# HomeKit Add-on
This integration exports openHAB Items to a HomeKit controller, so you can control openHAB from the Home app on Apple devices. Do not confuse this with the HomeKit binding (https://www.openhab.org/addons/bindings/homekit/ (opens new window)) which imports data from HomeKit accessories so that you can control them directly from openHAB.
  • Air Purifier
  • Air Quality Sensor
  • Battery
  • Carbon Dioxide Sensor
  • Carbon Monoxide Sensor
  • Contact Sensor
  • Fan
  • Faucet / Shower
  • Filter Maintenance
  • Garage Door Opener
  • Heater / Cooler
  • Humidity Sensor
  • Irrigation System
  • Leak Sensor
  • Light Sensor
  • Lighting (simple, dimmable, color)
  • Lock
  • Microphone
  • Motion Sensor
  • Motorized Door
  • Motorized Window
  • Occupancy Sensor
  • Outlet
  • Security System
  • Slat
  • SmartSpeaker
  • Smoke Sensor
  • Speaker
  • Switchable
  • Temperature Sensor
  • Television
  • Thermostat
  • Valve
  • Window Covering/Blinds
# Quick start
  • install homekit addon via UI
  • add metadata to an existing item (see UI based configuration)
  • scan QR code from UI->Settings->HomeKit Integration
  • open Home app on your iPhone or iPad
  • create new home
  • add accessory
  • click "Add Anyway"
  • follow the instruction of the Home app wizard
Add metadata to more items or fine-tune your configuration using further settings
# Global Configuration
You can define HomeKit settings either via Main UI or via $OPENHAB_CONF/services/homekit.cfg. HomeKit works with default settings, but we recommend changing the PIN for the bridge. This will be used in iOS when pairing without QR code. The PIN code is in the form "###-##-###". Requirements beyond this are not clear, and Apple enforces limitations on eligible PINs within iOS. At the very least, you cannot use repeating (111-11-111) or sequential (123-45-678) PIN codes.
Other settings, such as using Fahrenheit temperatures and specifying the interface to advertise the HomeKit bridge are also illustrated in the following sample:
org.openhab.homekit:port=9123
org.openhab.homekit:instances=1
org.openhab.homekit:useDummyAccessories=false
Some settings are only visible in UI if the checkbox "Show advanced" is activated.
# Overview of all settings
Setting Description Default value
networkInterface IP address or domain name under which the HomeKit bridge can be reached. If no value is configured, the add-on uses the primary IP address configured for openHAB. If unsure, keep it empty (none)
port Port under which the HomeKit bridge can be reached. 9123
useOHmDNS mDNS service is used to advertise openHAB as HomeKit bridge in the network so that HomeKit clients can find it. openHAB already has an mDNS service running. This option defines whether the mDNS service of openHAB or a separate service should be used. false
blockUserDeletion Blocks HomeKit user deletion in openHAB and as a result unpairing of devices. If you experience an issue with accessories becoming non-responsive after some time, try to enable this setting. You can also enable this setting if your HomeKit setup is done and you will not re-pair iOS devices. false
pin PIN code used for pairing with iOS devices. Apparently, PIN codes are provided by Apple and represent specific device types, so they cannot be chosen freely. The PIN code 031-45-154 is used in sample applications and known to work. 031-45-154
useFahrenheitTemperature Set to true to use Fahrenheit degrees, or false to use Celsius degrees. Note if an item has a QuantityType as its state, this configuration is ignored and it's always converted properly. false
name Name under which this HomeKit bridge is announced on the network. This is also the name displayed on the iOS device when searching for available bridges. openHAB
instances Defines how many bridges to expose. Necessary if you have more than 149 accessories. Accessories must be assigned to additional instances via metadata. Additional bridges will use incrementing port numbers. 1
useDummyAccessories When an accessory is missing, substitute a dummy in its place instead of removing it. See Dummy Accessories. false
After setting the global configuration, you will need to tag your openHAB items (opens new window) for HomeKit with an accessory type. For our purposes, you may consider HomeKit accessories to be of two types: simple and complex.
A simple accessory will be mapped to a single openHAB item, e.g., HomeKit lighting can represent an openHAB Switch, Dimmer, or Color item. A complex accessory will be made up of multiple openHAB items, e.g., HomeKit Thermostat can be composed of mode, and current & target temperature. Complex accessories require a tag on a Group Item indicating the accessory type, as well as tags on the items it composes.
A HomeKit accessory has mandatory and optional characteristics (listed below in the table). The mapping between openHAB items and HomeKit accessory and characteristics is done by means of metadata (opens new window).
If the first word of the item name matches the room name in the Home app, the Home app will hide it. E.g., an item with the name "Kitchen Light" will be shown in the "Kitchen" room as "Light". This is the recommended naming convention for HomeKit items and rooms.
# UI Based Configuration
  • select the desired item in Main UI
  • click on "Add Metadata"
  • select "Apple HomeKit" namespace
  • click on "HomeKit Accessory/Characteristic"
  • select the required HomeKit accessory type or characteristic
  • click on "Save"
# Textual Configuration
Switch leaksensor_metadata  "Leak Sensor"           {homekit="LeakSensor"}
The tag can be:
  • fully qualified: i.e., with accessory type and characteristic, e.g., "LeakSensor.LeakDetectedState"
  • shorthand version: with only either accessory type or characteristic, e.g., "LeakSensor", "LeakDetectedState".
If the shorthand version has only an accessory type, then HomeKit will automatically link all mandatory characteristics of this accessory type to the openHAB item. E.g., HomeKit window covering has 3 mandatory characteristics: CurrentPosition, TargetPosition, PositionState. The following are equal configurations:
Rollershutter    window_covering    "Window Rollershutter"     {homekit="WindowCovering"}
Rollershutter    window_covering    "Window Rollershutter"     {homekit="WindowCovering, WindowCovering.CurrentPosition, WindowCovering.TargetPosition, WindowCovering.PositionState"}
If the shorthand version has only a characteristic, then it must be part of a group which has a HomeKit accessory type. You can use an openHAB group to define complex accessories. The group item must indicate the HomeKit accessory type, e.g., LeakSensor definition
Group  gLeakSensor                      "Leak Sensor Group"                                              {homekit="LeakSensor"}
Switch leaksensor                       "Leak Sensor"                           (gLeakSensor)            {homekit="LeakSensor.LeakDetectedState"}
Switch leaksensor_battery               "Leak Sensor Battery"                   (gLeakSensor)            {homekit="LeakSensor.BatteryLowStatus"}
# Complex Multiple Service Accessories
Alternatively, you may want to have a choice of controlling the items individually, or as a group, from HomeKit. The following example defines a single HomeKit accessory with multiple services that the Home app will allow you to control together, or drill down and control individually. Note that AccessoryGroup doesn't expose any services itself but allows you to group other services together underneath it. Also note that when nesting accessories, you cannot use the shorthand of naming only a characteristic and not its accessory type, since it would be ambiguous whether that item belongs to a secondary service or to the primary service it's nested under.
Group:Switch:OR(ON,OFF) gLight "Light Group" {homekit="AccessoryGroup"}
Switch light1 "Light 1" (gLight) {homekit="Lighting"}
Switch light2 "Light 2" (gLight) {homekit="Lighting"}
Group of Lights
You can also group additional accessories directly under another accessory. In this example, HomeKit will show three separate light controls. As this is somewhat confusing (Home will allow controlling all members as a group, and you also have the group as a distinct switch inside the HomeKit accessory), this is not a recommended configuration.
Light Group With Additional Lights
You can also mix and match accessories:
Group gFan {homekit="Fan"}
Switch fan1 "Fan" (gFan) {homekit="Fan.Active"}
Switch fan1_light "Fan Light" (gFan) {homekit="Lighting"}
Fan With Light
Another way to build complex accessories is to associate multiple accessory types with the root group and then define all of the individual characteristics on group members. When using this style, you cannot have multiple instances of the same accessory type.
Group           FanWithLight        "Fan with Light"                           {homekit = "Fan,Lighting"}
Switch          FanActiveStatus     "Fan Active Status"     (FanWithLight)     {homekit = "Fan.ActiveStatus"}
Number          FanRotationSpeed    "Fan Rotation Speed"    (FanWithLight)     {homekit = "Fan.RotationSpeed"}
Switch          Light               "Light"                 (FanWithLight)     {homekit = "Lighting.OnState"}
or in MainUI:
ui_fan_with_light_group_view.png ui_fan_with_light_group_code.png ui_fan_with_light_group_config.png
Finally, you can link one openHAB item to one or more HomeKit accessories, as well:
Switch occupancy_and_motion_sensor       "Occupancy and Motion Sensor Tag"  {homekit="OccupancySensor,MotionSensor"}
You can even form complex sensors this way. Just be sure that you fully specify additional characteristics so that the add-on knows which root service to add it to.
Group eBunkAirthings "Bunk Room Airthings Wave Plus" { homekit="AirQualitySensor,TemperatureSensor,HumiditySensor" }
String Bunk_AirQuality "Bunk Room Air Quality" (eBunkAirthings) { homekit="AirQualitySensor.AirQuality" }
Number:Dimensionless Bunk_Humidity "Bunk Room Relative Humidity [%d %%]" (eBunkAirthings) { homekit="HumiditySensor.RelativeHumidity" }
Number:Temperature Bunk_AmbTemp "Bunk Room Temperature [%.1f °F]" (eBunkAirthings) { homekit="TemperatureSensor.CurrentTemperature" }
Number:Dimensionless Bunk_tVOC "Bunk Room tVOC [%d ppb]" (eBunkAirthings)  { homekit="AirQualitySensor.VOCDensity" [ maxValue=10000 ] }
A sensor with a battery configured in MainUI:
The Home app uses the first accessory in a group as the icon for the group as a whole. E.g., an accessory defined as homekit="Fan,Light" will be shown as a fan and an accessory defined as homekit="Light,Fan" will be shown as a light in the Home app. You can also override the primary service by adding primary=<type> to the HomeKit metadata configuration:
Group           FanWithLight        "Fan with Light"                           {homekit = "Light,Fan" [primary = "Fan"]}
or in Main UI:
Unusual combinations are also possible, e.g., you can combine a temperature sensor with blinds and light.
It will be represented by the Home app as follows:
Note that for sensors that aren't interactive, the Home app will show the constituent pieces in the room and home summaries, and you'll only be able to see the combined accessory when viewing the accessories associated with a particular bridge in the home settings:
Triple Air Sensor Triple Air Sensor Broken Out
# Dummy Accessories
openHAB is a highly dynamic system and prone to occasional misconfigurations where items can't be loaded for various reasons, especially if you're using something besides the UI to manage your items. This is a problem for HomeKit because if the bridge makes a connection but accessories are missing, then the HomeKit database will simply remove that accessory. When the accessory does come back (i.e., because you corrected a syntax error in an .items file, or openHAB completes booting), all customization of that accessory will be lost - the room assignment, customized name, custom icon, status/home screen/favorite preferences, etc. In order to work around this, the HomeKit add-on can create dummy accessories for any accessory it has previously published to HomeKit. To enable this behavior, turn on the useDummyAccessories setting. openHAB will then simply present a non-interactive accessory for any that are missing. The openHAB log will also contain information whenever a dummy accessory is created. If the item backing the accessory is later re-created, everything will sync back up, and nothing will be lost. You can also run the console command openhab:homekit listDummyAccessories to see which items are missing. Apple devices may or may not show "Not Responding" for some or all accessories when there are dummy accessories since they will no longer be backed by actual items with state. It's recommended that you resolve this state as soon as possible since HomeKit may decide your entire bridge is being uncooperative and remove everything itself. If you actually meant to remove an item, you will need to purge the dummy items from the database so that they'll disappear from the Home app altogether. In order to do so, run the console command openhab:homekit pruneDummyAccessories. Alternatively, disabling, saving, and then re-enabling useDummyAccessories in the add-on settings will have the same effect.
This section provides examples of widely used accessory types. For a complete list of supported accessory types and characteristics, please see section [Supported accessory type](#Supported accessory type).
# Dimmers
The way HomeKit handles dimmer devices can be different from the actual dimmers' way of working. The HomeKit Home app sends the following commands/updates:
  • On brightness change, the Home app sends "ON" event along with target brightness, e.g., "Brightness = 50%" + "State = ON".
  • On "ON" event, the Home app sends "ON" along with brightness 100%, i.e., "Brightness = 100%" + "State = ON"
  • On "OFF" event, the Home app sends "OFF" without brightness information.
However, some dimmer devices, for example, do not expect brightness on "ON" event; some others do not expect "ON" upon brightness change. In order to support different devices, the HomeKit integration can filter some events. Which events should be filtered is defined via the dimmerMode configuration.
Dimmer dimmer_light   "Dimmer Light"     {homekit="Lighting, Lighting.Brightness" [dimmerMode="<mode>"]}
The following modes are supported:
  • "normal" - no filtering. The commands will be sent to the device as received from HomeKit. This is the default mode.
  • "filterOn" - ON events are filtered out. Only OFF events and brightness information are sent.
  • "filterBrightness100" - only Brightness=100% is filtered out. Everything else is sent unchanged. This allows custom logic for soft launch in devices.
  • "filterOnExceptBrightness100" - ON events are filtered out in all cases except for brightness = 100%.
Dimmer dimmer_light_1   "Dimmer Light 1"     {homekit="Lighting, Lighting.Brightness" [dimmerMode="filterOn"]}
Dimmer dimmer_light_2   "Dimmer Light 2"     {homekit="Lighting, Lighting.Brightness" [dimmerMode="filterBrightness100"]}
Dimmer dimmer_light_3   "Dimmer Light 3"     {homekit="Lighting, Lighting.Brightness" [dimmerMode="filterOnExceptBrightness100"]}
# Color Temperature
Color temperature can be represented various ways in openHAB. Given the base bulb configured like this:
Group gLight "CCT Light" { homekit="Lighting" }
Switch light_switch (gLight) { homekit="Lighting.OnState" }
The color temperature might be configured in any of these ways:
// Number item presumed in mireds
Number light_temp (gLight) { homekit="Lighting.ColorTemperature" }
// Number item explicitly in mireds
Number:Temperature light_temp "Temp [%.0f mired]" { homekit="Lighting.ColorTemperature" }
// Number item explicitly in Kelvin
Number:Temperature light_temp "Temp [%.0f K]" { homekit="Lighting.ColorTemperature" }
// Dimmer item, with allowed range given in mireds
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue=50, maxValue=400 ]}
// Dimmer item, with allowed range given in Kelvin
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue="2700 K", maxValue="5000 K" ]}
// Dimmer item, where 0% represents "warm" instead of "cool" (i.e. if it's backed by a channel
// that's ultimately interpreting the value in Kelvin instead of mireds)
Dimmer light_temp { homekit="Lighting.ColorTemperature"[ minValue="2700 K", maxValue="5000 K", inverted=true ]}
# Television
HomeKit Televisions are represented as a complex accessory with multiple associated services. The base service is a Television. Then you need to add one or more InputSource services to describe the possible inputs. Finally you can add a TelevisionSpeaker to have control of the audio. A minimal example relying on multiple defaults with a single input, and no speaker:
Group gTelevision "Television" { homekit="Television" }
Switch Television_Switch "Power" (gTelevision) { homekit="Television.Active" }
Group gInput1 "Input 1" (gTelevision) { homekit="InputSource" }
Or, you can go nuts, and fill out many of the optional characteristics, to fully customize your TV:
String Television_Name "Name" (gTelevision) { homekit="Television.ConfiguredName" }
Number Television_CurrentInput "Current Input" (gTelevision) { homekit="Television.ActiveIdentifier" }
String Television_RemoteKey "Remote Key" (gTelevision) { homekit="Television.RemoteKey" }
Switch Television_SleepDiscoveryMode "Sleep Discovery Mode" (gTelevision) { homekit="Television.SleepDiscoveryMode" }
Dimmer Television_Brightness "Brightness" (gTelevision) { homekit="Television.Brightness" }
Switch Television_PowerMode "Power Mode" (gTelevision) { homekit="Television.PowerMode" }
Switch Television_ClosedCaptions "Closed Captions" (gTelevision) { homekit="Television.ClosedCaptions" }
String Television_CurrentMediaState "Current Media State" (gTelevision) { homekit="Television.CurrentMediaState" }
String Television_TargetMediaState "Target Media State" (gTelevision) { homekit="Television.TargetMediaState" }
String Television_PictureMode "Picture Mode" (gTelevision) { homekit="Television.PictureMode" }
Switch Input1_Visible "Visibility" (gInput1) { homekit="InputSource.CurrentVisibility" }
Switch Input1_TargetVisibility "Target Visibility" (gInput1) { homekit="InputSource.TargetVisibilityState" }
Group gInput2 "Input 2" (gTelevision) { homekit="InputSource"[Identifier=2, InputDeviceType="AUDIO_SYSTEM", InputSourceType="HDMI"] }
String Input2_Name "Name" (gInput2) { homekit="InputSource.ConfiguredName" }
Switch Input2_Configured "Configured" (gInput2) { homekit="InputSource.Configured" }
Switch Input2_Visible "Visibility" (gInput2) { homekit="InputSource.CurrentVisibility" }
Switch Input2_TargetVisibility "Target Visibility" (gInput2) { homekit="InputSource.TargetVisibilityState" }
Group gTelevisionSpeaker "Speaker" (gTelevision) { homekit="TelevisionSpeaker" }
Switch Television_Mute "Mute" (gTelevisionSpeaker) { homekit="TelevisionSpeaker.Mute" }
Switch Television_SpeakerActive "Speaker Active" (gTelevisionSpeaker) { homekit="TelevisionSpeaker.Active" }
Dimmer Television_Volume "Volume" (gTelevisionSpeaker) { homekit="TelevisionSpeaker.Volume,TelevisionSpeaker.VolumeSelector" }
Note that seemingly most of these characteristics are not accessible from the Home app. At the very least, you should be able to edit names, control main power, switch inputs, alter input visibility, and be notified when the user wants to open the TV's menu.
# Window Covering (Blinds) / Window / Door
HomeKit Window Covering, Window, and Door accessory types have the following mandatory characteristics:
  • CurrentPosition (0-100% of current window covering position)
  • TargetPosition (0-100% of target position)
  • PositionState (DECREASING, INCREASING, or STOPPED as state). If no state is provided, HomeKit will send STOPPED.
These characteristics can be mapped to a single openHAB rollershutter item. In such a case, currentPosition will always equal target position, meaning if you request to close a blind/window/door, HomeKit will immediately report that the blind/window/door is closed. As discussed above, one can use full or shorthand definition. The following two definitions are equal:
Rollershutter    window                "Window"                    {homekit = "Window"}
Rollershutter    door                  "Door"                      {homekit = "Door"}
Rollershutter   window_covering        "Window Rollershutter"      {homekit = "WindowCovering"}
Rollershutter    window_covering_long  "Window Rollershutter long" {homekit = "WindowCovering, WindowCovering.CurrentPosition, WindowCovering.TargetPosition, WindowCovering.PositionState"}
  • OPEN if position is 0%
  • CLOSED if position is 100%
In contrast, HomeKit window covering/door/window have inverted mapping:
  • OPEN if position is 100%
  • CLOSED if position is 0%
Therefore, the HomeKit integration inverts by default the values between openHAB and HomeKit, e.g., if the openHAB current position is 30%, then it will send 70% to the HomeKit app. In case you need to disable this logic, you can do it with the configuration parameter inverted=false, e.g.:
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering"  [inverted=false]}
Rollershutter window          "Window"               {homekit = "Window" [inverted=false]}
Rollershutter door            "Door"                 {homekit = "Door" [inverted=false]}
The HomeKit Home app never sends "STOP" but only the target position. If you add the configuration parameter "stop=true", openHAB will emulate stop and send the "STOP" command to the rollershutter item if you click on the blind icon in the iOS Home app while the blind is moving.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering"  [stop=true]}
Some blinds devices do support the "STOP" command but would stop if they receive UP/DOWN while moving in the same direction. In order to support such devices, add the "stopSameDirection" parameter.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering"  [stop=true, stopSameDirection=true]}
Some blinds devices do not support going to a specific position, even though they are modeled as Rollershutter items. The Home app only sends exact percentages by default. To avoid creating a rule, you can have the HomeKit add-on translate 0%/100% to UP/DOWN commands.
Rollershutter window_covering "Window Rollershutter" {homekit = "WindowCovering" [sendUpDownForExtents=true]}
Window covering can have a number of optional characteristics like horizontal & vertical tilt, obstruction status, and hold position trigger. If your blind supports tilt and you want to control tilt via HomeKit, you need to define the blind as a group. E.g.:
Group           gBlind                  "Blind with tilt"                               {homekit = "WindowCovering"}
Rollershutter   window_covering         "Blind"                         (gBlind)        {homekit = "CurrentPosition, TargetPosition, PositionState"}
Dimmer          window_covering_htilt   "Blind horizontal tilt"         (gBlind)        {homekit = "CurrentHorizontalTiltAngle, TargetHorizontalTiltAngle"}
Dimmer          window_covering_vtilt   "Blind vertical tilt"           (gBlind)        {homekit = "CurrentVerticalTiltAngle, TargetVerticalTiltAngle"}
Current and Target Position characteristics can be linked to Rollershutter but also to Number or Dimmer item types. E.g.:
Group           gBlind   "Blinds"                        {homekit = "WindowCovering"}
Dimmer          blind_current_position    (gBlind)       {homekit = "CurrentPosition"}
Number          blind_target_position     (gBlind)       {homekit = "TargetPosition"}
String          blind_position            (gBlind)       {homekit = "PositionState"}
# Thermostat
A HomeKit thermostat has the following mandatory characteristics:
  • CurrentTemperature
  • TargetTemperature
  • CurrentHeatingCoolingMode
  • TargetHeatingCoolingMode
In order to define a thermostat, you need to create a group with at least these 4 items. Example:
Group           gThermostat                "Thermostat"                                             {homekit = "Thermostat"}
Number          thermostat_current_temp    "Thermostat Current Temp [%.1f °C]"  (gThermostat)       {homekit = "CurrentTemperature"}
Number          thermostat_target_temp     "Thermostat Target Temp [%.1f °C]"   (gThermostat)       {homekit = "TargetTemperature"}
String          thermostat_current_mode    "Thermostat Current Mode"            (gThermostat)       {homekit = "CurrentHeatingCoolingMode"}
String          thermostat_target_mode     "Thermostat Target Mode"             (gThermostat)       {homekit = "TargetHeatingCoolingMode"}
In addition, thermostat can have thresholds for cooling and heating modes. When a thermostat is configured with all three of TargetTemperature, HeatingThresholdTemperature, and CoolingThresholdTemperature, Home will set the characteristics as follows:
  • TargetTemperature is used when the thermostat is in HEAT or COOL TargetHeatingCoolingMode.
  • CoolingThresholdThemperature and HeatingThresholdTemperature are only used in AUTO TargetHeatingCoolingMode.
  • In AUTO TargetHeatingCoolingMode, TargetTemperature will be set to the average of CoolingThresholdThemperature and HeatingThresholdTemperature.
Example with thresholds:
Number          thermostat_target_temp     "Thermostat Target Temp[%.1f °C]"          (gThermostat) {homekit = "TargetTemperature"}
Number          thermostat_cool_thrs       "Thermostat Cool Threshold Temp [%.1f °C]" (gThermostat) {homekit = "CoolingThresholdTemperature"}
Number          thermostat_heat_thrs       "Thermostat Heat Threshold Temp [%.1f °C]" (gThermostat) {homekit = "HeatingThresholdTemperature"}
If your thermostat simply has a heating set point and cooling set point, and uses those points regardless of HEAT, COOL, or AUTO mode, you may simply omit the TargetTemperature characteristic, and the add-on will dynamically route to those characteristics as appropriate:
# Min/Max Temperatures
Current and target temperatures have default min and max values. Any values below or above the max limits will be replaced with min or max limits. The default limits are:
  • current temperature: min value = 0 °C, max value = 100 °C
  • target temperature: min value = 10 °C, max value = 38 °C
You can overwrite default values using minValue and maxValue configuration at the item level, e.g.:
Number          thermostat_current_temp    "Thermostat Current Temp [%.1f °C]"     (gThermostat)       {homekit = "CurrentTemperature" [minValue=5, maxValue=30]}
Number          thermostat_target_temp     "Thermostat Target Temp[%.1f °C]"       (gThermostat)       {homekit = "TargetTemperature" [minValue=10.5, maxValue=27]}
# Thermostat Modes
The HomeKit thermostat accessory supports the following modes:
  • CurrentHeatingCoolingMode: OFF, HEAT, COOL
  • TargetHeatingCoolingMode: OFF, HEAT, COOL, AUTO
These modes are mapped to string values of openHAB items using configuration at the item level. E.g., if your current mode item can have the following values: "OFF", "HEATING", "COOLING", then you need the following mapping at the item level:
String          thermostat_current_mode     "Thermostat Current Mode" (gThermostat) {homekit = "CurrentHeatingCoolingMode" [OFF="OFF", HEAT="HEATING", COOL="COOLING"]}
You can provide mapping for target mode in a similar way.
The custom mapping can also be used to reduce the number of modes shown in the Home app. The modes can only be reduced, but not added, i.e., it is not possible to add a new custom mode to the HomeKit thermostat.
Example: if your thermostat does not support cooling, then you need to limit the mapping to OFF and HEAT values only:
String          thermostat_current_mode    "Thermostat Current Mode"            (gThermostat) {homekit = "CurrentHeatingCoolingMode" [HEAT="HEATING", OFF="OFF"]}
String          thermostat_target_mode     "Thermostat Target Mode"             (gThermostat) {homekit = "TargetHeatingCoolingMode" [HEAT="HEATING", OFF="OFF"]}
The mapping using Main UI looks like the following:
# Valve
The HomeKit valve accessory supports the following 2 optional characteristics:
  • duration: this describes how long the valve should be set to "InUse" once it is activated. The duration changes will apply to the next operation. If the valve is already active, then duration changes have no effect.
  • remaining duration: this describes the remaining duration on the valve. Notifications on this characteristic must only be used if the remaining duration increases/decreases from the accessory's usual countdown of remaining duration.
Upon valve activation in the Home app, the Home app starts to count down from the "duration" to "0" without contacting the server. The Home app also does not trigger any action if the remaining duration reaches 0. It is up to the valve to have its own timer and stop the valve once the timer is over. Some valves have such a timer, e.g., it is pretty common for sprinklers. In case the valve has no timer capability, openHAB can take care of this - start an internal timer and send an "Off" command to the valve once the timer is over.
The configuration for these two cases looks as follows:
  • valve with timer:
Group           gValve                   "Valve Group"                             {homekit="Valve"  [ValveType="Irrigation"]}
Switch          valve_active             "Valve active"             (gValve)       {homekit = "Valve.ActiveStatus, Valve.InUseStatus"}
Number          valve_duration           "Valve duration"           (gValve)       {homekit = "Valve.Duration"}
Number          valve_remaining_duration "Valve remaining duration" (gValve)       {homekit = "Valve.RemainingDuration"}
  • valve without timer (no item for remaining duration required)
Group           gValve             "Valve Group"                             {homekit="Valve"  [ValveType="Irrigation", homekitTimer="true"]}
Number          valve_duration     "Valve duration"             (gValve)     {homekit = "Valve.Duration" [homekitDefaultDuration = 1800]}
# Irrigation System
An irrigation system is an accessory composed of multiple valves. You just need to link multiple valves within an irrigation system's group. When part of an irrigation system, valves are required to have Duration and RemainingDuration characteristics, as well as a ServiceIndex. The valve's types will also automatically be set to IRRIGATION.
Group gIrrigationSystem "Irrigation System" { homekit="IrrigationSystem" }
String irrigationSystemProgramMode (gIrrigationSystem) { homekit="ProgramMode" }
Switch irrigationSystemEnabled (gIrrigationSystem) { homekit="Active" }
Switch irrigationSystemInUse (gIrrigationSystem) { homekit="InUseStatus" }
Group irrigationSystemTotalRemaining (gIrrigationSystem) { homekit="RemainingDuration" }
Group gValve1 "Valve 1" (gIrrigationSystem) { homekit="Valve"[ServiceIndex=1] }
Switch valve1Active (gValve1) { homekit="ActiveStatus" }
Switch valve1InUse (gValve1) { homekit="InUseStatus" }
Number valve1SetDuration (gValve1) { homekit="Duration" }
Number valve1RemainingDuration (gValve1) { homekit="RemainingDuration" }
Group gValve2 "Valve 2" (gIrrigationSystem) { homekit="Valve"[ServiceIndex=2] }
Switch valve2Active (gValve2) { homekit="ActiveStatus" }
Switch valve2InUse (gValve2) { homekit="InUseStatus" }
Number valve2SetDuration (gValve2) { homekit="Duration" }
Number valve2RemainingDuration (gValve2) { homekit="RemainingDuration" }
# Air Purifier
You can attach a filter maintenance service to an air purifier. The filter service will be linked under the air purifier in HomeKit:
Group  gPurifier                "Living Room Purifier"              { homekit="AirPurifier"}
Switch purifierActive           "Purifier Active"       (gPurifier) { homekit="Active" }
String purifierCurrentState     "Purifier State"        (gPurifier) { homekit="CurrentAirPurifierState" }
String purifierTargetState      "Purifier Mode"         (gPurifier) { homekit="TargetAirPurifierState" }
Group gFilter                                           (gPurifier) { homekit="Filter" }
Switch purifierFilterChange     "Filter Change Needed"  (gFilter)   { homekit="FilterChangeIndication" }
# Sensors
Sensors typically have one mandatory characteristic, e.g., temperature or leak trigger, and several optional characteristics which are typically used for battery-powered sensors and/or wireless sensors. The following table summarizes the optional characteristics supported by sensors.
Characteristics Supported openHAB items Description
Name String Name of the sensor. This characteristic is interesting only for very specific cases in which the name of the accessory is dynamic. If you are not sure, then you don't need it.
ActiveStatus Switch, Contact Accessory current working status. "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors.
FaultStatus Switch, Contact Accessory fault status. "ON"/"OPEN" value indicates that the accessory has experienced a fault that may be interfering with its intended functionality. A value of "OFF"/"CLOSED" indicates that there is no fault.
TamperedStatus Switch, Contact Accessory tampered status. "ON"/"OPEN" indicates that the accessory has been tampered with. Value should return to "OFF"/"CLOSED" when the accessory has been reset to a non-tampered state.
BatteryLowStatus Switch, Contact, Number Accessory battery status. "ON"/"OPEN" indicates that the battery level of the accessory is low. Value should return to "OFF"/"CLOSED" when the battery charges to a level that's above the low threshold. Alternatively, you can give a Number item that's the battery level, and if it's lower than the lowThreshold configuration, it will report low.
Switch and Contact items support inversion of the state mapping, e.g., by default the openHAB switch state "ON" is mapped to HomeKit contact sensor state "Open", and "OFF" to "Closed". The configuration "inverted=true" inverts this mapping so that "ON" will be mapped to "Closed" and "OFF" to "Open".
Examples of sensor definitions:
Sensors without optional characteristics:
Switch  leaksensor_single    "Leak Sensor"                   {homekit="LeakSensor"}
Number  light_sensor         "Light Sensor"                  {homekit="LightSensor"}
Number  temperature_sensor   "Temperature Sensor [%.1f °C]"  {homekit="TemperatureSensor"}
Contact contact_sensor       "Contact Sensor"                {homekit="ContactSensor"}
Contact contact_sensor       "Contact Sensor"                {homekit="ContactSensor" [inverted=true]}
Switch  occupancy_sensor     "Occupancy Sensor"              {homekit="OccupancyDetectedState"}
Switch  motion_sensor        "Motion Sensor"                 {homekit="MotionSensor"}
Number  humidity_sensor      "Humidity Sensor"               {homekit="HumiditySensor"}
Group           gLeakSensor                "Leak Sensor"                                             {homekit="LeakSensor"}
Switch          leaksensor                 "Leak Sensor State"                  (gLeakSensor)        {homekit="LeakDetectedState"}
Switch          leaksensor_bat             "Leak Sensor Battery"                (gLeakSensor)        {homekit="BatteryLowStatus" }
Switch          leaksensor_active          "Leak Sensor Active"                 (gLeakSensor)        {homekit="ActiveStatus" [inverted=true]}
Switch          leaksensor_fault           "Leak Sensor Fault"                  (gLeakSensor)        {homekit="FaultStatus"}
Switch          leaksensor_tampered        "Leak Sensor Tampered"               (gLeakSensor)        {homekit="TamperedStatus"}
Group           gMotionSensor              "Motion Sensor"                                           {homekit="MotionSensor"}
Switch          motionsensor               "Motion Sensor State"                (gMotionSensor)      {homekit="MotionDetectedState"}
Switch          motionsensor_bat           "Motion Sensor Battery"              (gMotionSensor)      {homekit="BatteryLowStatus" [inverted=true]}
Switch          motionsensor_active        "Motion Sensor Active"               (gMotionSensor)      {homekit="ActiveStatus"}
Switch          motionsensor_fault         "Motion Sensor Fault"                (gMotionSensor)      {homekit="FaultStatus"}
Switch          motionsensor_tampered      "Motion Sensor Tampered"             (gMotionSensor)      {homekit="TamperedStatus"}
or using UI
# Stateless Programmable Switch Groups
To expose multiple Stateless Programmable Switches as a single accessory with multiple buttons (a.k.a. a scene controller), you need to configure ServiceLabel on the accessory group and ServiceIndex on each switch. Note that in the Home app, the individual switch names will be ignored and will simply be displayed as "Button 1", "Button 2", etc. (for ARABIC_NUMERALS style).
Group gSceneController "Scene Controller" { homekit="AccessoryGroup"[ServiceLabel="ARABIC_NUMERALS"] }
Switch Button1 "Switch A" (gSceneController) { homekit="StatelessProgrammableSwitch"[ServiceIndex=1] }
Switch Button2 "Switch B" (gSceneController) { homekit="StatelessProgrammableSwitch"[ServiceIndex=2] }
Switch Button3 "Switch C" (gSceneController) { homekit="StatelessProgrammableSwitch"[ServiceIndex=3] }
Switch Button4 "Switch D" (gSceneController) { homekit="StatelessProgrammableSwitch"[ServiceIndex=4] }
# Supported Accessory Types
For configuration options, the default values are in parentheses. For enum values, the parentheses indicate the default values if the item is a Number or a Switch. All enum values can be customized via item metadata, i.e., HEAT="heating", COOL="cooling", or HEAT=5, COOL=7 for a Number. Some enums can have the list of valid values customized, meaning that if you customize the mapping, any value that is missing will not be presented to the user. They are appropriately marked. Enums that are linked to Switches or Contacts have an inverted parameter that will reverse the sense of ON/OFF or OPEN/CLOSED.
Enum mappings can have multiple values for a single key. These must be an array, not a comma-separated string. If the characteristic can be set by HomeKit, the first value will be used when sending the command to the linked item. Such a mapping can be configured manually in Main UI on HomeKit metadata in the Code editor:
value: "Lock"
  SECURE:
    - LOCK
    - LOCKED
  UNSECURE:
    - UNLOCK
    - UNLOCKED
Or in a .items file:
String MyLock "My Lock" { homekit="Lock"[SECURE="LOCK","LOCKED", UNSECURE="UNLOCK","UNLOCKED"] }
All accessories support the following characteristics that can be set via metadata or linked to a String item:
  • Name (defaults to item's label)
  • Manufacturer (defaults to "none")
  • Model (defaults to "none")
  • SerialNumber (defaults to item's name)
  • FirmwareRevision (defaults to "none")
  • HardwareRevision (defaults to not present)
Note that even though these characteristics can be linked to an item, they are not dynamic and cannot be updated once the Home app reads their initial values.
All accessories also support the following optional characteristic that can be linked to a Switch item:
  • Identify (receives ON command when the user wishes to identify the accessory)
Accessory Tag Mandatory Characteristics Optional Characteristics Supported openHAB item types Description Configuration Options Valid Enum Values
AirPurifier Air purifier
Active Contact, Dimmer, Number, String, Switch Accessory current working status inverted (false) INACTIVE (0, OFF), ACTIVE (1, ON)
CurrentAirPurifierState Number, String Current air purifier state INACTIVE (0), IDLE (1), PURIFYING_AIR (2)
TargetAirPurifierState Number, Switch, String Target air purifier state inverted (false) MANUAL (0, OFF), AUTO (1, ON)
LockControl Number, Switch, String Status of physical control lock inverted (false) CONTROL_LOCK_DISABLED (0, OFF), CONTROL_LOCK_ENABLED (1, ON)
RotationSpeed Dimmer, Number Fan rotation speed in % (1-100)
SwingMode Number, Switch, String Swing mode inverted (false) SWING_DISABLED (0, OFF), SWING_ENABLED (1, ON)
AirQualitySensor Air Quality Sensor which can measure different parameters
AirQuality Number, String, Switch Air quality state UNKNOWN (0, OFF), EXCELLENT (1, ON), GOOD (2), FAIR (3), INFERIOR (4), POOR (5)
ActiveStatus Contact, Switch Working status
BatteryLowStatus Contact, Number, Switch Battery status inverted (false), lowThreshold (20)
FaultStatus Contact, Number, String, Switch Fault status inverted (false) NO_FAULT (0, OFF, CLOSED), GENERAL_FAULT (1, ON, OPEN)
NitrogenDioxideDensity Number NO2 density in micrograms/m3, max 1000
OzoneDensity Number Ozone density in micrograms/m3, max 1000
PM10Density Number PM10 micrometer particulate density in micrograms/m3, max 1000
PM25Density Number PM2.5 micrometer particulate density in micrograms/m3, max 1000
SulphurDioxideDensity Number SO2 density in micrograms/m3, max 1000
TamperedStatus Contact, Number, String, Switch Tampered status inverted (false) NOT_TAMPERED (0, OFF, CLOSED), TAMPERED (1, ON, OPEN)
VOCDensity Number VOC Density in micrograms/m3, default max 1000 minValue (0), maxValue (100), step (1)
BasicFan Fan. A BasicFan is a subset of Fan, but the Home app allows you to customize the icon of the accessory to show a ceiling fan.
OnState Dimmer, Switch Accessory current working status. A value of "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors. inverted (false)
RotationDirection Number, Switch Rotation direction. inverted (false) CLOCKWISE (0, OFF), COUNTER_CLOCKWISE (1, ON)
Battery Accessory with battery. Battery can be chargeable (configuration chargeable:true) and non-chargeable (configuration chargeable:false)
BatteryLevel Number Battery level 0% to 100%
BatteryChargingState Contact, Dimmer, Switch Mandatory only for chargeable battery. ON/OPEN = battery is charging
BatteryLowStatus Contact, Number, Switch Battery low indicator. ON/OPEN = battery level is low; for number if the value is below the lowThreshold, then it is low. Default is 20. inverted (false), lowThreshold (20)
CarbonDioxideSensor Carbon Dioxide Sensor
CarbonDioxideDetectedState Contact, Dimmer, Switch, Number, String carbon dioxide sensor state inverted (false) NORMAL (0, OFF, CLOSED), ABNORMAL (1, ON, OPEN)
CarbonDioxideLevel Number Carbon dioxide level in ppm, max 100000
CarbonDioxidePeakLevel Number highest detected level (ppm) of carbon dioxide detected by a sensor, max 100000
CarbonMonoxideSensor Carbon monoxide Sensor
CarbonMonoxideDetectedState Contact, Dimmer, Switch, Number, String Carbon monoxide sensor state inverted (false) NORMAL (0, OFF, CLOSED), ABNORMAL (1, ON, OPEN)
CarbonMonoxideLevel Number Carbon monoxide level in ppm, max 100
CarbonMonoxidePeakLevel Number highest detected level (ppm) of carbon monoxide detected by a sensor, max 100
ContactSensor Contact Sensor, An accessory with on/off state that can be viewed in HomeKit but not changed such as a contact sensor for a door or window
ContactSensorState Contact, Dimmer, Number, String, Switch Contact sensor state inverted (false) DETECTED (0, OFF, CLOSED), NOT_DETECTED (1, ON, OPEN)
Door Motorized door. One Rollershutter item covers all mandatory characteristics. see examples below.
CurrentPosition Dimmer, Number, Rollershutter Current position of motorized door
PositionState Number, Rollershutter, String Position state. If no state is provided, "STOPPED" is used. DECREASING (0), INCREASING (1), STOPPED (2)
TargetPosition Dimmer, Number, Rollershutter Target position of motorized door
HoldPosition Rollershutter, Switch Motorized door should stop at its current position. ON is sent to Switch items. STOP is sent to Rollershutter items. Only supported by 3rd party Home apps (such as Elgato Eve)
ObstructionStatus Contact, Dimmer, Switch Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction
Doorbell Doorbell. This accessory must also have a Speaker, Microphone, and Camera RTP Stream Management service in the same group in order to be usable by the Home App. The latter is not yet implemented in openHAB.
ProgrammableSwitchEvent Contact, Number, String, Switch The button press event. Note that the event will be forwarded to Home for every update of the item, not just on change. inverted (false) SINGLE_PRESS (0, ON, OPEN), DOUBLE_PRESS (1), LONG_PRESS (2) *
Brightness Dimmer Brightness in % (1-100).
Volume Number Speaker volume from 0% to 100%
Fan Fan
ActiveStatus Dimmer, Switch Accessory current working status. A value of "ON"/"OPEN" indicates that the accessory is active and is functioning without any errors.
CurrentFanState Number, String Current fan state. INACTIVE (0), IDLE (1), BLOWING_AIR (2)
RotationDirection Number, Switch, String Rotation direction inverted (false) CLOCKWISE (0, OFF), COUNTER_CLOCKWISE (1, ON)
TargetFanState Number, Switch, String Target fan state inverted (false) MANUAL (0, OFF), AUTO (1, ON)
Faucet Faucet or shower. It should be used in combination with Valve or/and HeaterCooler.
Active Contact, Dimmer, Switch Accessory current working status inverted (false)
Filter Accessory with filter maintenance indicator
FilterChangeIndication Contact, Dimmer, Number, String, Switch Filter change indicator inverted (false) NO_CHANGED_NEEDED (0, OFF, CLOSED), CHANGE_NEEDED (1, ON, OPEN)
FilterLifeLevel Number Current filter life level. 0% to 100%
FilterResetIndication Switch Send "filter reset" action triggered by user in iOS Home app to openHAB ("ON" = reset requested by user).
GarageDoorOpener A garage door opener.
CurrentDoorState Contact, Number, Rollershutter, String, Switch Current door state. inverted (false) OPEN (0, ON, OPEN), CLOSED (1, OFF, CLOSED), OPENING (2), CLOSING (3), STOPPED (4)
TargetDoorState Contact, Number, Rollershutter, String, Switch Target door state. inverted (false) OPEN (0, ON, OPEN), CLOSED (1, OFF, CLOSED)
LockCurrentState Contact, Number, String, Switch Current state of lock mechanism inverted (false) UNSECURED (0, OFF, CLOSED), SECURED (1, ON, OPEN), JAMMED (2), UNKNOWN (3)
LockTargetState Number, String, Switch Target state of lock mechanism inverted (false) UNSECURED (0, OFF), SECURED (1, ON)
ObstructionStatus Contact, Switch Current status of obstruction sensor. ON-obstruction detected, OFF - no obstruction inverted (false)
HeaterCooler Heater or/and cooler device
CurrentHeaterCoolerState Number, String Current heater/cooler mode. INACTIVE (0), IDLE (1), HEATING (2), COOLING (3)
CurrentTemperature Number Current temperature minValue (0), maxValue (100), step (0.1)
TargetHeaterCoolerState Number, String Target heater/cooler mode. AUTO (0, OFF), HEAT (1, ON), COOL (2) *
CoolingThresholdTemperature Number Maximum temperature that must be reached before cooling is turned on minValue (10), maxValue (35), step (0.1)
HeatingThresholdTemperature Number Minimum temperature that must be reached before heating is turned on minValue (0), maxValue (25), step (0.1)
RotationSpeed Number Fan rotation speed in % (1-100)
HumiditySensor Relative Humidity Sensor providing read-only values
RelativeHumidity Number Relative humidity in % between 0 and 100 homekitMultiplicator = {number to multiply result with}
InputSource Input source linked service. Can only be used with Television.
ConfiguredName String Name of the input source configured in the iOS Home app. User can rename the source in iOS Home app and this characteristic can be used to reflect change in openHAB and sync name changes from openHAB to Home app.
Configured Contact, Dimmer, Switch If the source is configured on the device. Non-configured inputs will not show up in the Home app. - ON/OPEN = show, OFF/CLOSED = hide. Default is ON. Can also be configured via metadata, e.g. [Configured=true]
CurrentVisibility Contact, Dimmer, Number, String, Switch If the source has been hidden by the user. Can also be configured via metadata, e.g. [CurrentVisibility=false] inverted (false) SHOWN (0, ON), HIDDEN (1, OFF)
Identifier Number The identifier of the source, to be used with the ActiveIdentifier characteristic. Can also be configured via metadata, e.g. [Identifier=1]
InputDeviceType String Type of the input device. possible values (OTHER, TV, RECORDING, TUNER, PLAYBACK, AUDIO_SYSTEM). Custom mapping can be defined at item level. Can also be configured via metadata, e.g. [InputDeviceType="OTHER"].
InputSourceType String Type of the input source. possible values (OTHER, HOME_SCREEN, TUNER, HDMI, COMPOSITE_VIDEO, S_VIDEO, COMPONENT_VIDEO, DVI, AIRPLAY, USB, APPLICATION). Custom mapping can be defined at item level. Can also be configured via metadata, e.g. [InputSourceType="OTHER"].
TargetVisibilityState Switch, Number, String The desired visibility state of the input source. inverted (false) SHOWN (0, ON), HIDDEN (1, OFF)
IrrigationSystem An accessory that represents multiple water valves and accommodates a programmed scheduled.
Active Contact, Dimmer, Number, String, Switch If the irrigation system as a whole is enabled. This must be ON if any of the valves are also enabled. inverted (false) INACTIVE (0, OFF), ACTIVE (1, ON)
InUseStatus Contact, Dimmer, Number, String, Switch If the irrigation system as a whole is running. This must be ON if any of the valves are ON. inverted (false) NOT_IN_USE (0, OFF, CLOSED), IN_USE (1, ON, OPEN)
ProgramMode String The current program mode of the irrigation system. Possible values (NO_SCHEDULED - no programs scheduled, SCHEDULED - program scheduled, SCHEDULED_MANUAL - program scheduled, currently overriden to manual mode).
RemainingDuration Number The remaining duration for all scheduled valves in the current program in seconds.
LeakSensor Leak Sensor
LeakDetectedState Contact, Dimmer, Number, String, Switch Leak sensor state inverted (false) LEAK_NOT_DETECTED (0, OFF, CLOSED), LEAK_DETECTED (1, ON, OPEN)
LightSensor Light sensor
LightLevel Number Light level in lux minValue (0.0001), maxValue (100000)
Lighting A lightbulb, can have further optional parameters for brightness, hue, etc
OnState Switch State of the light - ON/OFF
Brightness Dimmer, Color Brightness in % (1-100). See "Usage of dimmer modes" for configuration details.
ColorTemperature Dimmer, Number Color temperature. If the item is a Number with no units, it is represented in mireds. The default value range is from 50 to 400 (2500 K to 20,000 K). If the item is a Dimmer, it will be transformed linearly to mireds. Color temperature should not be used in combination with hue, saturation and brightness. minValue (50), maxValue (400), inverted
Hue Dimmer, Color Hue
Saturation Dimmer, Color Saturation in % (1-100)
Lock A Lock Mechanism inverted (false)
Microphone Microphone accessory
Mute Contact, Dimmer, Switch Mute indication. ON/OPEN = microphone is muted inverted (false)
Volume Number Microphone volume from 0% to 100%
MotionSensor Motion Sensor
MotionDetectedState Contact, Dimmer, Switch Motion sensor state (ON=motion detected, OFF=no motion) inverted (false)
OccupancySensor Occupancy Sensor
OccupancyDetectedState Contact, Dimmer, Number, String, Switch Occupancy sensor state inverted (false) NOT_DETECTED (0, OFF, CLOSED), DETECTED (1, ON, OPEN)
Outlet An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps
InUseStatus Contact, Dimmer, Switch Indicates whether the outlet has an appliance e.g., a floor lamp, physically plugged in. This characteristic is set to True even if the plugged-in appliance is off. inverted (false)
OnState Dimmer, Switch State of the outlet - ON/OFF
SecuritySystem Security system.
CurrentSecuritySystemState Number, String Current state of the security system STAY_ARM (0), AWAY_ARM (1), NIGHT_ARM (2), DISARMED (3), TRIGGERED (4)
TargetSecuritySystemState Number, String Requested state of the security system. While the requested state is not DISARM, and the current state is DISARMED, HomeKit will display "Arming...", for example during an exit delay. STAY_ARM (0), AWAY_ARM (1), NIGHT_ARM (2), DISARM (3) *
Slat Slat which tilts on a vertical or a horizontal axis. Configuration "type:horizontal" or "type:vertical"
CurrentSlatState Number, String Current slat state. FIXED (0), JAMMED (1), SWINGING (2)
CurrentTiltAngle Dimmer, Number Number Item = current angle of slats. values -90 to 90. A value of 0 indicates that the slats are rotated to a fully open position. Dimmer Item = the percentage of openness (0%-100%)
TargetTiltAngle Dimmer, Number Number Item = target angle of slats (-90 to +90). Dimmer Item = the percentage of openness (0%-100%)
SmartSpeaker Smart speaker accessory with Play/Stop/Pause control
CurrentMediaState Number, String Current smart speaker state PLAY (0), PAUSE (1), STOP (2), UNKNOWN (3)
TargetMediaState Number, String Target smart speaker state PLAY (0), PAUSE (1), STOP (2)
ConfiguredName String Name of the speaker accessory configured in iOS Home app. User can rename the speaker in iOS Home app and this characteristic can be used to reflect change in openHAB and sync name changes from openHAB to Home app.
Mute Contact, Switch Mute indication. ON/OPEN = speaker is muted inverted (false)
SmokeSensor Smoke Sensor
SmokeDetectedState Contact, Dimmer, Number, String, Switch Smoke sensor state inverted (false) NOT_DETECTED (0, OFF, CLOSED), DETECTED (1, ON, OPEN)
Speaker Speaker accessory
Mute Contact, Dimmer, Switch Mute indication. ON/OPEN = speaker is muted inverted (false)
StatelessProgrammableSwitch A stateless programmable switch is a button or scene controller that simply sends an event to Home when it is pressed, allowing automations to occur. See Stateless Programmable Switch Groups for configuring multiple in one accessory.
Switchable An accessory that can be turned off and on. While similar to a lightbulb, this will be presented differently in the Siri grammar and iOS apps
OnState Dimmer, Switch State of the switch - ON/OFF
Television Television accessory with inputs
Active Contact, Dimmer, Number, String, Switch State of the television (on/off) inverted (false) INACTIVE (0, OFF), ACTIVE (1, ON)
ActiveIdentifier Number The input that is currently active (based on its identifier). Can also be configured via metadata, e.g. [ActiveIdentifier=1]
Brightness Dimmer Screen brightness in % (1-100).
ClosedCaptions Contact, Dimmer, Number, String, Switch Indicates closed captions are enabled. Can also be configured via metadata, e.g. [ClosedCaptions=true] inverted (false) DISABLED (0, OFF), ENABLED (1, ON)
ConfiguredName String Name of the television accessory configured in the iOS Home app. User can rename the television in iOS Home app and this characteristic can be used to reflect change in openHAB and sync name changes from openHAB to Home app.
CurrentMediaState Number, String Current television state. PLAY (0), PAUSE (1), STOP (2), UNKNOWN (3)
PictureMode Number, String Selected picture mode. OTHER (0), STANDARD (1), CALIBRATED (2), CALIBRATED_DARK (3), VIVID (4), GAME (5), COMPUTER (6), CUSTOM (7)
PowerMode Switch, Number, String This oddly named characteristic will receive an ON command when the user requests to open the TV's menu. inverted (false) SHOW (0, ON), HIDE (1, OFF)
RemoteKey String Receives a keypress event.
SleepDiscoveryMode Contact, Dimmer, Number, String, Switch Indicates if the television is discoverable while in standby mode. Can also be configured via metadata, e.g. [SleepDiscoveryMode=true] inverted (false) NOT_DISCOVERABLE (0, OFF), ALWAYS_DISCOVERABLE (1, ON)
TargetMediaState Number, String Target television state. PLAY (0), PAUSE (1), STOP (2)
TelevisionSpeaker An accessory that can be added to a Television in order to control the speaker associated with it.
Mute Switch If the television is muted. ON = muted, OFF = not muted.
Active Contact, Dimmer, Number, String, Switch Unknown. This characteristic is undocumented by Apple, but is still available. inverted (false) INACTIVE (0, OFF), ACTIVE (1, ON)
Volume Dimmer, Number Current volume.
VolumeControlType String The type of control available. This will default to infer based on what other items are linked. NONE = status only, no control; RELATIVE = INCREMENT/DECREMENT only, no status; RELATIVE_WITH_CURRENT = INCREMENT/DECREMENT only with status; ABSOLUTE = direct status and control. Can also be configured via metadata, e.g. [VolumeControlType="ABSOLUTE"].
VolumeSelector Dimmer, String If linked to a dimmer item, will send INCREASE/DECREASE commands. If linked to a string item, will send INCREMENT and DECREMENT.
TemperatureSensor Temperature sensor
CurrentTemperature Number current temperature minValue (0), maxValue (100), step (0.1)
Thermostat A thermostat requires at least one of TargetTemperature, CoolingThresholdTemperature, or HeatingThresholdTemperature must be provided.
CurrentTemperature Number Current temperature. minValue (0), maxValue (100), step (0.1)
TargetHeatingCoolingMode Number, String, Switch Target heating cooling mode OFF (0, OFF), HEAT (1, ON), COOL (2), AUTO (3) *
CurrentHeatingCoolingMode Number, String, Switch Current heating cooling mode OFF (0, OFF), HEAT (1, ON), COOL (2)
TargetTemperature Number Target temperature. If CoolingThresholdTemperature and HeatingThresholdTemperature are also provided, this characteristic is used when the thermostat is in HEAT or COOL mode. In AUTO mode, this characteristic receives the average of the two thresholds. minValue (10), maxValue (38), step (0.1)
CoolingThresholdTemperature Number Maximum temperature that must be reached before cooling is turned on. If TargetTemperature is not provided, this characteristic will also be used in COOL mode. minValue (10), maxValue (35), step (0.1)
HeatingThresholdTemperature Number Minimum temperature that must be reached before heating is turned on. If TargetTemperature is not provided, this characteristic will also be used in HEAT mode. minValue (0), maxValue (25), step (0.1)
RelativeHumidity Number Relative humidity in % between 0 and 100.
TargetRelativeHumidity Number Target relative humidity in % between 0 and 100.
TemperatureUnit Number, String, Switch The units the accessory itself uses to display the temperature. Can also be configured via metadata, e.g. [TemperatureUnit="CELSIUS"] CELSIUS (0, OFF), FAHRENHEIT (1, ON)
Valve Valve ValveType = ["Generic", "Irrigation", "Shower", "Faucet"] ("Generic")
InUseStatus Contact, Dimmer, Switch Indicates whether fluid flowing through the valve. A value of "ON"/"OPEN" indicates that fluid is flowing. inverted (false)
Duration Number Defines how long a valve should be set to ʼIn Useʼ in second. homekitDefaultDuration = {default duration in seconds}
RemainingDuration Number Describes the remaining duration on the accessory. the remaining duration increases/decreases from the accessoryʼs usual countdown. i.e. changes from 90 to 80 in a second.
Window Motorized window. One Rollershutter item covers all mandatory characteristics. see examples below.
CurrentPosition Dimmer, Number, Rollershutter Current position of motorized window
TargetPosition Dimmer, Number, Rollershutter Target position of motorized window
WindowCovering Window covering / blinds. One Rollershutter item covers all mandatory characteristics. see examples below.
CurrentPosition Dimmer, Number, Rollershutter Current position of window covering
TargetPosition Dimmer, Number, Rollershutter Target position of window covering
CurrentHorizontalTiltAngle Dimmer, Number Number Item = current angle of horizontal slats. values -90 to 90. A value of 0 indicates that the slats are rotated to a fully open position. A value of -90 indicates that the slats are rotated all the way in a direction where the user-facing edge is higher than the window-facing edge. Dimmer Item = the percentage of openness (0%-100%)
CurrentVerticalTiltAngle Dimmer, Number Number Item = current angle of vertical slats (-90 to +90) . Dimmer Item = the percentage of openness (0%-100%)
TargetHorizontalTiltAngle Dimmer, Number Number Item = target angle of horizontal slats (-90 to +90). Dimmer Item = the percentage of openness (0%-100%)
TargetVerticalTiltAngle Dimmer, Number Number Item = target angle of vertical slats. Dimmer Item = the percentage of openness (0%-100%)
Color           color_light_single         "Color Light Single"                                        {homekit="Lighting"}
Color           color_light_dimmable       "Legacy Color Light Dimmable"                               {homekit="Lighting, Lighting.Brightness"}
Color           color_light_hue            "Legacy Color Light Hue"                                    {homekit="Lighting, Lighting.Hue, Lighting.Brightness, Lighting.Saturation"}
Rollershutter   window_covering_long       "Window Rollershutter long"                                 {homekit="WindowCovering, WindowCovering.CurrentPosition, WindowCovering.TargetPosition, WindowCovering.PositionState"}
Switch          leaksensor_single          "Leak Sensor single"                                        {homekit="LeakSensor"}
Switch          lock                       "Lock single"                                               {homekit="Lock"}
Switch          valve_single               "Valve single"                                              {homekit="Valve" [homekitValveType="Shower"]}
Number          temperature_sensor         "Temperature Sensor [%.1f °C]"                              {homekit="TemperatureSensor" [minValue=10.5, maxValue=27] }
Group           gValve                     "Valve Group"                                               {homekit="Valve"  [homekitValveType="Irrigation"]}
Switch          valve_active               "Valve active"                         (gValve)             {homekit="Valve.ActiveStatus, Valve.InUseStatus"}
Number          valve_duration             "Valve duration"                       (gValve)             {homekit="Valve.Duration"}
Number          valve_remaining_duration   "Valve remaining duration"             (gValve)             {homekit="Valve.RemainingDuration"}
Group           gThermostat                "Thermostat"                                                {homekit="Thermostat"}
Number          thermostat_current_temp    "Thermostat Current Temp [%.1f °C]"    (gThermostat)        {homekit="Thermostat.CurrentTemperature" [minValue=0, maxValue=40]}
Number          thermostat_target_temp     "Thermostat Target Temp[%.1f °C]"      (gThermostat)        {homekit="Thermostat.TargetTemperature"  [minValue=10.5, maxValue=27]}
String          thermostat_current_mode    "Thermostat Current Mode"              (gThermostat)        {homekit="Thermostat.CurrentHeatingCoolingMode"}
String          thermostat_target_mode     "Thermostat Target Mode"               (gThermostat)        {homekit="Thermostat.TargetHeatingCoolingMode"}
Switch          leaksensor                 "Leak Sensor"                          (gLeakSensor)        {homekit="LeakDetectedState"}
String          leaksensor_name            "Leak Sensor Name"                     (gLeakSensor)        {homekit="Name"}
Switch          leaksensor_bat             "Leak Sensor Battery"                  (gLeakSensor)        {homekit="BatteryLowStatus"}
Switch          leaksensor_active          "Leak Sensor Active"                   (gLeakSensor)        {homekit="ActiveStatus"}
Group           gMotionSensor              "Motion Sensor Group"                                       {homekit="MotionSensor"}
Switch          motionsensor               "Motion Sensor"                        (gMotionSensor)      {homekit="MotionSensor.MotionDetectedState"}
Switch          motionsensor_bat           "Motion Sensor Battery"                (gMotionSensor)      {homekit="MotionSensor.BatteryLowStatus"}
Switch          motionsensor_active        "Motion Sensor Active"                 (gMotionSensor)      {homekit="MotionSensor.ActiveStatus"}
Switch          motionsensor_fault         "Motion Sensor Fault"                  (gMotionSensor)      {homekit="MotionSensor.FaultStatus"}
Switch          motionsensor_tampered      "Motion Sensor Tampered"               (gMotionSensor)      {homekit="MotionSensor.TamperedStatus"}
Group           gOccupancySensor           "Occupancy Sensor Group"                                    {homekit="OccupancySensor"}
Switch          occupancysensor            "Occupancy Sensor"                     (gOccupancySensor)   {homekit="OccupancyDetectedState"}
Switch          occupancysensor_bat        "Occupancy Sensor Battery"             (gOccupancySensor)   {homekit="BatteryLowStatus"}
Switch          occupancysensor_active     "Occupancy Sensor Active"              (gOccupancySensor)   {homekit="OccupancySensor.ActiveStatus"}
Switch          occupancysensor_fault      "Occupancy Sensor Fault"               (gOccupancySensor)   {homekit="OccupancySensor.FaultStatus"}
Switch          occupancysensor_tampered   "Occupancy Sensor Tampered"            (gOccupancySensor)   {homekit="OccupancySensor.TamperedStatus"}
Group           gContactSensor             "Contact Sensor Group"                                      {homekit="ContactSensor"}
Contact         contactsensor              "Contact Sensor"                       (gContactSensor)     {homekit="ContactSensor.ContactSensorState"}
Switch          contactsensor_bat          "Contact Sensor Battery"               (gContactSensor)     {homekit="ContactSensor.BatteryLowStatus"}
Switch          contactsensor_active       "Contact Sensor Active"                (gContactSensor)     {homekit="ContactSensor.ActiveStatus"}
Switch          contactsensor_fault        "Contact Sensor Fault"                 (gContactSensor)     {homekit="ContactSensor.FaultStatus"}
Switch          contactsensor_tampered     "Contact Sensor Tampered"              (gContactSensor)     {homekit="ContactSensor.TamperedStatus"}
Group           gAirQualitySensor           "Air Quality Sensor"                                       {homekit="AirQualitySensor"}
String          airquality                  "Air Quality"                         (gAirQualitySensor)  {homekit="AirQuality"}
Number          ozone                       "Ozone Density"                       (gAirQualitySensor)  {homekit="OzoneDensity"}
Number          voc                         "VOC Density"                         (gAirQualitySensor)  {homekit="VOCDensity"}
Number          nitrogen                    "Nitrogen Density"                    (gAirQualitySensor)  {homekit="NitrogenDioxideDensity"}
Number          sulphur                     "Sulphur Density"                     (gAirQualitySensor)  {homekit="SulphurDioxideDensity"}
Number          pm25                        "PM25 Density"                        (gAirQualitySensor)  {homekit="PM25Density"}
Number          pm10                        "PM10 Density"                        (gAirQualitySensor)  {homekit="PM10Density"}
Group           gSecuritySystem            "Security System Group"                                     {homekit="SecuritySystem"}
String          security_current_state     "Security Current State"               (gSecuritySystem)    {homekit="SecuritySystem.CurrentSecuritySystemState"}
String          security_target_state      "Security Target State"                (gSecuritySystem)    {homekit="SecuritySystem.TargetSecuritySystemState"}
Group           gCooler                    "Cooler Group"                                              {homekit="HeaterCooler"}
Switch          cooler_active              "Cooler Active"                        (gCooler)            {homekit="ActiveStatus"}
Number          cooler_current_temp        "Cooler Current Temp [%.1f °C]"        (gCooler)            {homekit="CurrentTemperature"}
String          cooler_current_mode        "Cooler Current Mode"                  (gCooler)            {homekit="CurrentHeaterCoolerState" [HEATING="HEAT", COOLING="COOL"]}
String          cooler_target_mode         "Cooler Target Mode"                   (gCooler)            {homekit="TargetHeaterCoolerState"}
Number          cooler_cool_thrs           "Cooler Cool Threshold Temp [%.1f °C]" (gCooler)            {homekit="CoolingThresholdTemperature" [minValue=10.5, maxValue=50]}
Number          cooler_heat_thrs           "Cooler Heat Threshold Temp [%.1f °C]" (gCooler)            {homekit="HeatingThresholdTemperature" [minValue=0.5, maxValue=20]}
# Multiple Instances
HomeKit has a limitation of 150 accessories per bridge. The bridge itself counts as an accessory, so in practice it's 149. In order to overcome this limitation, you can instruct openHAB to expose multiple bridges to HomeKit and then manually assign specific accessories to different instances. You will need to manually add each additional bridge in the Home app since the QR code in settings will only be for the primary bridge; however, the same PIN is still used. In order to assign a particular accessory to a different bridge, set the instance metadata parameter:
Switch kitchen_light {homekit="Lighting" [instance=2]}
Note that instances are numbered starting at 1. If you reference an instance that doesn't exist, then that accessory won't be exposed on any bridge.
For complex items, only the root group needs to be tagged for the specific instance:
Group           gSecuritySystem            "Security System Group"                                     {homekit="SecuritySystem" [instance=2]}
# Additional Notes
HomeKit allows only a single pairing to be established with the bridge. This pairing is normally shared across devices via iCloud. If you need to establish a new pairing, you will need to clear the existing pairings. To do this, you can issue the command openhab:homekit clearPairings from the OSGi console (opens new window). After doing this, you may need to remove the file $OPENHAB_USERDATA/jsondb/homekit.json and restart openHAB.
HomeKit requires a unique identifier for each accessory advertised by the bridge. This unique identifier is hashed from the item's name. For that reason, it is important that the names of your items exposed to HomeKit remain consistent.
HomeKit listens by default on port 9124. Java prefers the IPv6 network stack by default. If you have connection or detection problems, you can configure Java to prefer the IPv4 network stack instead. To prefer the IPv4 network stack, adapt the Java command line arguments to include: -Djava.net.preferIPv4Stack=true Depending on the openHAB installation method, you should modify start.sh, start_debug.sh, start.bat, or start_debug.bat (standalone/manual installation) or EXTRA_JAVA_OPTS in /etc/default/openhab2 (Debian installation).
# Console commands
# openHAB is not listed in the Home app
If you don't see openHAB in the Home app, probably multicast DNS (mDNS) traffic is not routed correctly from openHAB to the Home app device, or openHAB is already in a paired state. You can verify this with the Discovery DNS iOS app (opens new window) as follows:
  • install the Discovery DNS app from the App Store
  • start the Discovery app
  • find _hap._tcp in the list of service types
  • if you don't find _hap._tcp on the list, the traffic is probably blocked.
    • to confirm this, check whether you can find _openhab-server._tcp. If you don't see it as well, traffic is blocked. Check your network router/firewall settings.
  • if you found _hap._tcp, open it. You should see the name of your openHAB HomeKit bridge (the default name is openHAB)
  • if you don't see the openHAB bridge name, the traffic is blocked
  • if you see the openHAB HomeKit bridge, open it
  • verify the IP address. It must be the IP address of your openHAB server; if not, set the correct IP address using the networkInterface settings
  • verify the flag "sf".
    • if sf is equal to 1, openHAB is accepting pairing from a new iOS device.
    • if sf is equal to 0 (as in the screenshot), openHAB is already paired and does not accept any new pairing request. You can reset pairing using the openhab:homekit clearPairings command in the Karaf console.
  • if you see the openHAB bridge and sf is equal to 1 but you don't see openHAB in the Home app, the Home app probably still thinks it is already paired with openHAB. Remove your home from the Home app and restart the iOS device.
# Re-adding the openHAB HomeKit bridge reports that a bridge is already added, even though it has clearly been removed.
There are various reasons this may happen. Try the following:
  • In openhab-cli (opens new window), run openhab:homekit clearPairings. Try again.
  • In the HomeKit settings, change the port, setupId, and PIN. Save the settings, then re-open the settings to refresh the QR code. Re-add the device.
  • Remove HomeKit state in ${OPENHAB_USERDATA}/jsondb/homekit.json and HomeKit config in ${OPENHAB_USERDATA}/config/org/openhab/homekit.config. Restart openHAB. Reboot your iPhone. Try again.
You probably have useDummyAccessories enabled in the openHAB HomeKit settings. See the Dummy Accessories section in the help, above.
# I added an accessory as the wrong type in Home, and updating the item configuration does not cause the change to reflect in the Home app
HomeKit remembers certain configurations about an accessory, from its name to its fundamental type (i.e., fan, light, or switch?). If you added it incorrectly, simply updating the item type will not cause Home to update the type. To resolve:
  1. If using text configuration: Comment out the HomeKit metadata for an accessory. If in the GUI, delete the HomeKit metadata for all items associated with the accessory.
  2. If you have useDummyAccessories enabled, open the openhab-cli (opens new window). Run openhab:homekit listDummyAccessories and confirm your item is in the list. Once you've confirmed, clear it with openhab:homekit clearDummyAccessories.
  3. Kill your Home app on your iOS device. Re-open it and confirm that the accessory is gone.
  4. Uncomment the HomeKit metadata or re-add it via the UI.
  5. You should now see the updated configuration for your accessory.
