This binding supports generic MQTT devices. And has specialist extensions for the following manufacturers products:
MQTT Architecture
  • When a device (a client) wants to send data to the broker, we call this operation a “publish”.
  • When a device (a client) wants to receive data from the broker, we call this operation a “subscribe”.
Publish and Subscribe
openHAB itself is not an MQTT Broker and needs to connect to one as a regular client. You can use any of the freely available MQTT Brokers like Mosquitto (opens new window).
This particular binding allows to configure connections to brokers via openHAB Things, and configure channels corresponding to MQTT topics. This binding does NOT perform auto-discovery of available MQTT topics.
# MQTT Topics
It has a unique id amongst all light bulbs, say "device123". The manufacturer accepts new brightness values on "device123/brightness/set". In openHAB we call that a command topic.
Because every manufacturer can decide on his own on which topic his devices publish, this binding can unfortunately not provide any auto-discovery means.
If you use an open source IoT device, the chances are high, that it has the MQTT Homie convention or HomeAssistant implemented. Those conventions specify the topic topology and allow auto discovery. Please have a look at the specific openHAB bindings.
# Supported Bridges
  • Broker: This bridge represents an MQTT Broker connection, configured and managed by this binding.
# Bridge Configuration
  • host: The IP/Hostname of the MQTT broker. Be aware that this binding allows only one bridge / one connection per unique host:port.
  • port: The optional port of the MQTT broker. If none is provided, the typical ports 1883 and 8883 (SSL) are used. Be aware that this binding allows only one bridge / one connection per unique host:port.
  • secure: Uses TLS/SSL to establish a secure connection to the broker. Can be true or false. Defaults to false.
  • hostnameValidated: Validate hostname from certificate against server hostname for secure connection. Defaults to true.
  • protocol: The protocol used for communicating with the broker (TCP, WEBSOCKETS). Defaults to TCP.
  • webSocketPath: WebSocket path for the broker, e.g. /mqtt. Defaults to root. This only applies when protocol is WEBSOCKETS.
  • mqttVersion: The MQTT version used for communicating with the broker (V3, V5). Defaults to V3.
  • qos: Quality of Service requested for subscriptions and used as the default for messages published through this broker connection. Generic channels can override it for messages they publish. Can be 0, 1 or 2. Please read the MQTT specification for details. Defaults to 0.
  • clientID: Use a fixed client ID. Defaults to empty which means a client ID is generated for this connection.
  • cleanSessionStart: Clear the old session at connection start. Defaults to true. False only makes sense with a fixed client ID.
Reconnect parameters are:
  • reconnectTime: Reconnect time in ms. If a connection is lost, the binding will wait this time before it tries to reconnect. Defaults to 60000 (60s).
  • keepAlive: Keep alive / heartbeat timer in s. It can take up to this time to determine if a server connection is lost. A lower value may keep the broker unnecessarily busy for no or little additional value. Defaults to 60s.
  • lwtMessage: An optional last will and testament message. Defaults to empty.
  • lwtTopic: The last will topic. Defaults to empty and therefore disables the last will.
  • lwtQos: The optional qos of the last will. Defaults to 0.
  • lwtRetain: Retain last will message. Defaults to true.
An MQTT message can be published upon a successful connection to the MQTT broker with these parameters:
  • birthMessage: An optional message to be published once the bridge established a connection to the MQTT broker. Defaults to empty.
  • birthTopic: The birth topic. Defaults to empty and therefore no birth message will be published.
  • birthRetain: Retain the birth message. Defaults to true.
An MQTT message can be published just before disconnecting from the broker with these parameters:
  • shutdownMessage: An optional message to be published before the bridge disconnects from the MQTT broker. Defaults to empty.
  • shutdownTopic: The shutdown topic. Defaults to empty and therefore no shutdown message will be published.
  • shutdownRetain: Retain the shutdown message. Defaults to true.
  • username: The MQTT username (since MQTT 3.1). Defaults to empty.
  • password: The MQTT password (since MQTT 3.1). Defaults to empty.
  • certificatepin: If this is set: After the next connection has been successfully established, the certificate is pinned. The connection will be refused if another certificate is used. Clear certificate to allow a new certificate for the next connection attempt. This option will increase security.
  • publickeypin: If this is set: After the next connection has been successfully established, the public key of the broker is pinned. The connection will be refused if another public key is used. Clear publickey to allow a new public key for the next connection attempt. This option will increase security.
  • certificate: The certificate hash. If certificatepin is set this hash is used to verify the connection. Clear to allow a new certificate pinning on the next connection attempt. If empty will be filled automatically by the next successful connection. An example input would be SHA-256:83F9171E06A313118889F7D79302BD1B7A2042EE0CFD029ABF8DD06FFA6CD9D3.
  • publickey: The public key hash. If publickeypin is set this hash is used to verify the connection. Clear to allow a new public key pinning on the next connection attempt. If empty will be filled automatically by the next successful connection. An example input would be SHA-256:83F9171E06A313118889F7D79302BD1B7A2042EE0CFD029ABF8DD06FFA6CD9D3.
  • enableDiscovery: If set to true, enables discovery on this broker; if set to false, disables discovery services on this broker.
# Broker Channels
  • publishTrigger: This channel is triggered when a value is published to the configured MQTT topic on this broker connection. By default, the event payload (in receivedEvent) is the received MQTT topic value only. If a separator is configured (see channel config), the payload will contain the topic and the value separated by that character (e.g., my_topic#my_value).
Configuration parameters are:
  • stateTopic: This channel will trigger on this MQTT topic. This topic can contain wildcards like + and # for example "all/in/#" or "sensors/+/config".
  • payload: An optional condition on the value of the MQTT topic that must match before this channel is triggered.
The following optional parameters can be set for the Thing:
  • availabilityTopic: The MQTT topic that represents the availability of the Thing. This can be the Thing's LWT topic.
  • payloadAvailable: Payload of the Availability Topic, when the device is available. Default: ON.
  • payloadNotAvailable: Payload of the Availability Topic, when the device is not available. Default: OFF.
  • transformationPattern: An optional transformation pattern like JSONPath (opens new window) that is applied to the incoming availability payload. The result of the transformations is then checked against payloadAvailable and payloadNotAvailable.
# Supported Channels
  • string: This channel can show the received text on the given topic and can send text to a given topic.
  • number: This channel can show the received number on the given topic and can send a number to a given topic. It can have a min, max and step values.
  • dimmer: This channel handles numeric values as percentages. It can have min, max and step values.
  • contact: This channel represents an open/close state of a given topic.
  • switch: This channel represents an on/off state of a given topic and can send an on/off value to a given topic.
  • colorRGB: This channel handles color values in RGB format. (Deprecated)
  • colorHSB: This channel handles color values in HSB format. (Deprecated)
  • color: This channel handles color values in HSB, RGB or xyY (x,y,brightness) formats.
  • image: This channel handles binary images in common java supported formats (bmp,jpg,png).
  • datetime: This channel handles date/time values.
  • rollershutter: This channel is for rollershutters.
  • player: This channel is for media players. Each command (play/pause, next/previous, rewind/fastforward) can be mapped to an individual string.
  • trigger: This channel emits the received MQTT payload as a channel event without updating an Item state.
# Channel Configuration
  • stateTopic: The MQTT topic that represents the state of the Thing. This is required for Contact and trigger channels. Other channel types can omit it when a command topic is configured. You can use a wildcard topic like "sensors/+/event" to retrieve state from multiple MQTT topics.
  • transformationPattern: An optional transformation pattern like JSONPath (opens new window) that is applied to all incoming MQTT values.
  • transformationPatternOut: An optional transformation pattern like JSONPath (opens new window) that is applied before publishing a value to MQTT.
  • commandTopic: The MQTT topic that commands are sent to. If empty, the channel is read-only. Contact channels ignore this option.
  • formatBeforePublish: Format a value before it is published to the MQTT broker. The default is to just pass the channel/item state. If you want to apply a prefix, say "MYCOLOR,", you would use "MYCOLOR,%s". Currently only "%s" is supported. Note that this format does not apply to the special on/off command values for dimmer channels, or up/down/stop command values for rollershutter channels.
  • postCommand: If true, the received MQTT value is processed as a command instead of a state update. Profiles that react only to state updates, such as timestamp-update and timestamp-change, do not process incoming values when this option is enabled. The default is false. You usually need this to be true if your item is also linked to another channel, say a KNX actor, and you want a received MQTT payload to command that KNX actor.
  • retained: The value will be published to the command topic as retained message. A retained value stays on the broker and can even be seen by MQTT clients that are subscribing at a later point in time.
  • qos: QoS used when publishing messages from this channel to its commandTopic. It does not affect the subscription to the stateTopic, which uses the broker connection QoS. Defaults to the broker connection QoS.
  • trigger: If true, a received MQTT value that is valid for the selected channel type triggers a channel event instead of updating a state. This typed trigger behavior remains supported, but for untyped trigger events the dedicated trigger channel type is preferred. Image channels always remain state channels because their payload is binary. If a commandTopic is also configured, the channel retains state-channel metadata so linked Item commands can continue to be published to MQTT.
# Trigger Channels
The trigger channel emits every successfully transformed payload received on stateTopic as a channel event. It does not validate the payload as one of the state channel types and does not update an Item state.
In a .things file, use the MQTT trigger channel type:
Type trigger : alarm [ stateTopic="sensors/alarm" ]
The generic Trigger String and Trigger Switch forms do not select an MQTT channel type and are not supported by this binding.
# Channel Type "string"
  • allowedStates: An optional comma-separated list of allowed states. Example: "ONE,TWO,THREE"
# Channel Type "number"
  • min: An optional minimum value.
  • max: An optional maximum value.
  • step: For decrease, increase commands the step needs to be known
  • unit: Unit of measurement (optional). For supported units see OpenHAB: List of Units. Examples: "°C", "°F"
A decimal value (like 0.2) is sent to the MQTT topic if the number has a fractional part. If you always require an integer, please use the formatter.
# Channel Type "dimmer"
  • on: An optional string (like "ON"/"Open") that is sent for the ON command to tell the device to turn on to whatever value it thinks is useful (i.e. restore last state).
  • off: An optional string (like "OFF"/"Close") that is sent for the OFF command.
  • min: A required minimum value.
  • max: A required maximum value.
If on or off are not defined, an explicit 0 or 100 will be sent (after being scaled by min and max as appropriate). Note that formatBeforePublish will be ignored for these values, in case your device uses a vastly different format for these special commands than it does for number values.
  • on: An optional number (like 1, 10) or a string (like "ON"/"Open") that is recognized as on/open state.
  • off: An optional number (like 0, -10) or a string (like "OFF"/"Close") that is recognized as off/closed state.
The contact channel by default recognizes "OPEN" and "CLOSED". You can connect this channel to a Contact item. It only reports states; commandTopic and postCommand have no effect. The switch channel by default recognizes "ON" and "OFF". You can connect this channel to a Switch item.
If on and off are not configured, the switch channel publishes "ON" and "OFF" by default.
# Channel Type "color"
  • colorMode: An optional string that defines the color representation: HSB, RGB or XYY (x,y,brightness). Defaults to HSB when not specified.
  • onBrightness: If you connect this channel to a Switch item and turn it on, color and saturation are preserved from the last state, but the brightness will be set to this configured initial brightness (default: 10%).
This channel will publish the color as a comma-separated list to the MQTT broker, e.g. "112,54,123" for the RGB color mode (0-255 per component), "360,100,100" for the HSB color mode (0-359 for hue and 0-100 for saturation and brightness), and "0.640074,0.329970,100" for the xyY color mode (0-1 for x and y, and 0-100 for brightness).
If on or off are not defined, a color command with the brightness set to 0 or 100 will be sent. Note that formatBeforePublish will be ignored for these values, in case your device uses a vastly different format for these special commands than it does for regular values.
  • on: An optional string (like "BRIGHT") that is recognized as on state. (ON will always be recognized.)
  • off: An optional string (like "DARK") that is recognized as off state. (OFF will always be recognized.)
This channel will publish the color as a comma-separated list to the MQTT broker, e.g. "112,54,123" for an RGB channel (0-255 per component) and "360,100,100" for a HSB channel (0-359 for hue and 0-100 for saturation and brightness).
# Channel Type "location"
The channel will publish the location as a comma-separated list to the MQTT broker, e.g. "112,54,123" for latitude, longitude, altitude. The altitude is optional.
# Channel Type "image"
The channel expects values on the corresponding MQTT topic to contain the binary data of a bmp, jpg, png or any other format that the installed Java runtime supports.
# Channel Type "datetime"
The channel will publish the date/time in the format "yyyy-MM-dd'T'HH:mm:ss", for example 2018-01-01T12:14:00. If you require another format, please use the formatter.
  • on: An optional string (like "Open") that is sent for the UP command.
  • off: An optional string (like "Close") that is sent for the DOWN command.
  • stop: An optional string (like "Stop") that is sent for the STOP command.
  • stopCommandTopic: An optional topic to send STOP commands to. If not set, STOP commands are sent to the main commandTopic.
If on, off, or stop are not defined, an explicit 0 or 100 will be sent for UP and DOWN respectively. STOP commands will be ignored entirely. Note that formatBeforePublish is applied to numeric positions (including the 0 or 100 sent for UP and DOWN without on/off), but not to the configured on, off and stop strings, in case your device uses a vastly different format for these special commands than it does for number values.
If you want to invert percentages or commands you can do this on the item link to this channel.
# Channel Type "player"
You can connect this channel to a Player item.
  • play: An optional string (like "Start") that is sent for the PLAY command and recognised as the PLAY state when received. Defaults to PLAY.
  • pause: An optional string (like "Halt") that is sent for the PAUSE command and recognised as the PAUSE state when received. Defaults to PAUSE.
  • next: An optional string (like "Skip") that is sent for the NEXT command and recognised as the NEXT command when received. Defaults to NEXT.
  • previous: An optional string (like "Back") that is sent for the PREVIOUS command and recognised as the PREVIOUS command when received. Defaults to PREVIOUS.
  • rewind: An optional string (like "RW") that is sent for the REWIND command and recognised as the REWIND state when received. Defaults to REWIND.
  • fastforward: An optional string (like "FF") that is sent for the FASTFORWARD command and recognised as the FASTFORWARD state when received. Defaults to FASTFORWARD.
Note that formatBeforePublish will be ignored for these values. Since NEXT and PREVIOUS are commands without a state, a received NEXT/PREVIOUS message is sent as a command to the linked item instead of updating its state.
Example (the BLE remote from openhab-core#4972 (opens new window)):
Thing mqtt:topic:bleremote "BLE Remote" (mqtt:broker:mybroker) {
        Type player : control "Control" [ commandTopic="ble/remote/set", play="PLAY", pause="PAUSE", next="NEXT", previous="PREV" ]
Player BLERemoteControl "BLE Remote" { channel="mqtt:topic:bleremote:control" }
# Rule Actions
val mqttActions = getActions("mqtt","mqtt:broker:myBroker")
where the first parameter always has to be mqtt and the second (mqtt:broker:myBroker) is the Thing UID of the broker that should be used. Once this action instance is retrieved, you can invoke the publishMQTT(String topic, String value, Boolean retained) method on it:
Alternatively, publishMQTT(String topic, byte[] value, Boolean retained) can publish a byte array data.
broker.things file:
mqtt:broker:myInsecureBroker [ host="192.168.0.42", secure=false ]
mqtt:broker:myAuthenticatedBroker [ host="192.168.0.43",secure=true, username="user", password="password" ]
mqtt.things file:
Bridge mqtt:broker:myInsecureBroker [ host="192.168.0.42", secure=false ]
Thing mqtt:topic:mything "mything" (mqtt:broker:myInsecureBroker) {
    Type color : lampcolor "Kitchen Lamp color" [ stateTopic="lamp/color", commandTopic="lamp/color/set", colorMode="RGB" ]
If the availability status is available, it can be configured to set the Thing status:
Thing mqtt:topic:bedroom1-switch (mqtt:broker:myInsecureBroker) [ availabilityTopic="tele/bedroom1-switch/LWT", payloadAvailable="Online", payloadNotAvailable="Offline" ] {
         Type switch : power [ stateTopic="stat/bedroom1-switch/RESULT", transformationPattern="REGEX((.*POWER.*))∩JSONPATH($.POWER)", commandTopic="cmnd/bedroom1-switch/POWER" ]
The transformation pattern can be chained using the intersection character "∩" as above, or by listing them separately:
         Type switch : power [ stateTopic="stat/bedroom1-switch/RESULT", transformationPattern="REGEX((.*POWER.*))","JSONPATH($.POWER)", commandTopic="cmnd/bedroom1-switch/POWER" ]
# Limitations
  • The HomeAssistant Fan components only support ON/OFF.
  • The HomeAssistant Cover components only support OPEN/CLOSE/STOP.
  • The HomeAssistant Light component does not support XY color changes.
  • The HomeAssistant Climate components are not yet supported.
# Value Transformations
Transformations can be applied to:
  • Incoming availability payload
  • Incoming value
  • Outgoing value
Transformations can be chained in the UI by listing each transformation on a separate line, or by separating them with the mathematical intersection character "∩". Transformations are defined using this syntax: TYPE(FUNCTION), e.g.: JSONPATH($.path). The syntax: TYPE:FUNCTION is still supported, e.g.: JSONPATH:$.path. Please note that the values will be discarded if one of the transformations failed (e.g. REGEX did not match) or returned null.
Received value Tr. Service Transformation
{device: {status: { temperature: 23.2 }}} JSONPATH JSONPATH($.device.status.temperature)
<device><status><temperature>23.2</temperature></status></device> XPath XPath(/device/status/temperature/text())
THEVALUE:23.2°C REGEX REGEX(:(.*?)°)
abc JS (UI defined) JS(config:js:35edb3735a)
abc JS (file based) JS(to_uppercase.js)
abc JS (inline) JS(\| input.toUpperCase() )
true MAP (UI defined) MAP(config:map:54facda0f7)
true MAP (file based) MAP(status.map)
true MAP (inline) MAP(\|true=ON;false=OFF)
All mentioned channels allow an optional transformation for outgoing values. Please prefer formatting as described in the next section whenever possible.
# Format before Publish
This feature is quite powerful in transforming an item state before it is published to the MQTT broker. It has the syntax: %[flags][width]conversion. Find the full documentation on the Java (opens new window) web page.
Here are a few examples:
  • All uppercase: "%S". Just use the upper case letter for the conversion argument.
  • Apply a prefix: "myprefix%s"
  • Apply a suffix: "%s suffix"
  • Number precision: ".4f" for a 4 digit precision. Use the "+" flag to always add a sign: "+.4f".
  • Decimal to Hexadecimal/Octal/Scientific: For example "60" with "%x", "%o", "%e" becomes "3C", "74", "60".
  • Date/Time: To reference the item state multiple times, use "%1$". Use the "tX" conversion where "X" can be any of [h,H,m,M,I,k,l,S,p,B,b,A,a,y,Y,d,e].
    • For an output of May 23, 1995 use "%1$tb %1$te,%1$tY".
    • For an output of 23.05.1995 use "%1$td.%1$tm.%1$tY".
    • For an output of 23:15 use "%1$tH:%1$tM".
Type Parameter Pattern Comment
string String "%s"
number BigDecimal "%f" The default will remove trailing zeros after the decimal point.
dimmer BigDecimal "%f" The default will remove trailing zeros after the decimal point.
switch String -- No pattern supported. Always on and off strings.
colorRGB BigDecimal, BigDecimal, BigDecimal "%1$d,%2$d,%3$d" Parameters are red, green and blue components.
colorHSB BigDecimal, BigDecimal, BigDecimal "%1$d,%2$d,%3$d" Parameters are hue, saturation and brightness components.
location BigDecimal, BigDecimal "%2$f,%3$f,%1$f" Parameters are altitude, latitude and longitude, altitude is only in default pattern, if value is not '0'.
image -- -- No publishing supported.
datetime ZonedDateTime "%1$tY-%1$tm-%1$tdT%1$tH:%1$tM:%1$tS.%1$tN" Trailing zeros of the nanoseconds are removed.
rollershutter Integer "%s" Integer percent value. Configured on, off, stop strings are sent unformatted.
player String -- No pattern supported. Always the play, pause, next, previous, rewind and fastforward strings.
  • If you get the error "No MQTT client": Please update your installation.
  • If you use the Mosquitto broker: Please be aware that there is a relatively low setting for retained messages. If at some point messages stop being delivered change the setting.
