# Tips and Tricks
# Backups
Always create and maintain a recent backup of your openHAB config. When installed on Linux there will be an openhab-cli command line tool that supports backup and restore. For other systems, under $OH_HOME/runtime/bin you will find backup.sh and restore.sh (or .bat). Note that these will back up both text based configs and anything done through the UI. However, it only does backup and restore for openHAB, not external services.
# Don't Wait, Try it Out!
# Developer Sidebar
Developer Sidebar
Note that the sidebar will not come up if your display is too narrow. It will not work on a phone nor in portrait mode on most tablet displays.
There are four tabs on the sidebar, and the search field at the top.
Imagine you need to find all usages of an Item in rules or pages. You could open all your rules and pages to check them, or just use the developer sidebar search. Enter your Item name, and you will see in which rules, scenes, scripts and pages that Item is used.
The developer sidebar search ignores case and searches inside the following entities:
  • Things
    • UID
    • label
  • Items
    • name
    • label
    • tags (requires exact match)
    • metadata namespaces (requires exact match)
  • Pages
    • uid
    • label
    • content (widgets, tabs, charts, etc. with their configuration)
  • Rules, Scenes & Scripts
    • Item name & Thing UID of triggers, actions & conditions
    • script code (e.g. Rules DSL, JavaScript, and even Blockly)
    • script MIME types (requires exact match)
# Pinned Objects
Let's say you are working on your lighting automations which involves Things, Items, and Rules. Instead of keeping a dozen browser tabs open and flipping between them you can pin these objects to the sidebar.
Enter a search term in the search filed at the top to search within Items, Things, Rules, Scripts, Scenes and Pages. The search term can be part of an object's name, ID, label, etc.
search
Once you find an object that you want to pin, click the push-pin icon to keep it in the list. Once you've pinned all the objects you want, click the x icon in the search bar.
pinned
item control
thing
# Event Monitor
event stream
Item events (update, changed, received command), Thing events (e.g. change in status), and rule events will appear in this stream. But on a typical system a lot of events will be happening all the time. Often one will want to filter. Clicking on the filter icon lets you enter a comma separated list of events that should be streamed. The list is OR meaning is any one matches the event will be shown. For example, entering *Hum* would only show those events that include "Hum" in the names.
# Code Tools
code tools
# Expression Tester
# Scratchpad
# Create Shortcuts
Create Shortcuts
# Consider the logs
# Save Examples
# Where's it all Being Saved?
Everything presented in this tutorial is "managed" and saved to a text based JSON formatted database in $OH_USERDATA/jsondb. This folder contains a number of files, one for each type of entity within openHAB. These files are automatically backed up on changes. If you ever want to see the raw config data, these are the files to look in.
# API
# Asking for Help
  • do not withold information (except security related stuff like passwords); if it doesn't work you likely don't know what is relevant or not
  • provide lots of details
  • post code, logs, and other configs using code fences to preserve formatting
  • avoid posting screen shots of configs or logs where possible; post the text from the "Code" tab
  • answer all questions when asked for more details
  • be polite.
