Value Storage
Introduction
- The values are persisted as a part of the instance of the rule
- Modifying the rule during development creates a new instance which means the value is reset.
- Restarting openHAB creates a new rule instance which also means the value is reset
- In most cases both situations are negligible for many rules.
- If you need full persistence of values that can be used across rules you need to persist the value in one of the persistence engines like MapDB
- By default the value is undefined. To check if a value is undefined, use the special "is undefined"-block
Overview of the Value Storage blocks
Caching
Since openHAB 4.0 caching functionality was introduced (provided that the rule is using GraalJS / JS Scripting). The blocks have the same behaviour like before when set to "private cache" which means that the value is stores in the rule cache. When storing a value in the "shared cache" the value can be even used beyond the specific rule in a different rule.
Value Storage Blocks
See also the short video part about Global Value Storage
Store Value
openHAB 4.0
Function: Stores a value under the key name in the specified cache.
Get Stored Value
Since openHAB 4.0:
Function: Retrieves a stored value by the key name from the specified cache.
Check if Value is undefined
Since openHAB 4.0:
Function: Checks if a value is undefined in the specified cache
Example 1: Initialize a key if not set
Example 2: Use the rule instance variable to remember a color that has been set
