# Linky Binding
This binding enables the exploitation of electricity consumption data, mainly for the French market. It supports different functionalities:
- Connection to Enedis to retrieve consumption data online.
- Connection to the RTE API to get Tempo Red/White/Blue calendar information.
# Migration
The new binding (as of openHAB 5.0.0) will need some tweaks to your configuration to work. Mainly the new binding uses Bridge to access Enedis data, so you will have to add this bridge to your configuration. Step are:
before updating to openHAB 5.0, in case you defined your thing with Main UI, backup username, password & internalAuthId configuration parameters as you will need to fill them again.
add a bridge definition
Bridge linky:enedis:local "EnedisWebBridge" [ username="laurent@clae.net", password="Mnbo32tyu123!", internalAuthId="eyJhbGciOiJBMTI4S1ciLCJlbmMiOiJBMTI4Q0JDLUhTMjU2In0.u_mxXO7_d4I5bLvJzGtc2MARvpkYv0iM0EsO6a24k-tW9493_Myxwg.LVlfephhGTiCBxii8bRIkA.GOf9Ea8PTGshvkfjl62b6w.hSH97IkmBcEAz2udU-FqQg"] { }Move username, password and internalAuthId configuration parameters from the old linky thing to the bridge thing.
Link your old thing to the new created bridge thing:
Thing linky:linky:linkremotemelody "Linky Melody" (linky:enedis:local)Start using the new channels added by the enhanced binding.. Old items will work out of the box without the need to relink items to channels.
# Getting Consumption Data Online
The new binding version can use multiple bridges to access consumption data. You can use :
- The enedis bridge: Uses the old Enedis API, based on the Enedis website, to gather data.
- The myelectricaldata bridge: Uses the new REST Enedis API via the MyElectricalData proxy site to access the data.
- The enedis-api bridge: Also uses the new REST Enedis API, but gathers data directly from the Enedis site.
You first need to create an account at the Enedis website (opens new window) if you don't already have one. Ensure that you have accepted their conditions and check that you can see graphs on the website, especially the hourly view. Enedis may require your permission the first time to start collecting hourly data.
The binding will not provide this information unless this step is completed.
Advantage and Disadvantage of Each Method.
- Enedis bridge is the older method.
- MyelectricalData and enedis bridges both use the new API format, making them less prone to changes in website architecture.
- MyelectricalData bridge is managed by a third-party provider but is stable.
- Enedis-api bridge directly connects to Enedis but currently requires a complex registration process with Enedis. This limitation will likely be resolved in the near future, making Enedis-api Bridge the preferred method.
Be warned that MyElectricalData bridge collect data using MyElectricalData service. This service will store your enedis information for caching purpose. This cache is crypted, so it may be a very big concerns, but of course, we don't know the details about this crypting, and if it can be reverse to access your data.
# Bridge Configuration
To retrieve data, the Linky device needs to be linked to a LinkyBridge. The available bridge options are enedis, myelectricaldata, and enedis-api.
# Enedis Web Bridge
If you select enedis web bridge, you will need:
To create an Enedis account: https://mon-compte-client.enedis.fr/ (opens new window)
To provide your credentials: username, password, and InternalAuthId.
Parameter Description username Your Enedis platform username. password Your Enedis platform password. internalAuthId The internal authentication ID. This version is compatible with the latest Enedis Web API (deployed from June 2020). To bypass the captcha login, log in via a standard browser (e.g., Chrome, Firefox) and retrieve the user cookies (internalAuthId).
Instructions for Firefox :
- Go to https://mon-compte-client.enedis.fr/ (opens new window).
- Select "Particulier" from the drop down and click "Connexion".
- Enter your Enedis account email and check "Je ne suis pas un robot".
- Click "Suivant".
- Enter your Enedis password and click "Connexion à Espace Client Enedis".
- Navigate to your Enedis account environment, then return to the previous page in your browser.
- Log out from your Enedis account.
- Repeat steps 1-2. This time, open the developer tools window (F12) and select the "Storage" tab.
- Under "Cookies", select
https://mon-compte-client.enedis.fr/. Locate the "internalAuthId" entry and copy its value into your OpenHAB configuration.
A new timezone parameter has been introduced. If you don't put a value, it will default to the timezone of your openHAB installation. This parameter can be useful if you read data from a Linky in a different timezone.
Bridge linky:enedis:local "EnedisWebBridge" [ username="example@domaine.fr", password="******", internalAuthId="******" ]
# Myelectricaldata Bridge
If you select MyElectricalData bridge, you will need :
To follow these steps to initialize the token:
You can access the procedure from the connectlinky page available from your openHAB: https://home.myopenhab.org/connectlinky/index (opens new window).
You will find screenshot of the procedure in the following directory doc/myelectricaldata/
- Go to the connectlinky page on OpenHAB.
- Follow the first two steps of the wizard and click "Access Enedis".
- Log into your Enedis account.
- Authorize data collection for your PRM ID. If you have multiple Linky meters, repeat the procedure for each one separately; selecting multiple meters at once will not work.
- You will then be redirect to a confirmation page on MyElectricalData web site
- Return to OpenHAB, go to "connectlinky/myelectricaldata-step3", select your PRM ID from the dropdown, and click "Retrieve Token".
- A confirmation page will appear if everything is correctly set up.
Bridge linky:my-electrical-data:local "MyElectricalBridge" [ ]
# Enedis Bridge
If you select enedis bridge, you will need:
Follow these steps to initialize the token. You can access the procedure from the connectlinky page available from your openHAB: https://home.myopenhab.org/connectlinky/index (opens new window).
You will find a screenshot of the procedure in the following directory doc/enedis/
Bridge linky:enedis-api:localSB "EnedisBridgeSandbox" [ clientId="myClientId...", clientSecret="myClientSecret..."]
The remote bridge works with Linky devices to retrieve consumption data from a remote API or website.
You can have multiple Linky devices in your setup if you have different houses or multiple Linky meters linked to your account. To do this, simply create multiple Linky devices and set the prmId to match your meter ID. You can find the meter ID on the Enedis website or directly on your Linky meter.
You can switch the Linky device from one bridge to another if you experience issues with a particular bridge. The data retrieved will be almost identical regardless of the bridge you use. Only a few contract-related items may differ between the web bridge and the API bridge.
The device has the following configuration parameters:
| Parameter | Description |
| prmId | The prmId linked to the Linky Handler (optional: if blank first registered meter will be used |
| timezone | The timezone associated with your Point of delivery |
| token | Optional: Required if a token is necessary to access this Linky device (used for MyElectricalData). |
Thing linky:linky:linkyremote "Linky Remote" (linky:enedis:local) [ ]
Thing linky:linky:linkyremotexxxx "Linky Remote xxxx" (linky:enedis:local) [ prmId="xxxx" ]
Thing linky:linky:linkyremotexxxx "Linky Remote xxxx" (linky:enedis-api:local) [ prmId="xxxx" ]
Thing linky:linky:linkyremotexxxx "Linky Remote xxxx" (linky:myelectricaldata:local) [ prmId="xxxx", token="myElectricalDataToken" ]
# Thing Channels
The retrieved information is available in multiple groups.
The daily group will give consumtion information with day granularity
Channel ID Item Type Description daily#yesterday consumption Yesterday energy usage daily#day-2 consumption Day-2 energy usage daily#day-3 consumption Day-3 energy usage daily#consumption consumption timeseries for energy usage (up to three years will be store if available) daily#maw-power power timeseries for max-power usage daily#power power Yesterday's peak power usage daily#timestamp timestamp Timestamp of the power peak daily#power-2 power Day-2's peak power usage daily#timestamp-2 timestamp Timestamp Day-2's of the power peak daily#power-3 power Day-3's peak power usage daily#timestamp-3 timestamp Timestamp Day-3's of the power peak The weekly group will give consumtion information with week granularity
Channel ID Item Type Description weekly#thisWeek consumption Current week energy usage weekly#lastWeek consumption Last week energy usage weekly#week-2 consumption Week -2 energy usage weekly#consumption consumption timeseries for weeks energy usage weekly#max-power power timeseries for max-power weekly usage The monthly group will give consumtion information with month granularity
Channel ID Item Type Description monthly#thisMonth consumption Current month energy usage monthly#lastMonth consumption Last month energy usage monthly#month-2 consumption Month-2 energy usage monthly#consumption consumption timeseries for months energy usage monthly#max-power power timeseries for max-power monthly usage The yearly group will give consumtion information with year granularity
Channel ID Item Type Description yearly#thisYear consumption Current year energy usage yearly#lastYear consumption Last year energy usage yearly#year-2 consumption year-2 energy usage yearly#consumption consumption timeseries for years energy usage yearly#max-power power timeseries for max-power yearly usage The load-curve group will give you access to load curve data with granularity as low as 30mn
Channel ID Item Type Description load-curve#power power The load curve data You will also find some Information as properties on the linky things
Channel ID Description identitiy The full name of the contract older customerId The internal Enedis customer ID contractSubscribedPower The subscribed max Power contractLastActivationdate The contract activation date contractDistributionTariff The current applied tarif contractOffpeakHours The OffPeakHour link to your contract contractStatus The current contract status contractType The contract type contractLastdistributionTariffChangedate The date of the last tariff change contractSegment The customer segment for this contract usagePointId The distribution / usage point uniq indentifier usagePointStatus The usage point current state usagePointMeterType The usage point meter type usagePointCity The usage point City usagePointCountry The usage point Country usagePointPostalCode The usage point Postal Code usagePointStreet The usage point Address Street contactMail The usage point Contact Mail contactPhone The usage point Contact Phone
# Remote Enedis Web Connection
Number:Energy ConsoHier "Conso hier [%.0f %unit%]" <energy> { channel="linky:linky:linkyremotexxxx:daily#yesterday" }
Number:Energy ConsoSemaineEnCours "Conso cette semaine [%.0f %unit%]" <energy> { channel="linky:linky:linkyremotexxxx:weekly#thisWeek" }
Number:Energy ConsoSemaineDerniere "Conso semaine dernière [%.0f %unit%]" <energy> { channel="linky:linky:linkyremotexxxx:weekly#lastWeek" }
Number:Energy ConsoMoisEnCours "Conso ce mois [%.0f %unit%]" <energy> { channel="linky:linky:linkyremotexxxx:monthly#thisMonth" }
Number:Energy ConsoMoisDernier "Conso mois dernier [%.0f %unit%]" <energy> { channel="linky:linky:linkyremotexxxx:monthly#lastMonth" }
Number:Energy ConsoAnneeEnCours "Conso cette année [%.0f %unit%]" <energy> { channel="linky:linky:linkyremotexxxx:yearly#thisYear" }
Number:Energy ConsoAnneeDerniere "Conso année dernière [%.0f %unit%]" <energy> { channel="linky:linky:linkyremotexxxx:yearly#lastYear" }
# Displaying Information Graph
Using the timeseries channel, you will be able to easily create a calendar graph to display the Tempo calendar. To do this, you need to enable a timeseries persistence framework. Graph definitions will look like this:
Sample code:
future: false
label: Linky Melody Conso Journalière
order: "110"
period: 2W
sidebar: true
dataZoom:
- component: oh-chart-datazoom
type: inside
grid:
- component: oh-chart-grid
containLabel: true
includeLabels: true
show: true
legend:
- component: oh-chart-legend
bottom: 3
type: scroll
series:
- component: oh-time-series
areaStyle:
opacity: 0.2
gridIndex: 0
item: Linky_Melody_Daily_Conso_Day
label:
formatter: =v=>Number.parseFloat(v.data[1]).toFixed(2) + " Kwh"
position: inside
show: true
markLine:
data:
- type: average
markPoint:
data:
- name: min
type: min
- name: max
type: max
label:
backgroundColor: auto
noBoundary: true
noItemState: true
service: influxdb
type: bar
xAxisIndex: 0
yAxisIndex: 0
tooltip:
- component: oh-chart-tooltip
confine: true
smartFormatter: true
xAxis:
- component: oh-time-axis
gridIndex: 0
nameLocation: center
splitNumber: 10
yAxis:
- component: oh-value-axis
gridIndex: 0
max: "150"
min: "0"
# Getting Tempo Calendar Information
# Tempo Thing Channels
The tempo group will give information about the tempo day color link to a tempo contract
Channel ID Item Type Description linky-tempo-calendar#tempo-info-today tempo-value The tempo color for the current day linky-tempo-calendar#tempo-info-tomorrow tempo-value The tempo color for the tomorrow linky-tempo-calendar#tempo-info-timeseries tempo-value A timeseries channel that will expose full tempo information for one year
# Displaying Tempo Graph
Using the timeseries channel, you will be able to esealy create a calendar graph to show the tempo calendar. You will need for this to enable a timeseries persistence framework. Graph definitions will look like this
The resulting graph will look like this:
Sample code:
chartType: month
future: false
label: Tempo
period: M
sidebar: true
calendar:
- component: oh-calendar-axis
cellSize: 10
dayLabel:
firstDay: 1
fontSize: 16
margin: 20
left: center
monthLabel:
color: "#c0c0ff"
fontSize: 30
margin: 20
orient: vertical
top: middle
yearLabel:
color: "#c0c0ff"
fontSize: 30
margin: 50
dataZoom:
orient: horizontal
show: true
type: slider
grid: []
legend:
show: false
series:
- component: oh-calendar-series
aggregationFunction: average
calendarIndex: 0
coordinateSystem: calendar
item: Linky_Melody_Tempo
label:
formatter: =v=> JSON.stringify(v.data[0]).substring(1,11)
show: true
smartFormatter: false
service: inmemory
type: heatmap
title:
- component: oh-chart-title
show: true
text: Calendrier Tempo
toolbox:
- component: oh-chart-toolbox
presetFeatures:
- saveAsImage
- restore
- dataView
- dataZoom
- magicType
show: true
tooltip:
formatter: "{c}"
show: true
visualMap:
- component: oh-chart-visualmap
bottom: 0
calculable: true
inRange:
color:
- "#0000ff"
- "#ffffff"
- "#ff0000"
left: center
max: 2
min: 0
orient: horizontal
presetPalette: ""
show: false
type: continuous
xAxis: []
yAxis: []
# Console Commands
The binding provides one specific command you can use in the console.
Enter the command openhab:linky to get the usage.
openhab:linky <thingUID> report <start day> <end day> [<separator>] - report daily consumptions between two dates
The command report reports in the console the daily consumptions between two dates.
If no dates are provided, the last 7 are considered by default.
Start and end day are formatted yyyy-mm-dd.
Here is an example of command you can run: openhab:linky linky:linky:local report 2020-11-15 2020-12-15.
# Docker Specifics
In case you are running openHAB inside Docker, the binding will work only if you set the environment variable CRYPTO_POLICY to the value "unlimited", read the documentation (opens new window) for details.
← LinkTap Linux Input →
