# openHAB on Linux
Linux file permissions is one of the biggest sources of issues, Linux novices run into. If you find yourself in a situation, where you have no write access to the openHAB configuration or system files wrong permissions and/or the incorrect use of sudo are often the cause. Train your understanding of Linux permissions at linuxjourney.com/lesson/file-permissions (opens new window).
# Meeting the Requirements
Alternatively, Zulu Embedded can be installed for small systems either from the same package repository as above or manually (opens new window). If you're unsure which manual file you should download, using dpkg --print-architecture or rpm -q --qf '%{ARCH}\n' rpm in your Linux terminal should point you in the right direction (e.g. armhf means ARM Hard Float).
Make sure to download Zulu or Java 17. Java 21 can be used openHAB 4.x, and is required for openHAB 5.
# Installation
  • the openHABian project (easiest method, ships with the openHABian configuration tool)
  • a package repository (apt, yum)
  • manually from file.
# openHABian project
# Apt Based Systems
First, add the openHAB repository key to your package manager (note /usr/share/keyrings may already exist):
curl -fsSL "https://openhab.jfrog.io/artifactory/api/gpg/key/public" | gpg --dearmor > openhab.gpg
sudo mkdir /usr/share/keyrings
sudo mv openhab.gpg /usr/share/keyrings
sudo chmod u=rw,g=r,o=r /usr/share/keyrings/openhab.gpg
  • Stable Release
    echo 'deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg stable main' | sudo tee /etc/apt/sources.list.d/openhab.list
  • Testing Release
    The beta and release candidate builds come out more frequently, but will contain new features that are currently in the testing phase.
    echo 'deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg testing main' | sudo tee /etc/apt/sources.list.d/openhab.list
  • Snapshot Release
    echo 'deb [signed-by=/usr/share/keyrings/openhab.gpg] https://openhab.jfrog.io/artifactory/openhab-linuxpkg unstable main' | sudo tee /etc/apt/sources.list.d/openhab.list
sudo apt-get update
# Installing the latest version
sudo apt-get install openhab
# Prevent automatic upgrade of openHAB
To prevent unexpected breakage by accidentally updating openHAB it's recommended to only manually upgrade to the newest version. This can be achieved by putting the openHAB package on "hold".
sudo apt-mark hold openhab
sudo apt-mark hold openhab-addons
To enable automatic upgrades again run
sudo apt-mark unhold openhab
sudo apt-mark unhold openhab-addons
To show the packages on hold run
sudo apt-mark showhold
# Installing a specific version
Installing a specific version is possible by specifing the version that should be installed.
sudo apt install openhab=4.0.1
sudo apt install openhab-addons=4.0.1
To get a list of all available versions you can use
apt list -a openhab
# Yum or Dnf Based Systems
The RPM repo information should be defined inside a file, make a new file at /etc/yum.repos.d/openhab.repo with the following contents depending on your choice of release. You may add all three to the same file, but make sure the desired repo is is set to enabled=1:
  • Stable Release
    [openHAB-Stable]
    name=openHAB Stable
    baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/stable
    gpgcheck=1
    gpgkey="https://openhab.jfrog.io/artifactory/api/gpg/key/public"
    enabled=1
  • Testing Release
    [openHAB-Testing]
    name=openHAB Testing
    baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/testing
    gpgcheck=1
    gpgkey=https://openhab.jfrog.io/artifactory/api/gpg/key/public
    enabled=1
  • Snapshot Release
    [openHAB-Snapshots]
    name=openHAB Snapshots
    baseurl=https://openhab.jfrog.io/artifactory/openhab-linuxpkg-rpm/unstable
    gpgcheck=1
    enabled=1
sudo yum install openhab
# Arch Linux
cd openhab3
makepkg -s
sudo systemctl daemon-reload
You should be able to reach the openHAB Dashboard at http://openhab-device:8080 at this point. Be sure to check whether you need to adjust your firewall settings. If you're new to openHAB, then you should checkout the beginner's tutorial!
The openHAB Dashboard page
# Service Control
sudo /etc/init.d/openhab stop
After installing openHAB, a shortcut named openhab-cli provides access to the openHAB-specific commands (such as backup, restore, and console). To use the shortcuts in a terminal, simply type openhab-cli followed by the command. For example:
Usage:  openhab-cli command [options]
Possible commands:
  start [--debug]     -- Starts openHAB in the terminal.
  stop                -- Stops any running instance of openHAB.
  status              -- Checks to see if openHAB is running.
  console             -- Opens the openHAB console.
  backup [filename]   -- Stores the current configuration of openHAB.
  restore filename    -- Restores the openHAB configuration from a backup.
  showlogs            -- Displays the log messages of openHAB.
  info                -- Displays distribution information.
# Changing Versions
# Apt Based Systems
Upgrading is as easy as:
sudo apt-get update
sudo apt-get upgrade
sudo apt-get update
apt-cache showpkg openhab
sudo yum upgrade
rpm -q openhab
# Uninstall
# Apt Based Systems
sudo apt-get purge openhab*
sudo yum remove openhab*
# Manual Installation
note
The needed command syntax may vary based on the distribution you are using.
Below there is an example for fedora based systems:
sudo adduser --system --no-create-home --user-group --disabled-login openhab
So make sure to check the allowed command parameters in case of any errors.
We are going to download a platform independent archive file and extract it to the path /opt/openhab. Choose between the latest Beta release or a Snapshot with all incoming contributions, created daily. As openHAB is still in an evolving state, the snapshot may be the preferred choice.
  • Official Release
    Download and extract the latest official stable version of openHAB from our downloadpage (opens new window) to your host:
    cd /tmp
    wget -O openhab-download.zip https://www.openhab.org/download/releases... # Insert download link here
    sudo unzip openhab-download.zip -d /opt/openhab
    rm openhab-download.zip
  • Beta/RC Release
  • Snapshot Release
The extracted openHAB files should belong to the earlier created openhab user. Execute:
Everything is ready for a first test run. Execute openHAB and you should be able to reach the openHAB Dashboard at http://openhab-device:8080 after a few minutes:
The openHAB portal page
# Service
The following instructions are intended for a Linux init system based on systemd (e.g. Debian 8 / Ubuntu 15.x and newer). This will allow you to register openHAB as a service, so that it runs at startup and automatically restarts if openHAB crashes. The service will be running with the privileges of the user "openhab" and expects the openHAB files under /opt/openhab.
[Unit]
Wants=network-online.target
After=network-online.target
[Service]
User=openhab
Group=openhab
WorkingDirectory=/opt/openhab
Restart=on-failure
SuccessExitStatus=0 143
[Install]
WantedBy=multi-user.target
#start and retrieve status
# Installing add-ons
When running a manual installation, it is possible to pre-download add-ons or legacy add-ons if you want to install any bindings at a later date without connecting to the internet. Simply download the kar files (the latest builds can be found here (opens new window)) and move them to the /opt/openhab/addons folder.
# Upgrade
  • Versions 2.1.0 and Above
    From version 2.1.0, openHAB is distributed with the update script included. This script should be called from within openHAB's root directory. Assuming the openHAB directory is in /opt/openhab, simply run the following commands to update to the next major version of openHAB:
    cd /opt/openhab
    sudo runtime/bin/update
    You can also specify any version as a parameter. For example, to switch back to 2.0.0:
    sudo runtime/bin/update 2.0.0
    You may also change to openHAB's more frequent, but less stable snapshot builds. Just append "-SNAPSHOT" to the target version, e.g.:
    sudo runtime/bin/update 2.2.0-SNAPSHOT
  • Older Versions
    If you're using a version earlier than 2.1.0, then you can use the following commands in Terminal to download the script and run it. Assuming the openHAB directory is in /opt/openhab:
    cd /opt/openhab
    sudo sh -c "$(curl -fsSL https://raw.githubusercontent.com/openhab/openhab-distro/main/distributions/openhab/src/main/resources/bin/update)" -- 2.1.0
# Uninstall
sudo rm -rf /opt/openhab/
# File Locations
Repository Installation Manual Installation (according to guide)
openHAB application /usr/share/openhab /opt/openhab
Additional add-on files /usr/share/openhab/addons /opt/openhab/addons
Site configuration /etc/openhab /opt/openhab/conf
Log files /var/log/openhab /opt/openhab/userdata/logs
Userdata like rrd4j databases /var/lib/openhab /opt/openhab/userdata
Backups folder /var/lib/openhab/backups /opt/openhab/backups
Service configuration /etc/default/openhab (not preconfigured)
# Backup and Restore
It is recommended to make a backup of your configuration before any major change. To make a backup of openHAB 2 or higher, you need to retain your configuration and userdata files. openHAB comes with scripts for storing your configuration in a zip file which is saved in /var/lib/openhab/backups for automatic installs and openhab/backups for manual installs. You can change the default path by setting the $OPENHAB_BACKUPS environment variable.
## OR ##
# Viewing Log Messages
  • Package repository based installation:
    tail -f /var/log/openhab/openhab.log -f /var/log/openhab/events.log
  • Manual installation:
An openHAB setup will often rely on hardware like a modem, transceiver or adapter to interface with home automation hardware. Examples are a Z-Wave, Enocean or RXFcom USB Stick or a Raspberry Pi add-on board connected to the serial port on its GPIOs. In order to allow openHAB to communicate with additional peripherals, it has to be added to corresponding Linux groups. The following example shows how to add Linux user openhab to the often needed groups dialout and tty. Additional groups may be needed, depending on your hardware and software setup.
sudo adduser openhab dialout
sudo adduser openhab tty
sudo adduser openhab audio
# Java Network Permissions
# Network Sharing
sudo vim /etc/samba/smb.conf
wins support = yes
    [openHAB-userdata]
      comment=openHAB userdata
      path=/var/lib/openhab
      browseable=Yes
      writeable=Yes
      only guest=no
      public=no
      create mask=0777
      directory mask=0777
    [openHAB-conf]
      comment=openHAB site configuration
      path=/etc/openhab
      browseable=Yes
      writeable=Yes
      only guest=no
      public=no
      create mask=0777
      directory mask=0777
    [openHAB-logs]
      comment=openHAB logs
      path=/var/log/openhab
      browseable=Yes
      writeable=Yes
      only guest=no
      public=no
      create mask=0777
      directory mask=0777
    [openHAB-files]
      comment=openHAB
      path=/opt/openhab
      browseable=Yes
      writeable=Yes
      only guest=no
      public=no
      create mask=0777
      directory mask=0777
sudo smbpasswd -a openhab
samba-tool testparm
sudo service smbd restart
# Mounting Locally
  • On macOS: Open Finder → Go → Connect to Server: smb://[email protected]
  • On Windows: Open Windows Explorer → Address bar: \\openhab-device.local → Right click a share and assign a drive letter
Be sure to use the actual host name instead of openhab-device. When asked, authenticate with the username "openhab" and the chosen password. If you are not able to connect, try with the IP of your device (e.g. smb://[email protected] or \\192.168.0.2).
# Required Ports and Firewalls
Depending on your Linux distribution your system might come with a preconfigured firewall that could prevent access to the openHAB Dashboard. Refer to your distribution's firewall documentation to open the required ports.
Port Protocol Purpose
8080 TCP openHAB Dashboard via HTTP
8443 TCP openHAB Dashboard via HTTPS
5007 TCP Language Server Protocol (LSP) for VS Code
On a system using firewalld you could use the following commands:
sudo firewall-cmd --permanent --add-port=8080/tcp
sudo firewall-cmd --permanent --add-port=8443/tcp
sudo firewall-cmd --permanent --add-port=5007/tcp
