  • Calling Rules or other scripts either located as files on the server or provided via the UI
  • Retrieving attributes provided by the rule context or from the own caller rule.
  • Transforming values via different conversion methods (map, regex, jsonpath)
# Overview of the Run & Process blocks
run-and-process-blocks
# Run & Process Blocks
See also the short video part about youtube Run & Process blocks, transform (opens new window)
# Call Script File
run-script-file
  • No parameters can be provided
See openHAB Call-Script (opens new window) for background information
# Run Rule or Script created in UI
run-rule-or-script
The ruleUID can be found in the list of rules or scripts in the second line of the list (like here helloBlockly or helloWorld) rule-uuid
Parameters are optional:
Notes:
  • parameters can be retrieved in the called script via the "get context attribute"-block (see below)
  • the called rule / script cannot return any value
  • it is not possible to access a particular function in another script or rule as scripts / rules have to be perceived as completely autonomous
  • the called rule / script is run synchronously
# Retrieve context attribute from rule
retrieve-context
retrieve-context-example
# Retrieve rule context information
retrieve-context-info
Here is a list of possible values that can be retrieved.
  • rule UID - String
  • event available - Boolean
  • event type - String
  • new state of item - String / Number by selection
  • previous state of item - String / Number by selection
  • triggering item name - Item, not a String
  • received command - String / Number by selection
  • triggered channel - String
  • triggered event - String
Note on "event available": All values except rule UID expect an event context to be available. Thus, to avoid issues, you can validate that with the event available block in case this is not guaranteed in your rule.
The block adds a selection drop down in case a state or command is returned:
blockly-context-number-string
# Transform values via Map, Regex or JsonPath and others
openHAB provides many transformations (opens new window):
map regex jsonpath
# Example 1: Regex
transform-regex
# Example 2: JsonPath transformation
by using the jsonpath
$.device.status.temperature
transform-jsonpath
# Example 3: Map transformation
transform-map
ON=Ja
OFF=Nein
effects=Effekte
NULL=n/a
hs = Hue/Saturation
ct = Color Temperature
Hue/Saturation
# Inline Script
inline-script
# Example
inline-script-example
See also the short video part about youtube Inline Scripts (opens new window)
