhab-js (opens new window) NPM library.
Depending on the add-on configuration, it automatically exports all namespaces (see Standard Library) onto the global namespace. This allows the use of items, actions, cache and other APIs from the UI without the need to explicitly import them using require(). This functionality can be disabled for users who prefer to manage their own imports via the add-on configuration options:
  • Only inject the openhab-js namespaces globally for UI-based rules and scripts (recommended and default).
  • Inject the openhab-js namespaces globally for all scripts, including file-based rules and transformations.
  • Disable injection of the openhab-js namespaces everywhere, which means you need to import the library using require() in every script that uses it.
If enabled, the injection of the openhab-js (opens new window) NPM library is cached (using a special mechanism instead of require()) to improve script loading performance. This can be disabled, which will allow you to use a different version of the library than the one included in the add-on.
# Rules in Main UI
Formerly known as UI-Based Rules.
The quickest way to use JavaScript Scripting is to create a rule in Main UI and add a Script Action, see Adding Actions below. If you only want to execute code and don't need triggers, you can instead create a script in Main UI.
Advanced users, or users migrating scripts from Rules DSL may want to use Rules created from Script Files for managing rules using files in the user configuration directory.
# Adding Triggers
Using Main UI, first create a new rule and set a trigger condition.
openHAB Rule Configuration
# Adding Actions
Select "Add Action" and then select "Inline Script" with "ECMAScript 262 Edition 11". This will add a so-called Script Action to the rule. It's important this is "Edition 11" or higher. Earlier versions will not work. This will bring up an empty script editor where you can enter your JavaScript.
openHAB Rule Engines
You can now write rules using standard ES6 JavaScript along with the included openHAB Standard Library.
openHAB Rule Script
items.KitchenLight.sendCommand('ON');
console.log('Kitchen Light State', items.KitchenLight.state);
Sending a notification
actions.NotificationAction.sendNotification('romeo@montague.org', 'Balcony door is open');
var thingStatusInfo = actions.Things.getThingStatusInfo('zwave:serial_zstick:512');
console.log('Thing status', thingStatusInfo.getStatus());
See Standard Library for a complete list of functionality.
# Adding Conditions
If you want the rule to only execute if one or many predefined conditions, e.g. some Item has a given state are met, select "Add Condition". Next, select "Script Condition" and, again, "ECMAScript 262 Edition 11".
You can now write conditions for your rule using standard ES6 JavaScript along with the included openHAB Standard Library.
When writing script conditions, the script has to provide a boolean value (true or false) whether the condition is met. This can be done in two ways:
  • Explicitly using return: If the script condition wrapper is enabled (see below), the return keyword has to be used to return a boolean value (true or false). Example:
    if (items.KitchenWindow.state === 'OPEN') {
      return items.OutsideTemperature.quantityState.lessThan('12 °C')
    return false
    When using Blockly, there is a return block available from the "Run & Process" category.
  • Implicitly: If the script condition wrapper is not enabled or not available (see below), the last executed statement needs to evaluate to a boolean value. Example:
    false
The preferred way is explicit, as it is way clearer what is returned, however return is only supported if the script condition wrapper is enabled. The script condition wrapper has been available since openHAB 5.1.0, previous versions only support implicit return. It is advised to enable the wrapper and use explicit returns for all new script conditions, and step-by-step migrate existing conditions.
The wrapper can be enabled (and disabled as well) per script condition using the use wrapper directive:
  • Adding 'use wrapper' or 'use wrapper=true' (semicolons can be added) as the first or second line enables the wrapper.
  • Adding 'use wrapper=false' instead disables the wrapper.
New users of openHAB, users that haven't used script conditions with JavaScript Scripting before, and users that have migrated (through the directive) all conditions to wrapper use can simply turn on the "Wrap Script Conditions in Self-Executing Function" option in the add-on settings.
# Event Object
When a rule is triggered, the script is provided the event instance that triggered it. The specific data depends on the event type. The event object provides some information about that trigger.
This table gives an overview over the event object:
Property Name Trigger Types Description Rules DSL Equivalent Raw Event Object Equivalent
oldState ItemStateChangeTrigger, GroupStateChangeTrigger Previous state of Item or Group that triggered event previousState oldItemState
newState ItemStateChangeTrigger, GroupStateChangeTrigger New state of Item or Group that triggered event N/A itemState
receivedState ItemStateUpdateTrigger, GroupStateUpdateTrigger State of Item that triggered event triggeringItem.state itemState
receivedCommand ItemCommandTrigger, GroupCommandTrigger Command that triggered event receivedCommand itemCommand
itemName Item****Trigger, Group****Trigger Name of Item that triggered event triggeringItem.name
groupName Group****Trigger Name of the group whose member triggered event N/A
receivedEvent ChannelEventTrigger Channel event that triggered event N/A event
channelUID ChannelEventTrigger UID of channel that triggered event N/A channel
oldStatus ThingStatusChangeTrigger Previous state of Thing that triggered event N/A
newStatus ThingStatusChangeTrigger New state of Thing that triggered event N/A
status ThingStatusUpdateTrigger State of Thing that triggered event N/A
thingUID Thing****Trigger UID of Thing that triggered event N/A
cronExpression GenericCronTrigger Cron expression of the trigger N/A
time TimeOfDayTrigger Time of day value of the trigger N/A
timeOnly DateTimeTrigger Whether the trigger only considers the time part of the DateTime Item N/A
offset DateTimeTrigger Offset in seconds added to the time of the DateTime Item N/A
eventType all except PWMTrigger, PIDTrigger Type of event that triggered event (change, command, triggered, update, time) N/A
triggerType all except PWMTrigger, PIDTrigger Type of trigger that triggered event N/A
eventName all simple Java class name of the triggering event, e.g. ExecutionEvent N/A type
eventClass all full Java class name of the triggering event, e.g. org.openhab.core.automation.events.ExecutionEvent N/A
module all (user-defined or auto-generated) name of trigger N/A
raw all Original contents of the event including data passed from a calling rule N/A
All properties are typeof string except for properties contained by raw which are unmodified from the original types.
Please note that when using GenericEventTrigger, the available properties depend on the chosen event types. It is not possible for the openhab-js library to provide type conversions for all properties of all openHAB events, as those are too many. In case the event object does not provide type-conversed properties for your chosen event type, use the payload property to gain access to the event's (Java data type) payload.
When disabling the option Convert Event from Java to JavaScript type in Script Actions & Script Conditions, you will receive a raw Java event object instead of the event object described above in Script Actions & Script Conditions. This is useful for advanced users, but not recommended for most users. See the expandable section below for more details.
Raw Script Module Event Object
This table gives an overview over the raw Java event object of Script Actions & Script Conditions (well-known rules in Main UI) for most common trigger types:
Property Name Type Trigger Types Description Rules DSL Equivalent
itemState sub-class of org.openhab.core.types.State (opens new window) [item] changed, [item] was updated State that triggered event triggeringItem.state
oldItemState sub-class of org.openhab.core.types.State (opens new window) [item] changed Previous state of Item or Group that triggered event previousState
itemCommand sub-class of org.openhab.core.types.Command (opens new window) [item] received a command Command that triggered event receivedCommand
itemName string all Name of Item that triggered event triggeringItem.name
type string all Type of event that triggered event ("ItemStateEvent", "ItemStateChangedEvent", "ItemCommandEvent", ...) N/A
event string channel based triggers Event data published by the triggering channel. receivedEvent
payload JSON formatted string all Any additional information provided by the trigger not already exposed. "{}" there is none. N/A
event, and therefore everything carried by event are Java types (not JavaScript). Care must be taken when comparing these with JavaScript types:
console.log(event.itemState == "ON")  // WRONG. Java type does not equal with string, not even with "relaxed" equals (==) comparison
console.log(event.itemState.toString() == "ON")  // OK. Comparing strings
console.log(event.itemState == ON)  // OK. Comparing Java types
# Scripting Basics
The openHAB JavaScript Scripting runtime attempts to provide a familiar environment to JavaScript developers.
# require
Scripts may include standard NPM libraries by using CommonJS require. The library search will look in the path automation/js/node_modules in the user configuration directory. See libraries for more information.
# console
The JS Scripting binding supports the standard console object for logging. Script logging is enabled by default at the INFO level (messages from console.debug and console.trace won't be displayed), but can be configured using the openHAB console (opens new window):
log:set DEBUG org.openhab.automation.script
log:set TRACE org.openhab.automation.script
log:set DEFAULT org.openhab.automation.script
The default logger name consists of the prefix org.openhab.automation.script and the script’s individual part .file.filename or .ui.ruleUID. This logger name can be changed by assigning a new string to the loggerName property of the console:
console.loggerName = 'org.openhab.custom';
Please be aware that messages do not appear in the logs if the logger name does not start with org.openhab. This behaviour is due to log4j2 (opens new window) requiring a setting for each logger prefix in $OPENHAB_USERDATA/etc/log4j2.xml (on openHABian: /srv/openhab-userdata/etc/log4j2.xml).
  • console.log(obj1 [, obj2, ..., objN])
  • console.info(obj1 [, obj2, ..., objN])
  • console.warn(obj1 [, obj2, ..., objN])
  • console.error(obj1 [, obj2, ..., objN])
  • console.debug(obj1 [, obj2, ..., objN])
  • console.trace(obj1 [, obj2, ..., objN])
Where obj1 ... objN is a list of JavaScript objects to output. The string representations of each of these objects are appended together in the order listed and output.
Note: openhab-js (opens new window) is logging to org.openhab.automation.openhab-js.
# Timers
JS Scripting provides access to the global setTimeout, setInterval, clearTimeout and clearInterval methods specified in the Web APIs (opens new window).
When a script is unloaded, all created timeouts and intervals are automatically cancelled.
# setTimeout
The global setTimeout() (opens new window) method sets a timer which executes a function once the timer expires. setTimeout() returns a timeoutId (a positive integer value) which identifies the timer created.
var timeoutId = setTimeout(callbackFunction, delay, param1, /* ... */ paramN);
delay is an integer value that represents the number of milliseconds to wait before the timer expires. param1 ... paramN are optional, additional arguments which are passed through to the callbackFunction.
The global clearTimeout(timeoutId) (opens new window) method cancels a timeout previously established by calling setTimeout().
If you need a more verbose way of creating timers, consider to use createTimer instead.
# setInterval
The global setInterval() (opens new window) method repeatedly calls a function, with a fixed time delay between each call. setInterval() returns an intervalId (a positive integer value) which identifies the interval created.
var intervalId = setInterval(callbackFunction, delay, param1, /* ... */ paramN);
The global clearInterval(intervalId) (opens new window) method cancels a timed, repeating action which was previously established by a call to setInterval().
# Accessing Variables
var myVar = 'Hello world!';
// Schedule a timer that expires in ten seconds
setTimeout(() => {
  console.info(`Timer expired with variable value = "${myVar}"`);
}, 10000);
myVar = 'Hello mutation!'; // When the timer runs, it will log "Hello mutation!" instead of "Hello world!"
If you need to pass some variables to the timer but avoid that they can get mutated, pass those variables as parameters to setTimeout/setInterval or createTimer:
setTimeout((myVariable) => {
  console.info(`Timer expired with variable value = "${myVariable}"`);
}, 10000, myVar); // Pass one or more variables as parameters here. They are passed through to the callback function.
myVar = 'Hello mutation!'; // When the timer runs, it will log "Hello world!"
This also works for timers created with actions.ScriptExecution.createTimer.
# Paths
For Rules created from Script Files, scripts will be loaded from automation/js in the user configuration directory.
# Deinitialization Hook
It is possible to hook into unloading of a script and register a function that is called when the script is unloaded.
require('@runtime').lifecycleTracker.addDisposeHook(() => functionToCall());
// Example
require('@runtime').lifecycleTracker.addDisposeHook(() => {
  console.log("Deinitialization hook runs...")
# JS Transformation
openHAB provides several data transformation services (opens new window) as well as the script transformations, that are available from the framework and need no additional installation. It allows transforming values using any of the available scripting languages, which means JavaScript Scripting is supported as well. See the transformation docs (opens new window) for more general information on the usage of script transformations.
Use JavaScript Scripting as script transformation by:
  1. Creating a script in the $OPENHAB_CONF/transform folder with the .js extension. The script should take one argument input and return a value that supports toString() or null:
    (function(data) {
      // Do some data transformation here, e.g.
      return "String has" + data.length + "characters";
    })(input);
  2. Using JS(<scriptname>.js):%s as Item state transformation.
  3. Passing parameters is also possible by using a URL like syntax: JS(<scriptname>.js?arg=value). Parameters are injected into the script and can be referenced like variables.
Simple transformations can aso be given as an inline script: JS(|...), e.g. JS(|"String has " + input.length + "characters"). It should start with the | character, quotes within the script may need to be escaped with a backslash \ when used with another quoted string as in text configurations.
# Standard Library
The standard library is automatically injected into all scripts by default. However, it's recommended to enable auto-injection only for Script Actions & Script Conditions. To import the standard library namespaces manually, add the following at the beginning of your script:
// remove namespaces that are not needed by your code
const { actions, cache, items, things, time, triggers, utils, Quantity } = require('openhab');
The openHAB JavaScript library provides type definitions for most of its APIs to enable code completion is IDEs like VS Code (opens new window). To use the type definitions, install the openhab npm package (opens new window) (read the installation guide (opens new window) for more information), and manually import the used namespaces (see above). If an API does not provide type definitions and therefore autocompletion won't work, the documentation will include a note.
The items namespace allows interactions with openHAB Items. Anywhere a native openHAB Item is required, the runtime will automatically convert the JS-Item to its Java counterpart.
var item = items.KitchenLight;
Calling getItem(...) or ... returns an Item object with the following properties:
  • Item : object
    • .rawItem ⇒ HostItem
    • .persistence ⇒ ItemPersistence
    • .semantics ⇒ ItemSemantics (opens new window)
    • .type ⇒ string
    • .groupType ⇒ string|null
    • .name ⇒ string
    • .label ⇒ string
    • .state ⇒ string
    • .numericState ⇒ number|null: State as number, if state can be represented as number, or null if that's not the case
    • .quantityState ⇒ Quantity|null: Item state as Quantity or null if state is not Quantity-compatible or without unit
    • .boolState ⇒ boolean|null: Item state as boolean or null if not boolean-compatible or is NULL or UNDEF, see below for mapping of state to boolean
    • .rawState ⇒ HostState
    • .previousState ⇒ string|null: Previous state as string, or null if not available
    • .previousNumericState ⇒ number|null: Previous state as number, if state can be represented as number, or null if that's not the case or not available
    • .previousQuantityState ⇒ Quantity|null: Previous item state as Quantity or null if state is not Quantity-compatible, without unit, or not available
    • .previousRawState ⇒ HostState
    • .lastStateUpdateTimestamp ⇒ time.ZonedDateTime: The time the state was last updated as ZonedDateTime or null if not available
    • .lastStateUpdateInstant ⇒ time.Instant: The time the state was last updated as Instant or null if not available
    • .lastStateChangeTimestamp ⇒ time.ZonedDateTime: The time the state was last changed as ZonedDateTime or null if not available
    • .lastStateChangeInstant ⇒ time.Instant: The time the state was last changed as Instant or null if not available
    • .members ⇒ Array[Item]
    • .descendents ⇒ Array[Item]
    • .isUninitialized ⇒ boolean
    • .groupNames ⇒ Array[string]
    • .tags ⇒ Array[string]
    • .getMetadata(namespace) ⇒ object|null
    • .replaceMetadata(namespace, value, configuration) ⇒ object
    • .removeMetadata(namespace) ⇒ object|null
    • .sendCommand(value): value can be a string, a number, a time.ZonedDateTime, a time.Instant, or a Quantity
    • .sendCommand(value, expire): expire is a time.Duration, this will return the Item to its previous state after the given expire duration
    • .sendCommand(value, expire, onExpire): onExpire can be the same type as value, this will return the Item to the given onExpire value after the given expire duration
    • .sendCommandIfDifferent(value) ⇒ boolean: value can be a string, a number, a time.ZonedDateTime, a time.Instant, or a Quantity
    • .sendIncreaseCommand(value) ⇒ boolean: value can be a number, or a Quantity
    • .sendDecreaseCommand(value) ⇒ boolean: value can be a number, or a Quantity
    • .sendToggleCommand(): Sends a command to flip the Item's state (e.g. if it is ON, an OFF command is sent).
    • .postUpdate(value): value can be a string, a time.ZonedDateTime, or a Quantity
    • .addGroups(...groupNamesOrItems)
    • .removeGroups(...groupNamesOrItems)
    • .addTags(...tagNames)
    • .removeTags(...tagNames)
// Equivalent to items.KitchenLight
var item = items.getItem("KitchenLight");
// Send an ON command
item.sendCommand("ON");
// Post an update
item.postUpdate("OFF");
// Get state
console.log("KitchenLight state", item.state);
The boolState property is mapped according to the following table:
Item Type .boolState
Call null
Color brightness > 0
Contact state === OPEN
DateTime null
Dimmer state > 0
Group null if no group type, else use the group state
Image null
Location null
Number state !== 0
Number: state !== 0
Player state === PLAY
Rollershutter state > 0
String null
Switch state === ON
See openhab-js : Item (opens new window) for full API documentation.
# itemConfig
  • itemConfig : object
    • .type ⇒ string: required, e.g. Switch or Group
    • .name ⇒ string: required
    • .label ⇒ string: optional
    • .category (icon) ⇒ string: optional
    • .groups ⇒ Array[string]: optional names of groups to be a member of
    • .tags ⇒ Array[string]: optional
    • .group ⇒ object: optional additional config if Item is group Item
      • .type ⇒ string: optional type of the group, e.g. Switch
      • .function ⇒ string: optional aggregation function, e.g. AND
      • .parameters ⇒ Array[string]: parameters possibly required by aggregation function, e.g. ON and OFF
    • .channels ⇒ string | Object { channeluid: { config } }
    • .metadata ⇒ Object { namespace: 'value' } | Object { namespace: { value: '' , configuration: { ... } } }
There are a few short forms for common metadata available:
    • .format ⇒ string: short form for stateDescription metadata's pattern configuration
    • .unit ⇒ string: short form for the unit metadata
    • .autoupdate ⇒ boolean: short form for the autoupdate metadata
Note: .type and .name are required. Basic UI and the mobile apps need metadata.stateDescription.configuration.pattern to render the state of an Item.
items.replaceItem({
  type: 'Switch',
  label: 'My Switch'
items.replaceItem({
  type: 'String',
  label: 'Hallway Light',
  category: 'light',
  groups: ['Hallway', 'Light'],
  tags: ['Lightbulb'],
  channels: {
      profile: 'system:follow'
  metadata: {
    expire: '10m,command=1',
    stateDescription: {
      config: {
        pattern: '%d%%',
items.replaceItem({
  type: 'Group',
  label: 'Lights',
  group: {
    type: 'Switch',
    function: 'AND',
    parameters: ['ON', 'OFF']
The addItem method can be used to provide Items from scripts in a configuration-as-code manner. It also allows providing metadata and channel configurations for the Item, basically creating the Item as if it was defined in a .items file. The benefit of using addItem is that you can use loops, conditions, or generator functions to create lots of Items without the need to write them all out in a file or manually in the UI.
When called from script files, the created Item will share the lifecycle with the script, meaning it will be removed when the script is unloaded. You can use the persist parameter to optionally persist the Item from script files.
When called from Script Actions, the Item will be stored permanently and will not be removed when the script is unloaded. Keep in mind that attempting to add an Item with the same name as an existing Item will result in an error.
# ItemPersistence
Calling Item.persistence returns an ItemPersistence object with the following functions:
  • ItemPersistence :object
    • .averageSince(timestamp, riemannType, serviceId) ⇒ PersistedState | null
    • .averageUntil(timestamp, riemannType, serviceId) ⇒ PersistedState | null
    • .averageBetween(begin, end, riemannType, serviceId) ⇒ PersistedState | null
    • .changedSince(timestamp, serviceId) ⇒ boolean
    • .changedUntil(timestamp, serviceId) ⇒ boolean
    • .changedBetween(begin, end, serviceId) ⇒ boolean
    • .countSince(timestamp, serviceId) ⇒ number
    • .countUntil(timestamp, serviceId) ⇒ number
    • .countBetween(begin, end, serviceId) ⇒ number
    • .countStateChangesSince(timestamp, serviceId) ⇒ number
    • .countStateChangesUntil(timestamp, serviceId) ⇒ number
    • .countStateChangesBetween(begin, end, serviceId) ⇒ number
    • .deltaSince(timestamp, serviceId) ⇒ PersistedState | null
    • .deltaUntil(timestamp, serviceId) ⇒ PersistedState | null
    • .deltaBetween(begin, end, serviceId) ⇒ PersistedState | null
    • .deviationSince(timestamp, riemannType, serviceId) ⇒ PersistedState | null
    • .deviationUntil(timestamp, riemannType, serviceId) ⇒ PersistedState | null
    • .deviationBetween(begin, end, riemannType, serviceId) ⇒ PersistedState | null
    • .evolutionRateSince(timestamp, riemannType, serviceId) ⇒ number | null
    • .evolutionRateUntil(timestamp, riemannType, serviceId) ⇒ number | null
    • .evolutionRateBetween(begin, end, riemannType, serviceId) ⇒ number | null
    • .getAllStatesSince(timestamp, serviceId) ⇒ Array[PersistedItem]
    • .getAllStatesUntil(timestamp, serviceId) ⇒ Array[PersistedItem]
    • .getAllStatesBetween(begin, end, serviceId) ⇒ Array[PersistedItem]
    • .lastUpdate(serviceId) ⇒ ZonedDateTime | null
    • .nextUpdate(serviceId) ⇒ ZonedDateTime | null
    • .lastChange(serviceId) ⇒ ZonedDateTime | null
    • .nextChange(serviceId) ⇒ ZonedDateTime | null
    • .maximumSince(timestamp, serviceId) ⇒ PersistedItem | null
    • .maximumUntil(timestamp, serviceId) ⇒ PersistedItem | null
    • .maximumBetween(begin, end, serviceId) ⇒ PersistedItem | null
    • .minimumSince(timestamp, serviceId) ⇒ PersistedItem | null
    • .minimumUntil(timestamp, serviceId) ⇒ PersistedItem | null
    • .minimumBetween(begin, end, serviceId) ⇒ PersistedItem | null
    • .medianSince(timestamp, serviceId) ⇒ PersistedState | null
    • .medianUntil(timestamp, serviceId) ⇒ PersistedState | null
    • .medianBetween(begin, end, serviceId) ⇒ PersistedState | null
    • .persist(serviceId): Tells the persistence service to store the current Item state, which is then done asynchronously. Warning: This has the side effect, that if the Item state changes shortly after .persist has been called, the new Item state will be persisted. See JSDoc (opens new window) for a possible work-around.
    • .persist(timestamp, state, serviceId): Tells the persistence service to store the given state at the given timestamp, which is then done asynchronously.
    • .persist(timeSeries, serviceId): Tells the persistence service to store the given TimeSeries, which is then done asynchronously.
    • .persistedState(timestamp, serviceId) ⇒ PersistedItem | null
    • .previousState(skipEqual, serviceId) ⇒ PersistedItem | null
    • .nextState(skipEqual, serviceId) ⇒ PersistedItem | null
    • .riemannSumSince(timestamp, riemannType, serviceId) ⇒ PersistedState | null
    • .riemannSumUntil(timestamp, riemannType, serviceId) ⇒ PersistedState | null
    • .riemannSumBetween(begin, end, riemannType, serviceId) ⇒ PersistedState | null
    • .sumSince(timestamp, serviceId) ⇒ PersistedState | null
    • .sumUntil(timestamp, serviceId) ⇒ PersistedState | null
    • .sumBetween(begin, end, serviceId) ⇒ PersistedState | null
    • .updatedSince(timestamp, serviceId) ⇒ boolean
    • .updatedUntil(timestamp, serviceId) ⇒ boolean
    • .updatedBetween(begin, end, serviceId) ⇒ boolean
    • .varianceSince(timestamp, serviceId) ⇒ PersistedState | null
    • .varianceUntil(timestamp, serviceId) ⇒ PersistedState | null
    • .varianceBetween(begin, end, serviceId) ⇒ PersistedState | null
riemannType is an optional argument for methods that require calculating an approximation of the integral value. The approximation is calculated using a Riemann sum, with left, right, trapezoidal or midpoint value approximations. The argument is a Java RiemannType enum with possible values: RiemannType.LEFT, RiemannType.RIGHT, RiemannType.TRAPEZOIDAL or RiemannType.MIDPOINT. If omitted, RiemannType.LEFT is used. The RiemannType enum can be statically accessed on the items namespace, e.g.:
items.RiemannType.LEFT
A Riemann sum is always calculated using seconds as unit for time. As an example, the Riemann sum of power values in kW will result in an energy measurement in kWs. You can rely on framework functionality to convert to the appropriate unit (e.g. kWh), or do an explicit conversion. If you don't use units, be aware of this time factor.
Note: serviceId is optional, if omitted, the default persistence service will be used.
var item = items.KitchenDimmer;
console.log('KitchenDimmer averageSince', item.persistence.averageSince(yesterday));
The PersistedState object contains the following properties, representing Item state:
  • state: State as string
  • numericState: State as number, if state can be represented as number, or null if that's not the case
  • quantityState: Item state as Quantity or null if state is not Quantity-compatible
  • rawState: State as Java State object
The PersistedItem object extends PersistedState with the following properties, representing Item state and the respective timestamp:
var midnight = time.toZDT('00:00');
var historic = items.KitchenDimmer.persistence.maximumSince(midnight);
console.log('KitchenDimmer maximum was ', historic.state, ' at ', historic.timestamp);
See openhab-js : ItemPersistence (opens new window) for full API documentation.
# TimeSeries
A TimeSeries is used to transport a set of states together with their timestamp. It is usually used for persisting historic state or forecasts in a persistence service by using ItemPersistence.persist.
When creating a new TimeSeries, a policy must be chosen - it defines how the TimeSeries is persisted in a persistence service:
  • ADD adds the content to the persistence, well suited for persisting historic data.
  • REPLACE first removes all persisted elements in the timespan given by begin and end of the TimeSeries, well suited for persisting forecasts.
A TimeSeries object has the following properties and methods:
  • policy: The persistence policy, either ADD or REPLACE.
  • begin: Timestamp of the first element of the TimeSeries.
  • end: Timestamp of the last element of the TimeSeries.
  • size: Number of elements in the TimeSeries.
  • states: States of the TimeSeries together with their timestamp and sorted by their timestamps. Be aware that this returns a reference to the internal state array, so changes to the array will affect the TimeSeries.
  • add(timestamp, state): Add a given state to the TimeSeries at the given timestamp.
The following example shows how to create a TimeSeries:
var timeSeries = new items.TimeSeries('ADD'); // Create a new TimeSeries with policy ADD
timeSeries.add(time.toZDT('2024-01-01T14:53'), Quantity('5 m')).add(time.toZDT().minusMinutes(2), Quantity('0 m')).add(time.toZDT().plusMinutes(5), Quantity('5 m'));
console.log(ts); // Let's have a look at the TimeSeries
items.getItem('MyDistanceItem').persistence.persist(timeSeries, 'influxdb'); // Persist the TimeSeries for the Item 'MyDistanceItem' using the InfluxDB persistence service
The Things namespace allows interacting with openHAB Things.
  • things : object
    • .getThing(uid) ⇒ Thing|null
    • .getThings() ⇒ Array[Thing]
Calling getThing(uid) returns a Thing object with the following properties:
  • Thing : object
    • .bridgeUID ⇒ String
    • .label ⇒ String
    • .location ⇒ String
    • .status ⇒ String
    • .statusInfo ⇒ String
    • .thingTypeUID ⇒ String
    • .uid ⇒ String
    • .isEnabled ⇒ Boolean
    • .setLabel(label)
    • .setLocation(location)
    • .setProperty(name, value)
    • .setEnabled(enabled)
var thing = things.getThing('astro:moon:home');
// Set Thing location
// Disable Thing
thing.setEnabled(false);
The actions namespace allows interactions with openHAB actions. The following is a list of standard actions.
Warning: Please be aware that (unless not explicitly noted) there is no type conversion from Java to JavaScript types for the return values of actions. Read the Javadoc linked from the JSDoc to learn about the returned Java types.
Please note that most of the actions currently do not provide type definitions and therefore auto-completion does not work.
# Audio Actions
# BusEvent Actions
# CoreUtil Actions
See openhab-js : actions.CoreUtil (opens new window) for complete documentation.
The CoreUtil actions provide access to parts of the utilities included in openHAB core, see org.openhab.core.util (opens new window). These include several methods to convert between color types like HSB, RGB, sRGB, RGBW and XY.
# Ephemeris Actions
Ephemeris is a way to determine what type of day today or the number of days before or after today is. For example, a way to determine if today is a weekend, a public holiday, someone’s birthday, trash day, etc.
Additional information can be found on the Ephemeris Actions Docs (opens new window) as well as the Ephemeris Javadoc (opens new window).
var weekend = actions.Ephemeris.isWeekend();
# Exec Actions
Execute a command line.
// Execute command line.
var response = actions.Exec.executeCommandLine(time.Duration.ofSeconds(20), 'echo', 'Hello World!');
# HTTP Actions
// Example GET Request
# Ping Actions
See openhab-js : actions.Ping (opens new window) for complete documentation.
// Check if a host is reachable
var reachable = actions.Ping.checkVitality(host, port, timeout); // host: string, port: int, timeout: int
# ScriptExecution Actions
The ScriptExecution actions provide the callScript(string scriptName) method, which calls a script located at the $OH_CONF/scripts folder, as well as the createTimer method.
You can also create timers using the native JS methods for timer creation, your choice depends on the versatility you need. Sometimes, using setTimeout is much faster and easier, but other times, you need the versatility that createTimer provides.
Keep in mind that you should somehow manage the timers you create using createTimer, otherwise you could end up with unmanageable timers running until you restart openHAB. A possible solution is to store all timers in the private cache and let openHAB automatically cancel them when the script is unloaded and the cache is cleared. When using createTimer, please read Accessing Variables to avoid having unexpected results when using variables in timers.
# createTimer
actions.ScriptExecution.createTimer(time.ZonedDateTime zdt, function functionRef, any param1, /* ... */ paramN);
actions.ScriptExecution.createTimer(string identifier, time.ZonedDateTime zdt, function functionRef, any param1, /* ... */ paramN);
createTimer accepts the following arguments:
  • string identifier (optional): Identifies the timer by a string, used e.g. for logging errors that occur during the callback execution.
  • time.ZonedDateTime zdt: Point in time when the callback should be executed.
  • function functionRef: Callback function to execute when the timer expires.
  • * param1, ..., paramN: Additional arguments which are passed through to the function specified by functionRef.
createTimer returns an openHAB Timer, that provides the following methods:
  • cancel(): Cancels the timer. ⇒ boolean: true, if cancellation was successful
  • getExecutionTime(): The scheduled execution time or null if timer was cancelled. ⇒ time.ZonedDateTime or null
  • isActive(): Whether the scheduled execution is yet to happen. ⇒ boolean
  • isCancelled(): Whether the timer has been cancelled. ⇒ boolean
  • hasTerminated(): Whether the scheduled execution has already terminated. ⇒ boolean
  • reschedule(time.ZonedDateTime): Reschedules a timer to a new starting time. This can also be called after a timer has terminated, which will result in another execution of the same code. ⇒ boolean: true, if rescheduling was successful
function timerOver () {
  console.info('The timer expired.');
// Create the Timer.
var myTimer = actions.ScriptExecution.createTimer('My Timer', now.plusSeconds(10), timerOver);
// Cancel the timer.
myTimer.cancel();
var active = myTimer.isActive();
// Reschedule the timer.
myTimer.reschedule(now.plusSeconds(5));
# Transformation Actions
openHAB provides various data transformation services (opens new window) which can translate between technical and human-readable values. Usually, they are used directly on Items, but it is also possible to access them from scripts.
console.log(actions.Transformation.transform('MAP', 'en.map', 'OPEN')); // open
console.log(actions.Transformation.transform('MAP', 'de.map', 'OPEN')); // offen
See openhab-js : actions.Transformation (opens new window) for complete documentation.
# Voice Actions
# Cloud Notification Actions
Requires the openHAB Cloud Connector (opens new window) to be installed.
There are three different types of notifications:
  • Broadcast Notifications: Sent to all registered devices and shown as a notification on these devices.
  • Standard Notifications: Sent to the registered devices of the specified user and shown as notification on his devices.
  • Log Notifications: Only shown in the notification log, e.g. inside the Android and iOS Apps.
In addition to that, notifications can be updated later be re-using the same referenceId and hidden/removed either by referenceId or tag.
To send these three types of notifications, use the notificationBuilder(message) method of the actions namespace. message is optional and may be omitted. It returns a new NotificationBuilder object, which by default sends a broadcast notification and provides the following methods:
  • .logOnly(): Send a log notification only.
  • .hide(): Hides notification(s) with the specified referenceId or tag (referenceId has precedence over tag).
  • .addUserId(emailAddress): By adding the email address(es) of specific openHAB Cloud user(s), the notification is only sent to this (these) user(s). To add multiple users, either call addUserId multiple times or pass multiple emails as multiple params, e.g. addUserId(emailAddress1, emailAddress2).
  • .withIcon(icon): Sets the icon of the notification.
  • .withTag(tag): Sets the tag of the notification. Used for grouping notifications and to hide/remove groups of notifications.
  • .withTitle(title): Sets the title of the notification.
  • .withReferenceId(referenceId): Sets the reference ID of the notification. If none is set, but it might be useful, a random UUID will be generated. The reference ID can be used to update or hide the notification later by using the same reference ID again.
  • .withOnClickAction(action): Sets the action to be executed when the notification is clicked.
  • .withMediaAttachmentUrl(mediaAttachmentUrl): Sets the URL of a media attachment to be displayed with the notification. This URL must be reachable by the push notification client.
  • .addActionButton(label, action): Adds an action button to the notification. Please note that due to Android and iOS limitations, only three action buttons are supported.
  • .send()string|null: Sends the notification and returns the reference ID or null for log notifications and when hiding notifications.
The syntax for the action parameter is described in openHAB Cloud Connector: Action Syntax (opens new window).
The syntax for the mediaAttachmentUrl parameter is described in openHAB Cloud Connector (opens new window).
// Send a simple broadcast notification
actions.notificationBuilder('Hello World!').send();
// Send a broadcast notification with icon, tag and title
  .withIcon('f7:bell_fill').withTag('important').withTitle('Important Notification').send();
// Send a broadcast notification with icon, tag, title, media attachment URL and actions
  .withOnClickAction('ui:navigate:/page/my_floorplan_page').withMediaAttachmentUrl('https://example.com/image.jpg')
  .addActionButton('Turn Kitchen Light ON', 'command:KitchenLights:ON').addActionButton('Turn Kitchen Light OFF', 'command:KitchenLights:OFF').send();
// Send a simple standard notification to two specific users
actions.notificationBuilder('Hello World!').addUserId('florian@example.com').addUserId('florian@example.org').send();
// Send a standard notification with icon, tag and title to two specific users
  .withIcon('f7:bell_fill').withTag('important').withTitle('Important notification').send();
// Sends a simple log notification
actions.notificationBuilder('Hello World!').logOnly().send();
// Sends a simple log notification with icon and tag
  .withIcon('f7:bell_fill').withTag('important').send();
// Sends a notification about a temperature change ...
actions.notificationBuilder('new temperature: xyz').withIcon('oh:temperature').withTag('Temperature change').withReferenceId('livingRoom').send();
// ... and hides it again after 10 minutes
setTimeout(() => {
  actions.notificationBuilder().hide().withReferenceId('livingRoom').send();
}, 10 * 60 * 1000);
See openhab-js : actions.NotificationBuilder (opens new window) for complete documentation.
# Cache
The cache namespace provides both a private and a shared cache that can be used to set and retrieve data that will be persisted between subsequent runs of the same or between scripts.
The private cache can only be accessed by the same script and is cleared when the script is unloaded. You can use it to store primitives and objects, e.g. store timers or counters between subsequent runs of that script. When a script is unloaded and its cache is cleared, all timers (see createTimer) stored in its private cache are automatically cancelled.
The shared cache is shared across all rules and scripts, it can therefore be accessed from any automation language. The access to every key is tracked, and the key is removed when all scripts that ever accessed that key are unloaded. If that key stored a timer, the timer will be cancelled. You can use it to store primitives and Java objects, e.g. store timers or counters between multiple scripts.
Due to a multi-threading limitation in GraalJS (the JavaScript engine used by JavaScript Scripting), it is not recommended to store JavaScript objects in the shared cache. Multithreaded access to JavaScript objects will lead to script execution failure! You can work around that limitation by either serialising and deserialising JS objects or by switching to their Java counterparts.
Timers as created by createTimer can be stored in the shared cache. The ids of timers and intervals as created by setTimeout and setInterval cannot be shared across scripts as these ids are local to the script where they were created.
  • cache : object
    • .private
      • .get(key, defaultSupplier) ⇒ * | null
      • .put(key, value) ⇒ Previous * | null
      • .remove(key) ⇒ Previous * | null
      • .exists(key) ⇒ boolean
    • .shared
var counter = cache.shared.get('counter', () => 0);
console.log('Counter: ' + counter);
Example (Get a previously set value, modify and store it)
var counter = cache.private.get('counter');
counter++;
cache.private.put('counter', counter);
# Time
openHAB internally makes extensive use of the java.time package. openHAB-JS exports the excellent JS-Joda (opens new window) library via the time namespace, which is a native JavaScript port of the same API standard used in Java for java.time. Anywhere a native Java ZonedDateTime, Instant, or Duration is required, the runtime will automatically convert a JS-Joda ZonedDateTime, Instant, or Duration to its Java counterpart.
var item = items.Kitchen;
console.log("averageSince", item.persistence.averageSince(yesterday));
# Parsing and Formatting
Occasionally, one will need to parse a non-supported date time string or generate one from a ZonedDateTime. To do this, you will use JS-Joda DateTimeFormatter and potentially your Locale (opens new window). However, shipping all the locales with the openhab-js library would lead to an unacceptable large size. Therefore, if you attempt to use the DateTimeFormatter and receive an error saying it cannot find your locale, you will need to manually install your locale and import it into your rule.
JS-Joda Locales (opens new window) includes a list of all the supported locales. Each locale consists of a two-letter language indicator followed by a "-" and a two-letter dialect indicator: e.g. "EN-US". Installing a locale can be done through the command npm install @js-joda/locale_de-de from the $OPENHAB_CONF/automation/js folder.
To import and use a local into your rule, you need to require it and create a DateTimeFormatter that uses it:
var Locale = require('@js-joda/locale_de-de').Locale.GERMAN;
var formatter = time.DateTimeFormatter.ofPattern('dd.MM.yyyy HH:mm').withLocale(Locale);
# time.javaInstantToJsInstant()
Converts a java.time.Instant (opens new window) to a JS-Joda Instant (opens new window).
# time.javaZDTToJsZDT()
Converts a java.time.ZonedDateTime (opens new window) to a JS-Joda ZonedDateTime (opens new window).
# time.toZDT()
There will be times when this automatic conversion is not available (for example, when working with date times within a rule). To ease having to deal with these cases a time.toZDT() function will accept almost any type that can be converted to a time.ZonedDateTime. The following rules are used during the conversion:
Argument Type Rule Examples
null or undefined time.ZonedDateTime.now() time.toZDT();
time.ZonedDateTime passed through unmodified
java.time.ZonedDateTime converted to the time.ZonedDateTime equivalent
time.Instant, java.time.Instant converted to the time.ZonedDateTime equivalent using SYSTEM as the timezone time.toZDT(time.toInstant(500)); (epoch milli 500 to ZDT)
JavaScript native Date converted to the time.ZonedDateTime equivalent using SYSTEM as the timezone
number, bingint, java.lang.Number, DecimalType rounded to the nearest integer and added to now as milliseconds time.toZDT(1000);
Quantity or QuantityType if the unit is time-compatible, added to now time.toZDT(item.getItem('MyTimeItem').rawState);, time.toZDT(Quantity('10 min'));
items.Item or org.openhab.core.types.Item if the state is supported (see the Type rules in this table, e.g. DecimalType), the state is converted time.toZDT(items.getItem('MyItem'));
String, java.lang.String, StringType parsed based on the following rules; if no timezone is specified, SYSTEM timezone is used
ISO8601 Date/Time (opens new window) String parsed, depending on the provided data: if no date is passed, today's date; if no time is passed, midnight time time.toZDT('00:00');, time.toZDT('2022-12-24');, time.toZDT('2022-12-24T18:30');
RFC String (output from a Java ZonedDateTime.toString()) parsed time.toZDT('2019-10-12T07:20:50.52Z');
"kk:mm[:ss][ ]a" (12 hour time) today's date with the time indicated, the space between the time and am/pm and seconds are optional time.toZDT('1:23:45 PM');
ISO 8601 Duration (opens new window) String added to now time.toZDT('PT1H4M6.789S');
If no time zone is explicitly set, the system's default time zone is used. When a type or string that cannot be handled is encountered, an error is thrown.
# Additions to time.ZonedDateTime
The openHAB JavaScript library extends the JS-Joda ZonedDateTime class with additional methods that are useful in openHAB.
# toToday()
For example, if the time was 13:45 and today was a DST changeover, the time would still be 13:45 instead of one hour off.
var alarm = items.Alarm;
# isBeforeTime(timestamp), isBeforeDate(timestamp), isBeforeDateTime(timestamp)
Tests whether this time.ZonedDateTime is before the time passed in timestamp, tested in various ways:
  • isBeforeTime only compares the time portion of both, ignoring the date portion
  • isBeforeDate only compares the date portion of both, ignoring the time portion
  • isBeforeDateTime compares both date and time portions
timestamp can be anything supported by time.toZDT().
time.toZDT('22:00').isBeforeTime('23:00')
time.toZDT('2022-12-01T12:00Z').isBeforeDateTime('2022-12-02T13:00Z')
# isAfterTime(timestamp), isAfterDate(timestamp), isAfterDateTime(timestamp)
Tests whether this time.ZonedDateTime is after the time passed in timestamp, tested in various ways:
  • isAfterTime only compares the time portion of both, ignoring the date portion
  • isAfterDate only compares the date portion of both, ignoring the time portion
  • isAfterDateTime compares both date and time portions
// Equivalent to items.Sunset
time.toZDT().isAfterTime(items.getItem('Sunset')) // is now after sunset?
time.toZDT().isAfterDateTime('2022-12-01T12:00Z') // is now after 2022-12-01 noon?
# isBetweenTimes(start, end)
Tests whether this time.ZonedDateTime is between the passed in start and end. However, the function only compares the time portion of the three, ignoring the date portion. The function takes into account times that span midnight. start and end can be anything supported by time.toZDT().
time.toZDT().isBetweenTimes('22:00', '05:00') // currently between 11:00 pm and 5:00 am
time.toZDT().isBetweenTimes(items.getItem('Sunset'), '11:30 PM') // is now between sunset and 11:30 PM?
// Equivalent to items.StartTime
time.toZDT(items.getItem('StartTime')).isBetweenTimes(time.toZDT(), 'PT1H'); // is the state of StartTime between now and one hour from now
# isBetweenDates(start, end)
Tests whether this time.ZonedDateTime is between the passed in start and end. However, the function only compares the date portion of the three, ignoring the time portion. start and end can be anything supported by time.toZDT().
time.toZDT().isBetweenDates('2022-06-18', '2023-12-24') // currently between 2022-06-18 and 2023-12-24
# isBetweenDateTimes(start, end)
Tests whether this time.ZonedDateTime is between the passed in start and end. start and end can be anything supported by time.toZDT().
time.toZDT().isBetweenDateTimes('2022-06-18T22:00Z', '2023-12-24T05:00Z') // currently between 2022-06-18 22:00 and 2023-12-24 05:00
# isClose(zdt, maxDur)
var timestamp = time.toZDT();
// do some stuff
if(timestamp.isClose(time.toZDT(), time.Duration.ofMillis(100))) {
  // did "do some stuff" take longer than 100 msecs to run?
# getMillisFromNow
var timestamp = time.ZonedDateTime.now().plusMinutes(5);
# time.toInstant()
null or undefined time.Instant.now() time.toInstant();
time.Instant passed through unmodified
java.time.Instant converted to the time.Instant equivalent
number, bingint, java.lang.Number, DecimalType handled as epoch milliseconds and converted to the time.Instant equivalent time.toInstant(500);
java.time.ZonedDateTime converted to the time.Instant equivalent
JavaScript native Date converted to the time.Instant equivalent
items.Item or org.openhab.core.types.Item if the state is supported (see the *Type rules in this table), the state is converted time.toInstant(items.getItem('MyItem'));
String, java.lang.String, StringType parsed time.toInstant('2019-10-12T07:20:50.52Z');
DateTimeType converted to the time.Instant equivalent
# Quantity
The Quantity class greatly simplifies Quantity handling by providing unit conversion, comparisons and mathematical operations. A Quantity consists of a measurement and its Unit of Measurement (UoM) (opens new window), e.g. 5.7 m (the measurement is 5.7, the unit is m meters).
Internally using the openHAB QuantityType, which relies on javax.measure (opens new window), it supports all units and dimensions that openHAB supports. If your unit is not listed in the UoM docs, it is very likely that it is still supported, e.g. the Angstrom Å for very small lengths (1 Å = 10 nm). Anywhere a native openHAB QuantityType is required, the runtime will automatically convert the JS-Quantity to its Java counterpart.
# Creation
Quantity(value) is used without new (it's a factory, not a constructor), pass an amount and a unit to it to create a new Quantity object:
The argument value can be a Quantity-compatible Item, a string, a Quantity instance, or an openHAB Java QuantityType (opens new window).
value strings have the $amount $unit format and must follow these rules:
  • $amount is required with a number provided as string
  • $unit is optional (unit-less quantities are possible) and can have a prefix like m (milli) or M (mega)
  • $unit does not allow whitespaces.
  • $unit does allow superscript, e.g. ² instead of ^2.
  • $unit requires the * between two units to be present, although you usually omit it (which is mathematically seen allowed, but openHAB needs the *).
Generally, you can expect a unit consisting of two (or more) units to need a *, e.g. Nm is N*m,
Nearly all Units of Measurement (UoM) (opens new window) are expected to work with Quantity. ɡₙ (standard gravity) is known to not work.
// Allowed:
var qty = Quantity('5.75 m');
qty = Quantity('1 N*m');
qty = Quantity('1 m/s');
qty = Quantity('1 m^2/s^2');
qty = Quantity('1 m^2/s^-2'); // negative powers
qty = Quantity('1'); // unitless quantity
qty = Quantity(items.my_uom_item);
// Not allowed:
qty = Quantity('m');
qty = Quantity('1 Nm'); // * is required
qty = Quantity('1 m^2 / s^2'); // whitespaces are not allowed
qty = Quantity('1 m^2 s^2'); // / is required
qty = Quantity('1 m2/s2'); // ^ is required
Note: It is possible to create a unit-less (without a unit) Quantity, however, there is no advantage over using a number instead.
# Conversion
It is possible to convert a Quantity to a new Quantity with a different unit or to get a Quantity's amount as integer or float:
var qty = Quantity('10.2 °C');
qty = qty.toUnit('°F');
var intValue = qty.int;
var floatValue = qty.float;
toUnit returns a new Quantity with the given unit or null, if conversion to that unit is not possible.
# Comparison
Quantity provides the following methods for comparison:
  • equal(value)boolean: this Quantity equals to value
  • greaterThan(value)boolean: this Quantity is greater than value
  • greaterThanOrEqual(value)boolean: this Quantity is greater than or equal to value
  • lessThan(value)boolean: this Quantity is less than value
  • lessThanOrEqual(value)boolean: this Quantity is less than or equal to value
value can be a string or a Quantity, for the string the same rules apply as described above.
# Mathematical Operators
  • add(value)Quantity: value can be a Quantity-compatible Item, a string or a Quantity
  • divide(value)Quantity: value can be a Quantity-compatible or Number Item, a number, a string or a Quantity
  • multiply(value)Quantity: value can be a Quantity-compatible or Number Item, a number, a string or a Quantity
  • subtract(value)Quantity: value can be a Quantity-compatible Item, a string or a Quantity
For the string the same rules apply as described above.
See openhab-js : Quantity (opens new window) for full API documentation.
# Log
By default, the JS Scripting binding supports console logging like console.log() and console.debug() to the openHAB default log. Additionally, scripts may create their own native openHAB logger using the log namespace.
var logger = log('my_logger');
//prints "Hello World!"
logger.debug("Hello {}!", "world");
# Utils
# Environment
The environment namespace provides information about the environment of the script, like openHAB, openhab-js (opens new window) & GraalJS versions.
A word of caution: The environment namespace is considered an advanced API and might change without a new major version of openhab-js (opens new window).
See openhab-js : environment (opens new window) for full API documentation.
# Rules created from Script Files
Formerly known as File-Based Rules.
The JavaScript Scripting automation add-on will load .js scripts from automation/js in the user configuration directory. The system will automatically reload a script when changes are detected to the script file or its dependencies. Local variable state is not persisted among reloads, see using the cache for a convenient way to persist objects.
Rules created script files normally share the context with the script file that created them. This allows sharing functions, classes and variables that are defined outside the rule's execute function across multiple rules from the same script file. However, this comes with a caveat: Sharing the context across multiple rules imposes the limitation that only a single rule from the same script file can execute at a time. When writing rules that query persistence or wait for other I/O, it can make sense to disable this behaviour by setting the dedicatedContext option to true for JSRule.
When the dedicatedContext option is set to true, the rule's execute function will be executed in a separate context. This means that the rule's execute function can not access functions, classes or variables from the context of the script file that created the rule. The benefit of using a dedicated context is that the rule's execute function has its own, dedicated context and can therefore execute at any time, without needing to wait for other rules. Please note that in most cases, the dedicated context won't be needed, as rule execution is usually rapid and the wait time for the rule to execute is negligible.
Rules can be created from script files in two different ways: using JSRule or the Rule Builder.
When a rule is triggered, the script is provided information about the event that triggered the rule in the event object. Please refer to Event Object for documentation.
# JSRule
JSRule provides a simple, declarative syntax for defining rules that will be executed based on a trigger condition:
const email = "juliet@capulet.org"
rules.JSRule({
  execute: (event) => {
    // Equivalent to items.BalconyLights.sendCommand("ON")
  tags: ["Balcony", "Lights"],
  overwrite: false, // defaults to false: whether to overwrite an existing rule with the same UID
  dedicatedContext: false // defaults to false: whether to run the rule in a separate dedicated context
Note: You can use the passed event object to get information about the trigger that triggered the rule. See Event Object for documentation.
triggers.SystemStartlevelTrigger(40)  // Rules loaded
triggers.SystemStartlevelTrigger(50)  // Rule engine started
triggers.SystemStartlevelTrigger(70)  // User interfaces started
triggers.SystemStartlevelTrigger(80)  // Things initialised
triggers.DateTimeTrigger('MyDateTimeItem');
You can use null for a trigger parameter to skip its configuration.
You may use SwitchableJSRule to create a rule that can be enabled and disabled with a Switch Item. As an extension to JSRule, its syntax is the same, however, you can specify an Item name (using the switchItemName rule config property) if you don't like the automatically created Item's name.
# Rule Builder
Rules are started by calling rules.when() and can chain together triggers, conditions and operations in the following pattern:
Rules are completed by calling .build(name, description, tags, id) , all parameters are optional, and reasonable defaults will be used if omitted.
  • name (string): rule name - defaults generated name
  • description (string): rule description - defaults generated description
  • tags (string array) tag names - defaults empty array
  • id (string) id - defaults random UUID
rules.when().item("F1_Light").changed().then().send("changed").toItem("F2_Light").build("My Rule", "My First Rule", ['MyTag1', 'Tag2'], 'MyRuleID');
    console.log(event);
Note that the Rule Builder currently does not provide type definitions and therefore auto-completion does not work.
# Rule Builder Triggers
  • when()
  • or()
    • .channel(channelName): Specifies a channel event as a source for the rule to fire.
      • .triggered(event): Trigger on a specific event name
    • .cron(cronExpression): Specifies a cron schedule for the rule to fire.
    • .timeOfDay(time): Specifies a time of day in HH:mm for the rule to fire.
    • .item(itemName): Specifies an Item as the source of changes to trigger a rule.
      • .receivedCommand(), .receivedUpdate(), .changed() allows to define the received command/update, respective new state:
        • .of(command)
        • .to(state)
        • .toOn()
        • .toOff()
      • .changed() allows to define the previous state and a duration for which the Item must have changed:
        • .from(state)
        • .fromOn()
        • .fromOff()
        • .for(duration) where duration is in milliseconds
    • .memberOf(groupName): Specifies a group Item as the source of changes to trigger the rule.
        • .of(command)
        • .to(state)
        • .toOn()
        • .toOff()
        • .from(state)
        • .fromOn()
        • .fromOff()
    • .system(): Specifies a system event as a source for the rule to fire.
      • .ruleEngineStarted()
      • .rulesLoaded()
      • .startupComplete()
      • .thingsInitialized()
      • .userInterfacesStarted()
      • .startLevel(level)
    • .thing(thingName): Specifies a Thing event as a source for the rule to fire.
      • changed()
        • from(state)
        • to(state)
      • updated()
    • .dateTime(itemName): Specifies a DateTime Item whose (optional) date and time schedule the rule to fire.
      • .timeOnly(): Only the time of the Item should be compared, the date should be ignored.
      • .withOffset(offset): The offset in seconds to add to the time of the DateTime Item.
Additionally, all the above triggers have the following functions:
# Rule Builder Conditions
  • if(optionalFunction)
    • .stateOfItem(itemName)
      • is(state)
      • isOn()
      • isOff()
      • in(state...)
# Rule Builder Operations
  • then(optionalFunction)
    • .build(name, description, tags, id)
    • .copyAndSendState()
    • .copyState()
    • .inGroup(groupName)
    • .postIt()
    • .postUpdate(state)
    • .send(command)
    • .sendIt()
    • .sendOff()
    • .sendOn()
    • .sendToggle()
# Rule Builder Examples
}).build();
// Turn on the kitchen light at SUNSET (using the Astro binding)
rules.when().channel('astro:sun:home:set#event').triggered('START').then().sendOn().toItem('KitchenLight').build('Sunset Rule', 'Turn on the kitchen light at SUNSET');
rules.when().timeOfDay('21:00').then().sendOff().toItem('KitchenLight').build('9PM Rule', 'Turn off the kitchen light at 9PM', ['Tag1', 'Tag2']);
rules.when().cron('0 0 21 * * ?').then().send('300,100,100').toItem('HallLight').build('Pink Rule', 'Set the colour of the hall light to pink at 9PM', ['Tag1', 'Tag2'], 'MyCustomID');
rules.when().item('S1').changed().toOn().then().sendOn().toItem('HallLight').build('S1 Rule');
rules.when().item('HallLight').changed().to('300,100,100').if(fn).then().sendToggle().toItem('OutsideLight').build();
// Turn on the outdoor lights based on a DateTime Item's time portion
rules.when().dateTime('OutdoorLights_OffTime').timeOnly().then().sendOff().toItem('OutdoorLights').build('Outdoor Lights off');
rules.when(true).item('HallLight').receivedCommand().then().sendIt().toItem('KitchenLight').build('Hall Light to Kitchen Light');
rules.when(true).item('HallLight').receivedUpdate().then().copyState().fromItem('BedroomLight1').toItem('BedroomLight2').build();
# Advanced Scripting
# Libraries
# Third Party Libraries
Loading of third party libraries is supported the same way as loading the openHAB JavaScript library:
var myLibrary = require('my-library');
Note: Only CommonJS require is supported, ES module loading using import is not supported.
Run the npm command from the automation/js folder to install third party libraries, e.g. from npm (opens new window). This will create a node_modules folder (if it doesn't already exist) and install the library and it's dependencies there.
There are already some openHAB specific libraries available on npm (opens new window), you may also search the forum for details.
# Creating Your Own Library
You can also create your own personal JavaScript library for openHAB, but you cannot just create a folder in node_modules and put your library code in it! When it is run, npm will remove everything from node_modules that has not been properly installed.
Follow these steps to create your own library (it's called a CommonJS module):
  1. Create a separate folder for your library outside of automation/js, you may also initialize a Git repository.
  2. Run npm init from your newly created folder; at least provide responses for the name, version and main (e.g. index.js) fields.
  3. Create the main file of your library (index.js) and add some exports:
    var someProperty = 'Hello world!';
    function someFunction () {
      console.log('Hello from your personal library!');
    module.exports = {
      someProperty,
      someFunction
  4. Tar it up by running npm pack from your library's folder.
  5. Install it by running npm install <path-to-library-folder>/<name>-<version>.tgz from the automation/js folder.
  6. After you've installed it with npm, you can continue development of the library inside node_modules.
  7. As you might have already noticed, the JavaScript Scripting add-on is reloading a script as soon as one of its dependencies changes. When developing a library inside node_modules, this can cause regular reloads. To avoid this situation, you can disable dependency tracking in the JavaScript Scripting add-on settings (you need to tick "show advanced" for the setting to come up).
It is also possible to upload your library to npm (opens new window) to share it with other users.
If you want to get some advanced information, you can read this blog post (opens new window) or just google it.
# @runtime
In most cases, the Standard Library provides pure-JS APIs to interact with the openHAB runtime. Generally speaking, you should therefore prefer to use Standard Library provided by this library instead.
However, in some cases, e.g. when needing a HSBType (opens new window), one needs to access raw Java utilities and types. This can be achieved by using require('@runtime'), e.g.
var { ON, OFF, QuantityType } = require('@runtime');
// var runtime = require('@runtime');
// var ON = runtime.ON;
// var OFF = runtime.OFF;
A list of available utilities and types can be found in the JSR223 Default Preset documentation (opens new window).
require('@runtime') also defines "services" such as items, things, rules, events, actions, ir, itemRegistry. You can use these services for backwards compatibility or ease migration from JSR223 scripts.
