# Eclipse IDE
If you already have Eclipse installed it is recommended to perform a separate Eclipse install for openHAB to avoid overriding your existing Eclipse configuration.
# Eclipse IDE Setup
  1. Install the Java 21 JDK if you did not have it installed.
    Attention
    openHAB development requires Java JDK version 21.
  2. Download the "Eclipse Installer": can be downloaded from the Eclipse web site (opens new window)
  3. Launch the Installer and on the menu on the top right (3 bars)
    installer
  4. Select ADVANCED MODE...
    installer
  5. Select Eclipse IDE for Java Developers. Select Next >.
    select
  6. Under GitHub Projects > openHAB select openHAB Development and any desired option from openHAB Add-ons (includes all add-ons from openhab-addons repo), openHAB ZigBee Binding or openHAB Z-Wave Binding.
    select projects
    Selection Install if
    openHAB Development Debug/Demo Environment (Required)
    openHAB Add-ons Add-ons Development
    openHAB ZigBee Binding ZigBee Binding Development
    openHAB Z-Wave Binding Z-Wave Binding Development
    openHAB BACNet Binding BACNet Binding Development
    openHAB Web UIs Web UIs Development
    openHAB Core Framework Core Framework Development
  7. Click Next>, verify/modify Root and install folder name. Click on Show all variables to open the window shown below.
    variables
    Explanation of some of the variables
    • Root install folder: The base folder where the Installation folder will be placed.
    • Installation folder name: This is the directory in the root install folder everything will be installed in.
    • GitHub user ID: This is your GitHub user name used to configure the cloned Git projects.
  8. Click Next> and Finish to start installation.
    During install accept license agreement, "Unsigned Content" for Bndtools, and Eclipse Foundation certificates when requested to complete IDE installation.
  9. At this point the Eclipse installer is finished and the Eclipse IDE is automatically launched to continue the installation process.
    Attention
    Setup tasks will personalize the IDE with openHAB code formatting tools, configurations and a demo app. Setup tasks will also download openHAB latest projects you have selected during installation. Like openhab-distro and the add-ons openhab-addons project if you have selected it.
    Click bottom right button in the IDE for Progress.
    startup tasks finished
  10. After all tasks are finished you are ready to start developing.
  11. If you need additional libraries see the Build System documentation. For other libraries supported out-of-the-box check the Default Libraries on the guidelines page.
# Working with Add-ons
To easily run, modify and debug an add-on the openHAB Development setup installs and imports a demo project that contains a complete openHAB environment to run and debug an add-on. This mechanism replaces the add-on installation process via the UI that you would use outside the IDE.
# Running Add-ons
Under Infrastructure you will find the project org.openhab.demo.app. This project contains the full configuration to run openHAB. The following files are of interest for the execution environment:
|- org.openhab.demo.app
|--- runtime
|------- conf             Here you configure the manual text files
|------- userdata         Here is the openHAB user data
|------- log4j2.xml       XML file for logging options
|--- app.bndrun           The file to start openHAB
|--- pom.xml              The pom file with all dependencies for the demo project
  1. To let the demo project know about the add-on, the add-on must be added to the demo project pom.xml. Here is an example for the astro binding:
        <dependency>
        <groupId>org.openhab.addons.bundles</groupId>
        <artifactId>org.openhab.binding.astro</artifactId>
        <version>${project.version}</version>
        <scope>runtime</scope>
        </dependency>
  2. To run the add-on with the app.bndrun run configuration. Double click to open app.bndrun file (takes a few seconds):
    Bndtools
  3. Under Browse Repos search for the add-on you want to run (astro in our case) and add it to the Run Requirements list using drag&drop from the Browse Repos list:
    If you cannot find the binding you want run/debug in the Browse Repos list, or the list is empty, then it is likely either the pom.xml of the demo project contains an error or there is a build problem with your project. Check if your project has no compile errors. Or run Maven on the command line to check if it reports any errors.
    app.bndrun
  4. Save and click "Resolve": a window with the list of resolved bundles will be shown. Click Finish and save the file.
    Watch out - it's easy to miss saving the app.bndrun file. If you see the little asterisk next to app in the app tab you haven't yet saved.
    Now the IDE is ready to start openHAB with a minimum set of the openHAB core bindings, UIs and the add-ons you configured.
  5. Start openHAB from the IDE by clicking "Run OSGi" (upper right of the app.bndrun window).
    Depending on the amount of code you want to debug, especially when you're debugging not only add-ons, but also openHAB Core and UI's, start-up process may gets very slow and/or you get a java.lang.OutOfMemoryError: Java heap space exception. In case this happens, you could increase the maximum heap space by adding e.g. -Xmx8G (for a maximum of 8 gigabyte) to Runtime Properties > JVM arguments (bottem left of the app.bndrun window). Afterwards, you have to save app.bndrun file again.
  6. You can check that openHAB is running with your browser by going to: http://localhost:8080/ (the last / is important!)
  7. You can check log output in the Console tab at the bottom.
  8. Check the chosen binding is active in UI > Settings > Bindings
Debug Animation
  1. Install Sources
    Sources are installed by cloning the openHAB Add-ons (opens new window) repository. If you select openHAB Add-ons during installation the installer automatically clones the openHAB Add-ons (opens new window) repository into git\openhab-addons under your installation folder.
    If you didn't install openHAB Add-ons you can manually clone the openHAB Add-ons (opens new window) repository by executing git clone https://github.com/openhab/openhab-addons.git in the git folder under your installation folder.
    You can now modify add-on sources as needed.
  2. Build Sources
    Add the add-on as an Eclipse project so that Eclipse will build it automatically. Import the add-on project via File > Import... > Maven > Existing Maven Projects. Specify your add-on's source root folder (e.g. git\openhab-addons\bundles\org.openhab.binding.astro under the installation folder) as the root folder in the wizard.
  3. Start a Debug Session
    Simply start your debug session by clicking "Debug OSGi" (upper right of the app.bndrun window). You can now use breakpoints and all other Eclipse debug tools.
If you just run an add-on following the above steps then the required add-on jar files are retrieved through your Maven repository folder .m2/repository (e.g. .m2\repository\org\openhab\addons\bundles\org.openhab.binding.astro). If you imported your add-on as a project then the jar file is no longer retrieved from the Maven repository, but instead from the project build (e.g. git\openhab-addons\bundles\org.openhab.binding.astro\target under the installation folder).
# Using New Bindings
# Updating openHAB
You can update the openHAB version you are running in the IDE at any time simply by updating your git repos under your install folder. For example to update to the latest version run git checkout in each repo folder under your git folder in the installation folder.
