# IntelliJ IDE
# Prerequisites
- git, Maven (at least 3.8.6), IntelliJ and Java (21) are installed and available in the path.
# Build the repositories
Fork and clone the repositories into a parent directory (Reference
<PARENT_DIR>
from now on for this article). Take only the one(s) you will work on:
Use the command git clone https://github.com/<yourgitusername>/openhab-<addons|core|webui>
(replace git user name accordingly).
Open IntelliJ, select the file/open, and choose the
<PARENT_DIR>
Open The Module settings (inside
Project Settings
, or use F4). Click on the + button and selectImport module
.Choose one of the repository directory you just cloned. select the Maven external model as import format. IntelliJ will start importing and indexing. It will take while, wait until finished. The Module window should now be filled with a bunch of projects.
Repeat step 2 and 3 for all repositories you cloned.
Use Maven to clean & install projects. Make sure you use the required Maven version (3.8.6 is recommended).
mvn clean install
in the root of the repositories using commandline Maven (or IntelliJ Maven view)- some of the add-ons might fail to build - if it's not the one you're interested in, that should not bother you
You then have two main options to run your development: use the official distribution, or use Maven.
# Option 1: Use and debug from the official distribution
This is the simpler option, but you can only use it for add-on development.
# Install openHAB distribution
./start_debug.sh
instead of./start.sh
in step 4)
This article refers to the directory where you installed the distribution as <DISTRO_DIR>
# Debug your addon
Copy the addon JAR to Openhab distribution created before
The running instance of the openhab distribution should pick up your new addon & start it
- you can type
log:tail
in the openhab console to stream the openhab logs
- you can type
Create a Remote Debug runtime configuration in IntelliJ:
- open menu Run | Edit configurations
- click OK
# Option 2: Use maven-bdn plugin and the demo project
This option is more complex, but will allow you to run/debug anything.
You will have to clone the additional repository openhab-distro repository in your <PARENT_DIR>
. It contains the demo project.
Look at the generic IDEs information to know more about how to prepare and launch the demo project.
After this, instead of using the command line, you can setup IntelliJ to launch the maven tasks.
When launching the demo project from IntelliJ with the bnd debug option (in VM options in the screenshot above),
look in the Run window for the mention "Listening for transport".
You can then click on the Attach debugger
to automatically start a debugging session.
