# Logic
One of the most commonly used standard blocks are conditions blocks.
More about conditions can be viewed at  How to use IF and ELSE (opens new window).
A specific block that was added by openHAB is the UNDEFINED-Block which allows better comparison of undefined values.
Here is an example on how to use it:
# Math
The Math section mainly consists of standard Blockly blocks. Two new math blocks were added for bitwise operations:
# Quantity Type support
Blockly allows to use Quantity types to do its math operations. This means that Quantity States can directly be used as an input for math operation blocks.
Here are some examples for math operations with unit-accompanied values:
Note that there is a special case on min/max if the inputs are not of equal type. In this case an error will be shown to the user:
# Bitwise operators
- bitwise and &
 - bitwise or |
 - bitwise xor ^
 - bitwise left shift <<
 - bitwise right shift >>
 - bitwise unary right shift >>>
# Bitwise invert
Function: The bitwise NOT (~) operator inverts the bits of its operand.
# Rounding
The standard block has been extended to provide a rounding function with the ability to set the number of decimal places:
# Parse Number
This blocks takes a String floating point number representation and converts it into a Number type block.
# Text
More about that topic can be viewed at  Working with Text-Blocks (opens new window).
# CRLF
# Text Replace
Function: Allows to replace something that is defined by the pattern in the origin-text with what is provided in replacement. Note that the pattern can be just a text or also regex expression.
# Colors
More about that topic can be viewed at  Using Color-Blocks and HSB-Conversion (opens new window)
Blockly supports the following use cases:
- pick a color to return the value as an RGB type
 - chose a random color as RGB type
 - define an RGB color based on red, green and blue.
 - blend two colors with a ratio - this block can be used to dynamically transition from one color to the other by applying the ratio as a computed value in a rule.
 - calculate the HSB value of the RGB value
 - get hue, saturation or brightness from a HSB Type Color Status of an Item
# Color Picker
# Random Color
# Create RGB color
# Blend two colors
this could be used for example with a loop that changes the ratio from 0 to 1 to blend the first color into a second
- use that block and connect one of the above blocks into that one to be able to retrieve the HSB value of that block.
# Retrieve indidivual HSB values from an Item state
This block allows to retrieve the individual values of an Item’s HSB color state by returning
- Hue,
 - Saturation,
 - or Brightness
# Lists
# Loop over a dictionary
This block can be found in the Loops section and is a dedicated block that allows to iterate over the elements of a dictionary. The loop provides the value into the variable that was choosen in the drop down. See the examples below how the loop can be used.
Either the dictionary itself can be provided directly or via a variable.
# Concatenate lists
Function: adds the second list to the first list and returns a new list
# Loops
Even though there a no specialized openHAB blocks provided, loops are used rather often.
Therefore, there is a good introduction to loops available which can be viewed at  Loops in Blockly (opens new window).
# Functions
A more advanced feature for reusable blockly code is functions.
More about that topic can be viewed at  Functions (opens new window) and Parameters (opens new window).
