Skip to content
Run & Process (Rules and Scripts) ​
Introduction ​
  • Calling Rules or other scripts either located as files on the server or provided via the UI
  • Retrieving attributes provided by the rule context or from the own caller rule.
  • Transforming values via different conversion methods (map, regex, jsonpath)
Overview of the Run & Process blocks ​
run-and-process-blocks
Run & Process Blocks ​
See also the short video part about youtube Run & Process blocks, transform
Call Script File ​
run-script-file
  • No parameters can be provided
See openHAB Call-Script for background information
Run Rule or Script created in UI ​
run-rule-or-script
The ruleUID can be found in the list of rules or scripts in the second line of the list (like here helloBlockly or helloWorld) rule-uuid
Parameters are optional:
  • If not providing parameters leave the with context section as is.
  • If providing parameters you must replace the create empty dictionary block with the dictionary block from the Lists section, modifying the number of key/value pairs to suit.
Notes:
  • parameters can be retrieved in the called script via the "get context attribute"-block (see below)
  • the called rule / script cannot return any value
  • it is not possible to access a particular function in another script or rule as scripts / rules have to be perceived as completely autonomous
  • the called rule / script is run synchronously
Retrieve context attribute from rule ​
retrieve-context
retrieve-context-example
Retrieve rule context information ​
retrieve-context-info
  • The rule trigger type defines which of the attributes are available to the rule - the types available depend on the trigger type of the rule.
  • For more detailed information see UI Event Object or openHAB Events.
Here is a list of possible values that can be retrieved.
  • rule UID - String
  • event available - Boolean
  • event type - String
  • new state of item - String / Number by selection
  • previous state of item - String / Number by selection
  • triggering item name - Item, not a String
  • received command - String / Number by selection
  • triggered channel - String
  • triggered event - String
Note on "event available": All values except rule UID expect an event context to be available. Thus, to avoid issues, you can validate that with the event available block in case this is not guaranteed in your rule.
The block adds a selection drop down in case a state or command is returned:
blockly-context-number-string
Transform values via Map, Regex or JsonPath and others ​
openHAB provides many transformations:
mapregexjsonpath
Example 1: Regex ​
transform-regex
Example 2: JsonPath transformation ​
json
by using the jsonpath
json
$.device.status.temperature
transform-jsonpath
Example 3: Map transformation ​
transform-map
dsl
ON=Ja
OFF=Nein
effects=Effekte
NULL=n/a
hs = Hue/Saturation
ct = Color Temperature
bash
Hue/Saturation
Inline Script ​
inline-script
Example ​
inline-script-example
See also the short video part about youtube Inline Scripts
Return to Blockly Reference ​
