# SolarForecast Binding
This binding provides data from Solar Forecast services. Use it to estimate your daily production, plan electric consumers like Electric Vehicle charging, heating or HVAC. Look ahead the next days in order to identify surplus / shortages in your energy planning.
Supported Services
Display Power values of Forecast and PV Inverter items
Solar Forecast Power Chart
Display Energy values of Forecast and PV inverter items Yellow line shows Daily Total Forecast.
Solar Forecast Energy Chart
Each service needs one xx-site for your location and at least one photovoltaic xx-plane.
Thing Type ID Label Subscription
sc-site Solcast service site definition yes (free)
sc-plane Solcast PV Plane yes (free)
fs-site Forecast Solar Site no
fs-plane Forecast Solar Plane no
adjustable-fs-site Adjustable Forecast Solar Site yes (paid)
adjustable-fs-plane Adjustable Forecast Solar Plane yes (paid)
smart-fs-site Smart Forecast Solar Site no
smart-fs-plane Smart Forecast Solar Plane no
# Solcast Configuration
Solcast service (opens new window) requires a personal registration with an e-mail address. A free version for your personal home PV system is available in Hobbyist Plan (opens new window) (Limited to 10 API requests per day). You need to configure your home photovoltaic system within the web interface. The resourceId for each PV plane is provided afterwards.
In order to receive proper timestamps double check your time zone in openHAB - Settings - Regional Settings. Correct time zone is necessary to show correct forecast times in UI.
# Solcast Bridge Configuration
Name Type Description Default Required Advanced
apiKey text API Key N/A yes no
timeZone text Time Zone of forecast location empty no yes
apiKey can be obtained in your Account Settings (opens new window)
timeZone can be left empty to evaluate Regional Settings of your openHAB installation. See DateTime section for more information.
# Solcast Plane Configuration
resourceId text Resource Id of Solcast rooftop site N/A yes no
refreshInterval integer Forecast Refresh Interval in minutes (0 = disable automatic refresh) 150 yes no
guessActuals boolean Guess actual forecast values instead of placing an API call true yes no
resourceId for each plane can be obtained in your Rooftop Sites (opens new window)
refreshInterval of forecast data needs to respect the throttling of the Solcast service.
With parameter guessActuals=true a plane needs 1 API call per update. If not 2 API calls per update are placed. A refresh interval of 150 minutes will result in approx 10 calls per day.
With refreshInterval = 0 the forecast data will not be updated by binding. This gives the user the possibility to define an own update strategy in rules. See manual update rule example to update Solcast forecast data
With boolean configuration guessActuals true the binding will take over the previous forecast data and use them as actual values. This will spare one API call. If set to false the 2 API calls are placed as in the previous versions.
# Solcast Channels
Each sc-plane reports its own values. The sc-site bridge sums up all attached sc-plane values and provides total forecast for your home location.
Channels are covering today's actual data with current, remaining and today's total prediction. Forecasts are delivered up to 6 days in advance. Scenarios are clustered in groups:
  • average scenario
  • pessimistic scenario: 10th percentile
  • optimistic scenario: 90th percentile
Channel Type Unit Description TimeSeries
power-estimate Number:Power W Power forecast for next hours/days X
energy-estimate Number:Energy kWh Energy forecast for next hours/days X
power-actual Number:Power W Power prediction for this moment
energy-actual Number:Energy kWh Today's forecast till now
energy-remain Number:Energy kWh Today's remaining forecast till sunset
energy-today Number:Energy kWh Today's forecast in total
For TimeSeries channels default RRD4j item persistence doesn't work. You need to to configure persistence service capable of storing future values like In Memory, InfluxDB or similar.
Technical channels observing the update behavior are reported in update group.
Channel Type Description
api-count String Number of requests send to Solcast API starting 0:00 UTC
latest-update DateTime Date and time of the latest forecast update
The api-count channel delivers a JSON object with 3 different counters:
  • 200 - succesful API calls
  • 429 - unsuccessful API calls due to throttling, too many calls
  • other - unsuccesful API calls due to other problems
{"200":2,"other":0,"429":0}
API Count Transformation Example
You can connect a Number item to this channel using a JSONPATH transformation (opens new window) referring the wanted JSON key e.g. $.200.
# ForecastSolar Configuration
ForecastSolar service (opens new window) provides a public free (opens new window) plan. You can try it without any registration or other preconditions.
# ForecastSolar Bridge Configuration
location text Location of Photovoltaic system. empty no
inverterKwp decimal Inverter Kilowatt Peak N/A no
apiKey text API Key N/A yes / no
location defines latitude, longitude values of your PV system. In case of empty the location configured in openHAB is obtained.
inverterKwp defines the maximum possible kilo watt capability of your inverter. Used if your installed plane kWp is greater than inverter kWp.
apiKey is mandatory for adjustable-fs-site commercial plan to calculate forecast adjustment by forecast.solar (opens new window). It's optional for fs-site and smart-fs-site but can be used for comparison of forecasts.
# ForecastSolar Plane Configuration
Following parameters are needed for each fs-plane.
refreshInterval integer Forecast Refresh Interval in minutes 30 yes false
declination integer Plane Declination: 0 for horizontal till 90 for vertical declination N/A yes false
azimuth integer Plane Azimuth: -180 = north, -90 = east, 0 = south, 90 = west, 180 = north N/A yes false
kwp decimal Installed Kilowatt Peak N/A yes false
refreshInterval of forecast data needs to respect the throttling of the ForecastSolar service. 12 calls per hour allowed from your caller IP address so for 2 planes lowest possible refresh rate is 10 minutes.
# Advanced Configuration
Advanced configuration parameters are available to fine tune your forecast data. Read linked documentation in order to know what you're doing.
dampAM decimal Damping factor of morning hours 0 no true
dampPM decimal Damping factor of evening hours 0 no true
horizon text Horizon definition as comma separated integer values N/A no true
Damping factors (opens new window) for morning and evening.
Horizon information (opens new window) as comma-separated integer list. This configuration item is aimed to expert users. You need to understand the horizon concept (opens new window). Shadow obstacles like mountains, hills, buildings can be expressed here. First step can be a download from PVGIS tool (opens new window) and downloading the terrain shadows. But it doesn't fit 100% to the required configuration. Currently there's no tool available which is providing the configuration information 1 to 1. So you need to know what you're doing.
# Energy Feedback Configuration
You can provide feedback of your energy production in order to correct the forecast of the current day. This is mandatory for adjustable-fs-plane and smart-fs-plane.
calculationItemName text Power or Energy item from your solar inverter for this plane N/A
calculationItemPersistence text Persistence service to query calculation item values N/A
holdingTime integer Time to wait in minutes from first prediction to adjust forecast 120
Strict requirement for calculationItemName type is Number:Poweror Number:Energy. Values without unit will be rejected.
The name calculationItemName shall be the calculation item directly corresponding to this plane. Check if this item is frequently updated and not e.g. 15 minutes behind because this will have a negative impact on the forecast correction.
The calculationItemPersistence shall point to the persistence service storing the calculation item values. All installed persistence services are given as options.
Parameter holdingTime defines the time between the first forecast prediction and when corrections shall start. The correction shall not start at early stages. Rationale: If correction starts too early values may differ a lot. E.g. forecast predicts 0.1 kWh but real production is 0.001 kWh results into massive correction factors (opens new window).
# ForecastSolar Channels
Each fs-plane reports its own values. The fs-site bridge sums up all attached fs-plane values and provides the total forecast for your home location.
Channels are covering today's actual data with current, remaining and total prediction. Forecasts are delivered up to 3 days for paid personal plans.
For TimeSeries channels default RR4Dj item persistence doesn't work. You need to to configure persistence service capable of storing future values like In Memory, InfluxDB or similar.
# Correction Channel
In case of smart-fs-site and smart-fs-plane the correction factor is shown.
correction-factor Number Factor of forecast correction. Less than one - down correction, otherwise up correction.
# Thing Actions
All things sc-site, sc-plane, fs-site and fs-plane are providing the same Actions. Channels are providing actual forecast data and daily forecasts in future. Actions provides an interface to execute more sophisticated handling in rules. You can execute this for each xx-plane for specific plane values or xx-site to sum up all attached planes.
See Date Time section for more information. Double check your time zone in openHAB -> Settings -> Regional Settings which is crucial for calculation.
# getForecastBegin
Returns Instant of the earliest possible forecast data available. It's located in the past, e.g. Solcast provides data from the last 7 days. Instant.MAX is returned in case of no forecast data is available.
# getForecastEnd
Returns Instant of the latest possible forecast data available. Instant.MIN is returned in case of no forecast data is available.
# getPower
Parameter Type Description
timestamp Instant Timestamp of power query
mode String Choose average, optimistic or pessimistic to select forecast scenario. Only Solcast.
Returns QuantityType<Power> at the given Instant timestamp. Respect getForecastBegin and getForecastEnd to get a valid value.
Check log or catch exceptions for error handling
  • IllegalArgumentException thrown in case of problems with call arguments
  • SolarForecastException thrown in case of problems with timestamp and available forecast data
# getEnergyOfDay
date LocalDate Date of the day
Returns QuantityType<Energy> at the given localDate. Respect getForecastBegin and getForecastEnd to avoid ambiguous values.
# getEnergy
startTimestamp Instant Start timestamp of energy query
endTimestamp Instant End timestamp of energy query
mode String Choose optimistic or pessimistic to get values for a positive or negative future scenario. Only Solcast.
Returns QuantityType<Energy> between the timestamps startTimestamp and endTimestamp. Respect getForecastBegin and getForecastEnd to avoid ambiguous values.
# Date Time
Each forecast is bound to a certain location which automatically defines the time zone. Most common use case is forecast and your location are matching the same time zone. Action interface is using Instant as timestamps which enables you translating to any time zone. This allows you with an easy conversion to query also foreign forecast locations.
Examples are showing
  • how to translate Instant to ZonedDateTime objects and
  • how to translate ZonedDateTime to Instant objects
# Forecast Solar Example
# Thing file
Bridge solarforecast:fs-site:homeSite   "ForecastSolar Home" [ location="54.321,8.976"] {
         Thing fs-plane homeSouthWest   "ForecastSolar Home South-West" [ refreshInterval=15, azimuth=45, declination=35, kwp=5.5]
         Thing fs-plane homeNorthEast   "ForecastSolar Home North-East" [ refreshInterval=15, azimuth=-145, declination=35, kwp=4.425]
# Items file
// channel items
Number:Power     ForecastSolarHome_Actual_Power          "Power prediction for this moment"                           {channel="solarforecast:fs-site:homeSite:power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    ForecastSolarHome_Actual                "Today's forecast till now"                                  {channel="solarforecast:fs-site:homeSite:energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    ForecastSolarHome_Remaining             "Today's remaining forecast till sunset"                     {channel="solarforecast:fs-site:homeSite:energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    ForecastSolarHome_Today                 "Today's total energy forecast"                              {channel="solarforecast:fs-site:homeSite:energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// calculated by rule
Number:Energy    ForecastSolarHome_Tomorrow              "Tomorrow's total energy forecast"                           {stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
Number:Power     ForecastSolarHome_Actual_Power_NE       "NE Power prediction for this moment"                        {channel="solarforecast:fs-plane:homeSite:homeNorthEast:power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    ForecastSolarHome_Actual_NE             "NE Today's forecast till now"                               {channel="solarforecast:fs-plane:homeSite:homeNorthEast:energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    ForecastSolarHome_Remaining_NE          "NE Today's remaining forecast till sunset"                  {channel="solarforecast:fs-plane:homeSite:homeNorthEast:energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    ForecastSolarHome_Today_NE              "NE Today's total energy forecast"                           {channel="solarforecast:fs-plane:homeSite:homeNorthEast:energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
Number:Power     ForecastSolarHome_Actual_Power_SW       "SW Power prediction for this moment"                        {channel="solarforecast:fs-plane:homeSite:homeSouthWest:power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    ForecastSolarHome_Actual_SW             "SW Today's forecast till now"                               {channel="solarforecast:fs-plane:homeSite:homeSouthWest:energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    ForecastSolarHome_Remaining_SW          "SW Today's remaining forecast till sunset"                  {channel="solarforecast:fs-plane:homeSite:homeSouthWest:energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    ForecastSolarHome_Today_SW              "SW Today's total energy forecast"                           {channel="solarforecast:fs-plane:homeSite:homeSouthWest:energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// estimation items
Group            influxdb
Number:Power     ForecastSolarHome_Power_Estimate        "Power estimations"                            (influxdb)    {channel="solarforecast:fs-site:homeSite:power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    ForecastSolarHome_Energy_Estimate       "Energy estimations"                           (influxdb)    {channel="solarforecast:fs-site:homeSite:energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Power     ForecastSolarHome_Power_Estimate_SW     "SW Power estimations"                         (influxdb)    {channel="solarforecast:fs-plane:homeSite:homeSouthWest:power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    ForecastSolarHome_Energy_Estimate_SW    "SW Energy estimations"                        (influxdb)    {channel="solarforecast:fs-plane:homeSite:homeSouthWest:energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
# Solcast Example
# Thing file
Bridge solarforecast:sc-site:homeSite   "Solcast Site" [ apiKey="KEY"] {
         Thing sc-plane planeSouthWest  "Solcast Plane South-West" [ resourceId="ID", refreshInterval=150, guessActuals=true]
# Items file
// site items for average forecast
Number:Power     Solcast_Site_Average_Actual_Power            "Power prediction for this moment"                                       {channel="solarforecast:sc-site:homeSite:average#power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Site_Average_Actual                  "Today's forecast till now"                                              {channel="solarforecast:sc-site:homeSite:average#energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Site_Average_Remaining               "Today's remaining forecast till sunset"                                 {channel="solarforecast:sc-site:homeSite:average#energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Site_Average_Today                   "Today's total energy forecast"                                          {channel="solarforecast:sc-site:homeSite:average#energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// site items for optimistic forecast
Number:Power     Solcast_Site_Optimistic_Actual_Power         "Power prediction for this moment"                                       {channel="solarforecast:sc-site:homeSite:optimistic#power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Site_Optimistic_Actual               "Today's forecast till now"                                              {channel="solarforecast:sc-site:homeSite:optimistic#energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Site_Optimistic_Remaining            "Today's remaining forecast till sunset"                                 {channel="solarforecast:sc-site:homeSite:optimistic#energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Site_Optimistic_Today                "Today's total energy forecast"                                          {channel="solarforecast:sc-site:homeSite:optimistic#energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// site items for pessimistic forecast
Number:Power     Solcast_Site_Pessimistic_Actual_Power        "Power prediction for this moment"                                       {channel="solarforecast:sc-site:homeSite:pessimistic#power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Site_Pessimistic_Actual              "Today's forecast till now"                                              {channel="solarforecast:sc-site:homeSite:pessimistic#energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Site_Pessimistic_Remaining           "Today's remaining forecast till sunset"                                 {channel="solarforecast:sc-site:homeSite:pessimistic#energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Site_Pessimistic_Today               "Today's total energy forecast"                                          {channel="solarforecast:sc-site:homeSite:pessimistic#energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// site API call counter
Number           Solcast_Site_API_Sucess_Counter              "Site API Counter"                                                       {channel="solarforecast:sc-site:homeSite:update#api-count" [ profile="transform:JSONPATH", function="$.200"]}
Number           Solcast_Site_API_Throttle_Counter            "Site API Throttle Counter"                                              {channel="solarforecast:sc-site:homeSite:update#api-count" [ profile="transform:JSONPATH", function="$.429"]}
Number           Solcast_Site_API_Error_Counter               "Site API ErrorCounter"                                                  {channel="solarforecast:sc-site:homeSite:update#api-count" [ profile="transform:JSONPATH", function="$.other"]}
DateTime         Solcast_Site_API_LastUpdate                  "Site API Last Update"                                                   {channel="solarforecast:sc-site:homeSite:update#latest-update"}
// estimation items
Group            influxdb
Number:Power     Solcast_Site_Average_Power_Estimate          "Site Average Power estimations"                           (influxdb)    {channel="solarforecast:sc-site:homeSite:average#power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Site_Average_Energy_Estimate         "Site Average Energy estimations"                          (influxdb)    {channel="solarforecast:sc-site:homeSite:average#energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Power     Solcast_Site_Optimistic_Power_Estimate       "Site Optimistic Power estimations"                        (influxdb)    {channel="solarforecast:sc-site:homeSite:optimistic#power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Site_Optimistic_Energy_Estimate      "Site Optimistic estimations"                              (influxdb)    {channel="solarforecast:sc-site:homeSite:optimistic#energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Power     Solcast_Site_Pessimistic_Power_Estimate      "Site Pessimistic Power estimations"                       (influxdb)    {channel="solarforecast:sc-site:homeSite:pessimistic#power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Site_Pessimistic_Energy_Estimate     "Site Pessimistic Energy estimations"                      (influxdb)    {channel="solarforecast:sc-site:homeSite:pessimistic#energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
// plane items average
Number:Power     Solcast_Plane_Average_Actual_Power_SW        "SW Power prediction for this moment"                                    {channel="solarforecast:sc-plane:homeSite:planeSouthWest:average#power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Plane_Average_Actual_SW              "SW Today's forecast till now"                                           {channel="solarforecast:sc-plane:homeSite:planeSouthWest:average#energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Plane_Average_Remaining_SW           "SW Today's remaining forecast till sunset"                              {channel="solarforecast:sc-plane:homeSite:planeSouthWest:average#energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Plane_Average_Today_SW               "SW Today's total energy forecast"                                       {channel="solarforecast:sc-plane:homeSite:planeSouthWest:average#energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// plane items optimistic
Number:Power     Solcast_Plane_Optimistic_Actual_Power_SW     "SW Power optimistic prediction for this moment"                         {channel="solarforecast:sc-plane:homeSite:planeSouthWest:optimistic#power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Plane_Optimistic_Actual_SW           "SW Today's optimistic forecast till now"                                {channel="solarforecast:sc-plane:homeSite:planeSouthWest:optimistic#energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Plane_Optimistic_Remaining_SW        "SW Today's optimistic remaining forecast till sunset"                   {channel="solarforecast:sc-plane:homeSite:planeSouthWest:optimistic#energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Plane_Optimistic_Today_SW            "SW Today's optimistic total energy forecast"                            {channel="solarforecast:sc-plane:homeSite:planeSouthWest:optimistic#energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// plane items pessimistic
Number:Power     Solcast_Plane_Pessimistic_Actual_Power_SW    "SW Power pessimistic prediction for this moment"                        {channel="solarforecast:sc-plane:homeSite:planeSouthWest:pessimistic#power-actual", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Plane_Pessimistic_Actual_SW          "SW Today's pessimistic forecast till now"                               {channel="solarforecast:sc-plane:homeSite:planeSouthWest:pessimistic#energy-actual", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Plane_Pessimistic_Remaining_SW       "SW Today's pessimistic remaining forecast till sunset"                  {channel="solarforecast:sc-plane:homeSite:planeSouthWest:pessimistic#energy-remain", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Energy    Solcast_Plane_Pessimistic_Today_SW           "SW Today's pessimistic total energy forecast"                           {channel="solarforecast:sc-plane:homeSite:planeSouthWest:pessimistic#energy-today", stateDescription=" "[ pattern="%.1f %unit%" ], unit="kWh"}
// plane API call counter
Number           Solcast_Plane_API_Sucess_Counter             "Plane API Counter"                                                      {channel="solarforecast:sc-plane:homeSite:planeSouthWest:update#api-count" [ profile="transform:JSONPATH", function="$.200"]}
Number           Solcast_Plane_API_Throttle_Counter           "Plane API Throttle Counter"                                             {channel="solarforecast:sc-plane:homeSite:planeSouthWest:update#api-count" [ profile="transform:JSONPATH", function="$.429"]}
Number           Solcast_Plane_API_Error_Counter              "Plane API ErrorCounter"                                                 {channel="solarforecast:sc-plane:homeSite:planeSouthWest:update#api-count" [ profile="transform:JSONPATH", function="$.other"]}
DateTime         Solcast_Plane_API_LastUpdate                 "Plane API Last Update"                                                  {channel="solarforecast:sc-plane:homeSite:planeSouthWest:update#latest-update"}
// plane estimation items
Number:Power     Solcast_Plane_Average_Power_Estimate         "Plane Average Power estimations"                          (influxdb)    {channel="solarforecast:sc-plane:homeSite:planeSouthWest:average#power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Plane_Average_Energy_Estimate        "Plane Average Energy estimations"                         (influxdb)    {channel="solarforecast:sc-plane:homeSite:planeSouthWest:average#energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Power     Solcast_Plane_Optimistic_Power_Estimate      "Plane Optiisitc Power estimations"                        (influxdb)    {channel="solarforecast:sc-plane:homeSite:planeSouthWest:optimistic#power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Plane_Optimistic_Energy_Estimate     "Plane Optiisitc Energy estimations"                       (influxdb)    {channel="solarforecast:sc-plane:homeSite:planeSouthWest:optimistic#energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
Number:Power     Solcast_Plane_Pessimistic_Power_Estimate     "Plane Pessimistic Power estimations"                      (influxdb)    {channel="solarforecast:sc-plane:homeSite:planeSouthWest:pessimistic#power-estimate", stateDescription=" "[ pattern="%.0f %unit%" ], unit="W"}
Number:Energy    Solcast_Plane_Pessimistic_Energy_Estimate    "Plane Pessimistic Energy estimations"                     (influxdb)    {channel="solarforecast:sc-plane:homeSite:planeSouthWest:pessimistic#energy-estimate", stateDescription=" "[ pattern="%.3f %unit%" ], unit="kWh"}
# Persistence file
// persistence strategies have a name and definition and are referred to in the "Items" section
Strategies {
        everyHour : "0 0 * * * ?"
        everyDay  : "0 0 0 * * ?"
 * Each line in this section defines for which Item(s) which strategy(ies) should be applied.
 * You can list single items, use "*" for all items or "groupitem*" for all members of a group
 * Item (excl. the group Item itself).
Items {
        influxdb* : strategy = restoreOnStartup, forecast
# Actions rule
rule "Tomorrow Forecast Calculation"
        Item ForecastSolarHome_Today received update
        val solarforecastActions = getActions("solarforecast","solarforecast:fs-site:homeSite")
        val energyState = solarforecastActions.getEnergyOfDay(LocalDate.now.plusDays(1))
        logInfo("SF Tests","{}",energyState)
        ForecastSolarHome_Tomorrow.postUpdate(energyState)
# Handle exceptions
import java.time.temporal.ChronoUnit
rule "Exception Handling"
        System started
        val solcastActions = getActions("solarforecast","solarforecast:sc-site:homeSite")
        try {
            val forecast = solcastActions.getPower(solcastActions.getForecastEnd.plus(30,ChronoUnit.MINUTES))
        } catch(RuntimeException e) {
            logError("Exception","Handle {}",e.getMessage)
# Actions rule with Arguments
rule "Solcast Actions"
        Time cron "0 0 23 * * ?" // trigger whatever you like
        // Query forecast via Actions
        val solarforecastActions = getActions("solarforecast","solarforecast:sc-site:homeSite")
        val startTimestamp = Instant.now
        val endTimestamp = Instant.now.plus(6, ChronoUnit.DAYS)
        val sixDayForecast = solarforecastActions.getEnergy(startTimestamp,endTimestamp)
        logInfo("SF Tests","Forecast Average 6 days "+ sixDayForecast)
        val sixDayOptimistic = solarforecastActions.getEnergy(startTimestamp,endTimestamp, "optimistic")
        logInfo("SF Tests","Forecast Optimist 6 days "+ sixDayOptimistic)
        val sixDayPessimistic = solarforecastActions.getEnergy(startTimestamp,endTimestamp, "pessimistic")
        logInfo("SF Tests","Forecast Pessimist 6 days "+ sixDayPessimistic)
        // Query forecast TimesSeries Items via persistedState
        val energyAverage =  (Solcast_Site_Average_Energyestimate.persistedState(now.plusDays(1)).state as Number)
        logInfo("SF Tests","Average energy {}",energyAverage)
        val energyOptimistic =  (Solcast_Site_Optimistic_Energyestimate.persistedState(now.plusDays(1)).state as Number)
        logInfo("SF Tests","Optimist energy {}",energyOptimistic)
# Solcast manual update
rule "Daylight End"
        Channel "astro:sun:local:daylight#event" triggered END
        PV_Daytime.postUpdate(OFF) // switch item holding daytime state
rule "Daylight Start"
        Channel "astro:sun:local:daylight#event" triggered START
        PV_Daytime.postUpdate(ON)
rule "Solacast Updates"
        Thing "solarforecast:sc-plane:homeSite:homeSouthWest" changed to INITIALIZING or // Thing status changed to INITIALIZING
        Time cron "0 30 0/2 ? * * *" // every 2 hours at minute 30
        if(PV_Daytime.state == ON) {
            val solarforecastActions = getActions("solarforecast","solarforecast:sc-plane:homeSite:homeSouthWest")
            solarforecastActions.triggerUpdate
        } // reject updates during night
