# Tabbed Pages
Tabbed Pages are composite Pages which are able to display other Pages in tabs.
Tabbed Example
# Anatomy of a Tabbed Page
Tabbed pages are very simple: you can only add oh-tabs components which will have a label, icon, and a reference to another Page. The tabs will be displayed in the order they're defined.
# Building a Tabbed Page
In the Design view, under Tabs, click Add tab to add another tab. Then click on the newly added entry to configure the tab. using the black context menu, you can reorder or remove existing tabs.
As you can see in the screenshot above, navigating through the tabs of tabbed pages is done through a toolbar on the bottom.
However, it is also possible to programatically navigate between the tabs, e.g. when using the UI Command Item or the actions of cloud notifications This is done by providing the index of the tab in the route, e.g. assuming the UID of the tabbed page in the above example is MyTabbedPage, you can navigate to the "Isometric View" tab using the route /page/MyTabbedPage/0, to the "Kitchen Picture" tab using /page/MyTabbedPage/1 and to the "Plan" tab using /pages/MyTabbedPage/2.
