# Preface
# openHAB Configuration Files
  • via mounting the files shares from the server to your client-PC. In the main UI as an admin you can go to Help & About and will have the different folder locations under Technical information.
  • Use the share openHAB-conf when mounting it from Windows or macOS
  • Find you openHAB-Server via the network share functionality
  • User the share openHAB-conf to assign it to a network drive
  • Finder -> Go -> Connect to Server
    • Enter the username and server name to connect to the openHAB Server
    macos-share-1
    • then choose the folder you want to mount
    macos-share-2
Finding it on Linux
  • Access the folder directly on the openHAB server at /etc/openhab
  • html
  • icons
  • items
  • services
  • html
  • persistence
  • rules
  • scripts
  • sitemaps
  • sounds
  • things
  • transform
Also view youtube Creating a Blockly Rule (opens new window)
  • go to Settings -> Rules
  • press plus on bottom right
  • enter a unique id and rule name for your new blockly rule
  • Under "When" click on "Add Trigger" to define a trigger for the rule (you may add multiple triggers which are perceived as any of those triggers may occurs which stands for an OR combination of the triggers)
    • choose a title for the rule
    • choose "item" (or something else) that should trigger the rule
    • select the item from your model and the click PICK on the upper right corner
    • choose "received a command", "was updated" or "changed"
  • Under "Then" click on "Add Action"
  • choose run-script-1
  • click on run-script-2 und you should now see this screen blockly-edit-screen
  • you can now click the toolbox-submenu to access all openHAB Blocks.
  • Drag and Drop the blocks to the white area
  • Press Ctrl-s (Windows) or Command-s (macOS) to save your rule
  • Press Ctrl-r (Windows) or Command-r (macOS) to directly run your rule with the trigger
  • Press Ctrl-d (Windows) or Command-d (macOS) to disable / enable your rule. See the following video on youtube How to disable Rules (opens new window)
  • Click on showblock on the lower right of the bottom toolbar to see the generated code and will transition to showcode(click again to come back to the blocks).
More about the topic of code generation can be viewed at youtube Blockly as an ECMA-Script code generator (opens new window)
# Panning and Zooming
You can move around Blockly's workspace by clicking and dragging on the empty space, or by using two fingers on a touch screen or a trackpad.
Zooming can be done using either of these methods:
  • By pinching or stretching on a touch screen or a trackpad.
  • By holding Ctrl while dragging or moving with two fingers on the touch screen or trackpad.
  • With the on-screen controls:
    workspace-zoom-controls
# Context Menu
A context menu is available when right-clicking on a block.
Blockly Context Menu
Right-clicking on an empty area in the workspace will pop up a slightly different context menu. In particular, Clean up Blocks will automatically move and arrange your blocks neatly.
# Selecting Blocks
Click on a block to select it.
You can select multiple blocks by holding the Shift key while clicking on other blocks. Alternatively, hold down the Shift key, click on an empty area and start dragging to select the blocks within the selection rectangle.
Child blocks are automatically selected when their parent is selected.
Once selected, the blocks can be copied, duplicated, deleted, or moved around.
# Copying & Pasting
Copy-pasting can be used as a quick way to duplicate a set of blocks within the same script. You can also copy a set of blocks into your clipboard, and paste them into another script.
# Other Operations
  • Duplicate: Clones the block
  • Add comment: Adds a comment to the block
  • Inline Inputs / External inputs: Switches between horizontal or vertical alignment of inputs
    Inline: inline-inputs
    External: external-inputs
  • Collapse (expand) block: Shrinks the block to get a better overview
    Normal block view: expanded-block
    Collapsed view:
    collapsed-block
  • Disable (enable) block: Disables the block, so no code is generated and its functionality switched off
  • Delete: delete the blocks (this can be reverted via Command/Ctrl-Z)
# Searching the workspace
Sometimes blockly rules become pretty big, and it is hard to find particular blocks in the rule. Therefore, a search functionality has been provided by pressing Cmd/Ctrl-F which opens a small search window in the top right (just below the "save"-label). After pressing Enter all found blocks that contain the search term are marked in black.
blockly-search
More on that topic can be viewed at youtube Logging (opens new window)
In the developer section there is the possibility to add a sidebar to the blockly rules development workspace that allows to watch live status of an item. View the chapter youtube Debugging Rules with openHAB Developer Tools to watch Item-Status (opens new window) for more information
