# BambuLab Binding
This addon supports connecting with BambuLab 3D printers in local mode. While cloud mode is theoretically possible, it is not supported by the addon developers.
# Cloud Mode
Cloud mode is possible but not officially supported by the addon developers.
To use cloud mode, follow these steps:
# Find Username
Log in to Maker World and visit my-preferences (opens new window) to retrieve a JSON response containing your data.
The relevant field is uid
, which represents the unique ID of your account.
Use this value as the username
in the configuration (advanced field) with the prefix u_
# Access Token
To obtain an access token, follow these steps:
- Log in using your email and password.
- Confirm the login using a token received via email.
# Step 1: Login with Email and Password
curl -X POST "https://api.bambulab.com/v1/user-service/user/login" \
-H "Content-Type: application/json" \
-d '{
"account": "[email protected]",
"password": "superduperpassword123"
# Step 2: Confirm Login with Token from Email
-d '{
"code": "123456"
You will receive a long access code in the response. Copy it and use it as the accessCode
parameter.
Note: This access code expires after three months. When it expires, repeat the process to obtain a new one.
# Hostname
Use us.mqtt.bambulab.com
as the hostname.
printer
: Represents a BambuLab 3D printer.
Parameter | Type | Required | Description |
serial | Text | Yes | Unique serial number of the printer. |
scheme | Text | No | URI scheme. (Advanced) |
hostname | Text | Yes | IP address of the printer or us.mqtt.bambulab.com for cloud mode. |
port | Integer | No | URI port. (Advanced) |
username | Text | No | bblp for local mode or your Bambu Lab user (starting with u_ ). (Advanced) |
accessCode | Text | Yes | Access code for the printer. The method of obtaining this varies between local and cloud modes. |
Channel ID | Type | Description |
nozzle-temperature | Temperature Channel | Current temperature of the nozzle. |
nozzle-target-temperature | Temperature Channel | Target temperature of the nozzle. |
bed-temperature | Temperature Channel | Current temperature of the heated bed. |
bed-target-temperature | Temperature Channel | Target temperature of the heated bed. |
chamber-temperature | Temperature Channel | Current temperature inside the printer chamber. |
mc-print-stage | String Channel | Current stage of the print process. |
mc-percent | Percent Channel | Percentage of the print completed. |
mc-remaining-time | Number Channel | Estimated time remaining for the print (in seconds). |
wifi-signal | WiFi Channel | Current WiFi signal strength. |
bed-type | String Channel | Type of the printer's heated bed. |
gcode-file | String Channel | Name of the currently loaded G-code file. |
gcode-state | String Channel | Current state of the G-code execution. |
reason | String Channel | Reason for pausing or stopping the print. |
result | String Channel | Final result or status of the print job. |
gcode-file-prepare-percent | Percent Channel | Percentage of G-code file preparation completed. |
big-fan1-speed | Number Channel | Speed of the first large cooling fan (RPM). |
big-fan2-speed | Number Channel | Speed of the second large cooling fan (RPM). |
heat-break-fan-speed | Number Channel | Speed of the heat break cooling fan (RPM). |
layer-num | Number Channel | Current layer being printed. |
speed-level | Number Channel | Current speed setting of the print job. |
time-laps | Boolean Channel | Indicates whether time-lapse recording is enabled. |
use-ams | Boolean Channel | Indicates whether the Automatic Material System (AMS) is active. |
vibration-calibration | Boolean Channel | Indicates whether vibration calibration has been performed. |
led-chamber | On/Off Command | Controls the LED lighting inside the printer chamber. |
led-work | On/Off Command | Controls the LED lighting for the work area. |
# bambulab.things
Thing bambulab:printer:myprinter "My BambuLab Printer" @ "3D Printing Area" [
serial="ABC123456789",
hostname="192.168.1.100",
accessCode="your_access_code_here"
# bambulab.items
Exmaple
Number:Temperature NozzleTemperature "Nozzle Temperature [%.1f °C]" { channel="bambulab:printer:myprinter:nozzle-temperature" }
Number:Temperature BedTemperature "Bed Temperature [%.1f °C]" { channel="bambulab:printer:myprinter:bed-temperature" }
String PrintStage "Print Stage [%s]" { channel="bambulab:printer:myprinter:mc-print-stage" }
Switch LedChamber "Chamber LED" { channel="bambulab:printer:myprinter:led-chamber" }
The printer thing supports actions:
rule "test"
/* when */
val actions = getActions("bambulab", "bambulab:printer:as8af03m38")
if(actions !==null){
// Refresh all channels
actions.refreshChannels()
actions.sendCommand("Pushing:1:1")
# refreshChannels
Reports the complete status of the printer. This is unnecessary for the X1 series since it already transmits the full object each time. However, the P1 series only sends the values that have been updated compared to the previous report. As a rule of thumb, refrain from executing this command at intervals less than 5 minutes on the P1P, as it may cause lag due to its hardware limitations.
# sendCommand
The sendCommand
method expects a string command in the format:
CommandType:Parameter1:Parameter2:...
# Possible Commands:
Command Type | Parameters | Description |
Pushing | version(int) ,pushTarget(int) (optional) | Sends a push command. |
Print | START / STOP / PAUSE | Controls the print job. |
ChangeFilament | target(int) ,currentTemperature(int)) ,targetTemperature(int) | Changes filament using. |
AmsUserSetting | amsId(int) ,startupReadOption(boolean) ,trayReadOption(boolean) | Sets AMS user settings. |
AmsFilamentSetting | amsId(int) ,trayId(int) ,trayInfoIdx(string) ,trayColor(string) ,nozzleTempMin(int) ,nozzleTempMax(int) ,trayType(string) | Configures filament settings. |
AmsControl | RESUME / RESET / PAUSE | Sends an AMS control command. |
PrintSpeed | SILENT / STANDARD / SPORT / LUDICROUS | Adjusts print speed. |
GCodeFile | filename(string) | Loads a G-code file. |
GCodeLine | userId(string)\nlines(string...) | Sends multiple G-code lines. Lines are enter (\n ) separated |
LedControl | (CHAMBER_LIGHT / WORK_LIGHT ),(ON / OFF / FLASHING ),ledOnTime(int)? ,ledOffTime(int)? ,loopTimes(int)? ,intervalTime(int)? | Controls LED lighting. |
System | GET_ACCESS_CODE | Executes a system command. |
IpCamRecord | enable(boolean) | Starts or stops IP camera recording. |
Info | GET_VERSION | Sends a info command. |
IpCamTimelaps | enable(boolean) | Enables or disables timelapse recording. |
XCamControl | (FIRST_LAYER_INSPECTOR / SPAGHETTI_DETECTOR ),control(boolean) ,printHalt(boolean) | Controls XCam settings. |
← aWATTar Belkin Wemo →
