# Logic
One of the most commonly used standard blocks are conditions blocks.
More about conditions can be viewed at How to use IF and ELSE (opens new window).
# Math
The Math section mainly consists of standard Blockly blocks. Two new math blocks were added for bitwise operations:
# Bitwise operators
- bitwise and &
- bitwise or |
- bitwise xor ^
- bitwise left shift <<
- bitwise right shift >>
- bitwise unary right shift >>>
# Bitwise invert
Function: The bitwise NOT (~) operator inverts the bits of its operand.
# Rounding
The standard block has been extended to provide a rounding function with the ability to set the number of decimal places:
# Text
More about that topic can be viewed at Working with Text-Blocks (opens new window).
# CRLF
# Text Replace
Function: Allows to replace something that is defined by the pattern in the origin-text with what is provided in replacement. Note that the pattern can be just a text or also regex expression.
# Colors
More about that topic can be viewed at Using Color-Blocks and HSB-Conversion (opens new window)
# Color Picker
# Random Color
# Create RGB color
# Blend two colors
this could be used for example with a loop that changes the ratio from 0 to 1 to blend the first color into a second
- use that block and connect one of the above blocks into that one to be able to retrieve the HSB value of that block.
# Lists
# Loop over a dictionary
This block can be found in the Loops section and is a dedicated block that allows to iterate over the elements of a dictionary. The loop provides the value into the variable that was choosen in the drop down. See the examples below how the loop can be used.
Either the dictionary itself can be provided directly or via a variable.
# Concatenate lists
Function: adds the second list to the first list and returns a new list
# Loops
Even though there a no specialized openHAB blocks provided, loops are used rather often.
Therefore there is a good introduction to loops available which can be viewed at Loops in Blockly (opens new window)
# Functions
A more advanced feature for reusable blockly code is functions.
More about that topic can be viewed at Functions (opens new window) and Parameters (opens new window).
