# Google Assistant Action
Please be aware that the graphical user interface in the Google Home app or on Google Nest devices may not fully support interaction with some of the supported device types. We cannot influence this and rely on Google to implement user interfaces for more devices. Nevertheless, interaction via voice or in writing with Google Assistant should always work.
# Latest Changes
State of this document
This documentation refers to release v5.0.2 (opens new window) of openHAB Google Assistant (opens new window) published on 2025-12-21
# v5.0.1
  • Added Humidifier device type with humidity control and fan speed support
  • Added extended Vacuum device with dock, locate, battery status and cycle information
  • Added Rotation trait (opens new window) support to Awning, Blinds, Curtain, Pergola and Shutter devices
# v4.1.0
  • Added queryOnly=true option to Switch devices indicating that the device can only be queried for state information and not be controlled
# v4.0.0
  • Breaking Changes
    • Group members are now stored in customData. This means existing (group) devices will only work after a new SYNC
    • The modes configuration for Thermostats has been renamed to thermostatModes
    • The speeds configuration for Fans will be renamed to fanSpeeds
    • As item types of group members will then be validated, users might see devices disappearing in Google Home if they used an unsupported item within a group device
    • Please take a look at Migration Guide (opens new window) and check your configuration against the new constraints
  • More details and other changes
    • Item names for group members will be stored in customData to save a query request to openHAB when executing commands
      • For commands that need the current state the query request is still needed (thermostat commands or relative volume)
      • Also some other configuration options are stored in customData
      • Item types of group members will now be validated
    • Add a lot of new functionality to Fan devices (AirPurifier, Fan, Hood)
      • OnOff (separate power switch if used as a group)
      • FanSpeed (separate fan speed if used as a group)
      • Modes (yes, for the first time modes are available)
      • SensorState (for FilterLifeTime and PM2.5 - no clue how to query those)
    • Add AC Unit device
      • Basically just a combination of the extended Fan and the Thermostat with all control and config options of both
  • Potential Issues
    • As customData is limited to 512 bytes it could be an issue to store very long item names e.g. for devices with a lot of members like thermostat
# v3.9.0
  • Prepared available configuration options for the upcoming rollout of v4
  • Users can start adjusting their setup to use the new configuration options:
    • Thermostat: modes has been renamed to thermostatModes
    • Fan: speeds has been renamed to fanSpeeds
# v3.8.0
  • Added colorTemperatureInverted=true option to SpecialColorLight allowing users to invert the percentage to Kelvin conversion for the lightColorTemperature item
# v3.7.0
  • Adjusted Fan to use supportsFanSpeedPercent option
  • Inverted lightColorTemperature percentage range when using colorUnit="percent" with SpecialColorLight
# v3.6.0
# v3.5.0
  • ga="light" for SpecialColorLight is replaced by ga="specialcolorlight"
  • useKelvin=true is replaced by colorUnit="kelvin"
  • Support for color temperature in Mired added
# General Configuration
# Switch
Device Type Switch (opens new window)
Supported Traits OnOff (opens new window)
Supported Items Switch
Configuration (optional) queryOnly=true/false
(optional) inverted=true/false
(optional) checkState=true/false
# Light
Device Type Light (opens new window)
Supported Traits OnOff (opens new window), ColorSetting (opens new window), Brightness (opens new window) (depending on used item type)
Supported Items Switch, Dimmer, Color
Configuration (optional) inverted=true/false
(optional) colorTemperatureRange="minK,maxK"
Dimmer { ga="Light" }
Color  { ga="Light" [ colorTemperatureRange="2000,9000" ] }
# Light as Group with separate controls
Supported Items Group as SpecialColorLight with the following members:
(optional) Number or Dimmer as lightBrightness
(optional) Number or Dimmer as lightColorTemperature
(optional) Color as lightColor
(optional) Switch as lightPower
Configuration (optional) colorUnit="percent/kelvin/mired"
(optional) colorTemperatureInverted=true/false
Important Hint: If you want to use lightColorTemperature, you must either set colorUnit to kelvin or mired or define a colorTemperatureRange, because colorUnit defaults to percent.
If you use colorUnit as percentage values, the lowest color temperature (warm light) will be converted to 0%, and correspondingly the highest color temperature (cold light) will be converted to 100%. If you need the inverted values for your device, you can set colorTemperatureInverted=true. This will convert low Kelvin values to high percentage values and vice versa.
Group  lightGroup { ga="SpecialColorLight" [ colorUnit="kelvin", colorTemperatureRange="2000,9000" ] }
Switch powerItem            (lightGroup) { ga="lightPower" }
Dimmer brightnessItem       (lightGroup) { ga="lightBrightness" }
Color  colorItem            (lightGroup) { ga="lightColor" }
Example of a light device where low Kelvin values (warm light) are represented by high percentage values in the color temperature item:
Group  lightGroup { ga="SpecialColorLight" [ colorUnit="percent", colorTemperatureRange="2000,6500", colorTemperatureInverted=true ] }
Dimmer colorTemperatureItem (lightGroup) { ga="lightColorTemperature" }
In case you want to control multiple lights using one device with Google Assistant, you can apply the following pattern:
Group:Switch powerItems      (lightGroup) { ga="lightPower" }
Group:Dimmer brightnessItems (lightGroup) { ga="lightBrightness" }
Group:Color  colorItems      (lightGroup) { ga="lightColor" }
Switch powerItem1            (powerItems)
Switch powerItem2            (powerItems)
Dimmer brightnessItem1       (brightnessItems)
Dimmer brightnessItem2       (brightnessItems)
Color colorItem1             (colorItems)
Color colorItem2             (colorItems)
# Scene
Device Type Scene (opens new window)
Supported Traits Scene (opens new window)
Configuration (optional) sceneReversible=true/false
Device Type Outlet (opens new window), Coffee_Maker (opens new window), WaterHeater (opens new window), Fireplace (opens new window)
Switch { ga="Fireplace" }
# Valve
Device Type Valve (opens new window)
Supported Traits OpenClose (opens new window)
# Sprinkler, Vacuum, Washer, Dishwasher
Device Type Sprinkler (opens new window), Vacuum (opens new window)
Supported Traits StartStop (opens new window)
Switch { ga="Washer" [ inverted=false ] }
Switch { ga="Dishwasher" [ inverted=false ] }
# Vacuum as Group with advanced functionality
Device Type Vacuum (opens new window)
Supported Traits StartStop (opens new window), Dock (opens new window), Locator (opens new window), RunCycle (opens new window), EnergyStorage (opens new window)
Supported Items Group as Vacuum with the following members:
(required) Switch as vacuumPower
(optional) Switch as vacuumDock
(optional) Switch as vacuumLocate
(optional) Number or Dimmer as vacuumBattery
(optional) String as vacuumCurrentCycle
Group  vacuumRobot { ga="Vacuum" [ checkState=true ] }
Switch vacuumPowerItem     (vacuumRobot) { ga="vacuumPower" }
Switch vacuumDockItem      (vacuumRobot) { ga="vacuumDock" }
Switch vacuumLocateItem    (vacuumRobot) { ga="vacuumLocate" }
Number vacuumBatteryItem   (vacuumRobot) { ga="vacuumBattery" }
String vacuumCycleItem     (vacuumRobot) { ga="vacuumCurrentCycle" }
# Lock
Device Type Lock (opens new window)
Supported Traits LockUnlock (opens new window)
Supported Items Contact (no device control), Switch
(optional) ackNeeded=true/false
(optional) pinNeeded="1234"
# SecuritySystem as Switch
Device Type SecuritySystem (opens new window)
Supported Traits ArmDisarm (opens new window)
(optional) pinOnDisarmOnly=true/false
(optional) waitForStateChange="2"
See SecuritySystem as Group for explanation on the configuration options.
StatusReport (opens new window)
Supported Items Group as SecuritySystem with the following members:
Switch as securitySystemArmed
(optional) String as securitySystemArmLevel
(optional) Switch as securitySystemTrouble
(optional) String as securitySystemTroubleCode
(optional) Contact as securitySystemZone
(optional) armLevels="L1=Level 1,L2=Level 2"
Specifically on Zone Contacts:
(required) zoneType="OpenClose/Motion"
(optional) blocking=true/false
Configuring the SecuritySystem as a Group will enable a lot of advanced functionality.
The Switch and the Group configuration support the following configuration parameters:
  • checkState=true will compare the current state with the requested one and responds accordingly.
  • ackNeeded=true will request an acknowledgement before performing an action.
  • pinNeeded="1234" will request and check the configured PIN before performing an action.
  • pinOnDisarmOnly=true will enforce the PIN on disarming only. Arming will be done without the PIN.
  • waitForStateChange=0 defines the number of seconds to wait for the security system state to update before checking that the arm/disarm was successful. Defaults to 0 if not specified.
armLevels="Key=Label" - The label is used for commanding Google Assistant, the key is the matching value sent to openHAB.
When using arm levels, Google will send the mapped level ID (L1,L2 in below example) to the item tagged with securitySystemArmLevel when you use the arm command. It will then use the status of the item securitySystemArmed to confirm that arming was successful.
When arming and not using arm levels or disarming, Google will send ON/OFF to the item tagged securitySystemArmed.
If arming fails and blocking zones have been configured with securitySystemZone and blocking=true, Google will attempt to check for zones that are causing the arming to fail.
ga="securitySystemTrouble" and ga="securitySystemTroubleCode" are used in a StatusReport to report any errors on the alarm, e.g. a flat battery.
Group   gHouseAlarm "House Alarm" { ga="SecuritySystem" [ pinNeeded="1234", armLevels="L1=Level 1,L2=Level 2" ] }
Switch  alarmArmed            (gHouseAlarm) { ga="securitySystemArmed" }
String  alarmArmLevel         (gHouseAlarm) { ga="securitySystemArmLevel" }
Switch  alarmTrouble          (gHouseAlarm) { ga="securitySystemTrouble" }
String  alarmTroubleErrorCode (gHouseAlarm) { ga="securitySystemTroubleCode" }
Contact frontDoorSensor       (gHouseAlarm) { ga="securitySystemZone" [ zoneType="OpenClose", blocking="true" ] }
# Camera
Device Type Camera (opens new window)
Supported Traits CameraStream (opens new window)
Supported Items String
Configuration (optional) protocols="hls,dash,smooth_stream,progressive_mp4" (choose suitable)
Device Type Speaker (opens new window)
Supported Traits Volume (opens new window)
Supported Items Dimmer
Configuration (optional) checkState=true/false
(optional) volumeDefaultPercentage="20"
(optional) levelStepSize="5"
(optional) volumeMaxLevel="100"
# TV
Device Type TV (opens new window)
Supported Traits OnOff (opens new window), Volume (opens new window), TransportControl (opens new window), InputSelector (opens new window), AppSelector (opens new window), Channel (opens new window) (depending on used members)
Supported Items Group as TV with the following members:
(optional) Switch as tvPower
(optional) Switch as tvMute
(optional) Dimmer or Number as tvVolume
(optional) String or Number as tvChannel
(optional) String or Number as tvInput
(optional) String or Number as tvApplication
(optional) Player as tvTransport
(optional) transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME"
(optional) availableChannels="channelNumber=channelId=channelName:channelSynonym:...,..."
(optional) availableInputs="inputKey=inputName:inputSynonym:...,..."
(optional) availableApplications="applicationKey=applicationName:applicationSynonym:...,..."
(optional) lang="en"
Group  tvGroup { ga="TV" [ volumeDefaultPercentage="20", levelStepSize="10", volumeMaxLevel="100", transportControlSupportedCommands="NEXT,PREVIOUS,PAUSE,RESUME", availableChannels="1=Channel1=NBC,2=Channel2=CBS", availableInputs="hdmi1=xbox:gaming,hdmi2=settopbox", availableApplications="spotify=Spotify:Music,netflix=Netflix:Chill" ] }
Switch powerItem       (tvGroup) { ga="tvPower" }
Switch muteItem        (tvGroup) { ga="tvMute" }
Dimmer volumeItem      (tvGroup) { ga="tvVolume" }
String channelItem     (tvGroup) { ga="tvChannel" }
String inputItem       (tvGroup) { ga="tvInput" }
Player transportItem   (tvGroup) { ga="tvTransport" }
# Fan, Hood, AirPurifier (only on/off or fan speed control)
Device Type Fan (opens new window), Hood (opens new window), AirPurifier (opens new window)
Supported Traits OnOff (opens new window), FanSpeed (opens new window) (depending on used item type)
Supported Items Switch (no speed control), Dimmer, Number
(optional) fanSpeeds="0=away:zero,50=default:standard:one,100=high:two"
(optional) ordered=true/false
Fans (and similar device types, like AirPurifier or Hood) support the FanSpeed trait. If you do not specify the fanSpeeds option, Google will use and expect percentage values for the fan speed. Otherwise, you will be able to set up and use human speakable modes, e.g. "fast" for 100% or "slow" for 25%.
fanSpeeds will be a comma-separated list of modes, where the mode value corresponds to the speed value to be passed to the device. The mode or value is followed by an equal sign to list different aliases separated by a colon sign. So in the example stated below both "high" and "two" would set the speed to 100%. Some devices may expect a specific value instead of a percentage, like "1" or "2" as speed values. In this case, you can adjust the configuration and replace the percentage values with the values that the device expects. (e.g.: fanSpeeds="0=away:zero,1=default:standard:one,2=high:two"). You are also able to define the language of those aliases. The option ordered will tell the system that your list is ordered and you will then be able to also say "faster" or "slower" and Google will use the next or previous speed.
Dimmer { ga="Fan" [ fanSpeeds="0=away:zero,50=default:standard:one,100=high:two", lang="en", ordered=true ] } # Using specific percentage values for the speed
Switch { ga="Hood" } # No speed control - only on/off
Dimmer { ga="AirPurifier" } # Using percentage values for the speed
Dimmer { ga="AirPurifier" [ fanSpeeds="0=away:zero,1=low:one,2=medium:two,3=high:three,4=turbo:four", lang="en", ordered=true ] } # Using specific speed modes/values, which differ from percentage
Switch { ga="AirPurifier" } # No speed control - only on/off
# Fan, Hood, AirPurifier (extended control options)
Supported Traits OnOff (opens new window), FanSpeed (opens new window), Modes (opens new window), SensorState (opens new window)
Supported Items Group as Fan, Hood or AirPurifier with the following members:
(optional) Switch as fanPower
(optional) Dimmer or Number as fanSpeed
(optional) Number or String as fanMode
(optional) Number as fanFilterLifeTime
(optional) Number as fanPM25
(optional) fanModeName="OperationMode,Modus"
(optional) fanModeSettings="1=Low:Silent,2=Normal,3=High:Night"
When configuring a Fan (or similar device) as a group with the above listed members, you will gain more options to control the device. In addition to control power and speeds, you will also be able to set modes and query sensor information (if supported by Google).
For more information on the fanSpeeds configuration option, please take a look at the simple Fan device type.
With the fanModeName and fanModeSettings you can control specific modes. Currently, one mode type per device is supported that you can configure with a name and a list of settings. The first entry in the names field is used internally while any other following separated by comma will be a synonym to be used in commands. The settings list is a comma-separated list of value=name pairs. The name can also contain synonyms separated by a colon. In the listed example you could then say "Set OperationMode to Normal".
Hint: At the moment, sensor values will only be queriable by voice and will not show up anywhere in the Google Home app.
Group  fanGroup { ga="Fan" [ fanSpeeds="0=away:zero,50=default:standard:one,100=high:two", fanModeName="OperationMode,Modus", fanModeSettings="1=Silent,2=Normal,3=Night", lang="en", ordered=true ] }
Switch powerItem    (fanGroup) { ga="fanPower" }
Dimmer speedItem    (fanGroup) { ga="fanSpeed" }
String modeItem     (fanGroup) { ga="fanMode" }
Number lifetimeItem (fanGroup) { ga="fanFilterLifeTime" }
Number pm25Item     (fanGroup) { ga="fanPM25" }
# AC_Unit
Device Type AC_Unit (opens new window)
Supported Traits OnOff (opens new window), FanSpeed (opens new window), TemperatureSetting (opens new window), Modes (opens new window), SensorState (opens new window)
Supported Items Group as AC_Unit with the following members:
(optional) Number as thermostatTemperatureAmbient
(optional) Number as thermostatTemperatureSetpoint
(optional) Number as thermostatTemperatureSetpointLow
(optional) Number as thermostatTemperatureSetpointHigh
(optional) Number as thermostatHumidityAmbient
(optional) String or Number or Switch as thermostatMode
(optional) useFahrenheit=true/false
(optional) maxHumidity=1-100
(optional) thermostatTemperatureRange="10,30"
(optional) thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto"
The AC_Unit device is basically the combination of the Fan and the Thermostat device. For explanation on configuration options please take a look at both of them.
Group  acunitGroup { ga="AC_Unit" [ fanSpeeds="0=null:off,50=slow,100=full:fast", fanModeName="OperationMode,Modus", fanModeSettings="1=Silent,2=Normal,3=Night", thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto", thermostatTemperatureRange="10,30", useFahrenheit=false, lang="en", ordered=true ] }
Switch powerItem        (acunitGroup) { ga="fanPower" }
Dimmer speedItem        (acunitGroup) { ga="fanSpeed" }
String modeItem         (acunitGroup) { ga="fanMode" }
Number lifetimeItem     (acunitGroup) { ga="fanFilterLifeTime" }
Number pm25Item         (acunitGroup) { ga="fanPM25" }
Number ambientItem      (acunitGroup) { ga="thermostatTemperatureAmbient" }
Number humidityItem     (acunitGroup) { ga="thermostatHumidityAmbient" }
Number setpointItem     (acunitGroup) { ga="thermostatTemperatureSetpoint" }
Number setpointItemLow  (acunitGroup) { ga="thermostatTemperatureSetpointLow" }
Number setpointItemHigh (acunitGroup) { ga="thermostatTemperatureSetpointHigh" }
String modeItem         (acunitGroup) { ga="thermostatMode" }
# Humidifier
Device Type Humidifier (opens new window)
Supported Traits OnOff (opens new window) (all devices), HumiditySetting (opens new window) (Dimmer/Number items and Groups with humidity setpoint), FanSpeed (opens new window) (Groups with fan speed member)
Supported Items Switch (on/off only), Dimmer, Number, or Group as Humidifier with the following members:
(optional) Switch as humidifierPower
(optional) Number or Dimmer as humidifierHumiditySetpoint
(optional) Number as humidifierHumidityAmbient
(optional) Number or Dimmer as humidifierFanSpeed
(optional) humidityRange="30,80"
(optional) fanSpeeds="low=Low:Slow,high=High:Fast"
For simple humidifiers, you can use:
  • Switch: Basic on/off control only (no humidity percentage)
  • Dimmer/Number: Full humidity control with setpoint
For advanced functionality, use a Group with specific members.
  • maxHumidity=100 defines the maximum value of your humidity items if they don't use percentage (0-100). For example, if your sensor reports 0.0-1.0, set maxHumidity=1.
  • humidityRange="30,80" defines the supported humidity range for the setpoint (defaults to 0-100%).
  • fanSpeeds allows you to define named fan speeds with synonyms.
Google Commands: "Hey Google, turn on the humidifier", "Hey Google, set humidifier to 60 percent" (Dimmer/Number/Group only), "Hey Google, set humidifier fan speed to high" (Group with fan speed only).
# Simple humidifier
Switch { ga="Humidifier" }
Dimmer { ga="Humidifier" [ maxHumidity=1 ] }
# Advanced humidifier with humidity control and fan speed
Group  humidifierGroup { ga="Humidifier" [ humidityRange="30,80", fanSpeeds="low=Low:Slow,high=High:Fast", maxHumidity=100 ] }
Switch humidifierPowerItem     (humidifierGroup) { ga="humidifierPower" }
Number humidifierSetpointItem  (humidifierGroup) { ga="humidifierHumiditySetpoint" }
Number humidifierAmbientItem   (humidifierGroup) { ga="humidifierHumidityAmbient" }
Dimmer humidifierFanSpeedItem  (humidifierGroup) { ga="humidifierFanSpeed" }
Device Type Awning (opens new window), Blinds (opens new window), Curtain (opens new window), Door (opens new window), Garage (opens new window), Gate (opens new window), Pergola (opens new window), Shutter (opens new window), Window (opens new window)
Supported Traits OpenClose (opens new window), StartStop (opens new window), Rotation (opens new window) (awning, blinds, curtain, pergola, shutter - requires group configuration)
Supported Items Contact (no device control), Switch (no open percentage), Rollershutter, Group (for rotation support)
Configuration (optional) discreteOnly=true/false
Rotation Support (Groups with shutterRotation only):
(optional) supportsDegrees=true/false (default: true)
(optional) supportsContinuousRotation=true/false (default: false)
(optional) rotationDegreesRange="min,max" (default: "0,90")
Blinds and similar devices should always use the Rollershutter item type for proper functionality. Since Google and openHAB use the opposite percentage value for "opened" and "closed", the action will translate this automatically. If the values are still inverted in your case, you can state the inverted=true option for all Rollershutter items.
# Rotation Support for Awning, Blinds, Curtain, Pergola, and Shutter
Awnings, blinds, curtains, pergolas, and shutters support the Rotation trait (opens new window), allowing control of slat tilt/rotation in addition to opening/closing. This feature is only available for group-based configurations with separate position and rotation controls.
Group Configuration for Rotation: For devices with separate items for position and rotation control:
Group blindsGroup { ga="Blinds" }
  Rollershutter blindsPosition  { ga="shutterPosition" }
  Number        blindsRotation  { ga="shutterRotation" }
Voice Commands:
  • "Open the shutters to 50%"
  • "Tilt the shutters to 30 degrees"
  • "Set the blinds to 75%"
  • "Rotate the blinds to 45 degrees"
Group Members:
  • shutterPosition: Controls the opening/closing position (Rollershutter, Dimmer, Number)
  • shutterRotation: Controls the slat rotation/tilt (Rollershutter, Dimmer, Number)
Configuration Options: The rotation trait supports the following optional configuration parameters:
  • supportsDegrees=true/false (default: true) - Enable degree-based control (percentage is always supported)
    • Set to false if you only want percentage-based control without degree conversion
  • supportsContinuousRotation=true/false (default: false) - Enable continuous rotation beyond limits
  • rotationDegreesRange="min,max" (default: "0,90") - Rotation range in degrees as comma-separated values (only used when supportsDegrees is true)
openHAB items always store rotation as percentages (0-100). When supportsDegrees=true, the percentage is converted to/from degrees using the configured range for Google Assistant commands and state responses.
Group shutterGroup { ga="Shutter" [ rotationDegreesRange="-45,45" ] }
  Rollershutter shutterPosition  { ga="shutterPosition" }
  Number        shutterRotation  { ga="shutterRotation" }
# Example with continuous rotation support
Group blindsGroup { ga="Blinds" [ supportsContinuousRotation=true, rotationDegreesRange="0,360" ] }
  Rollershutter blindsCover     { ga="shutterPosition" }
# Example with percentage-only control (no degree conversion)
Group awningGroup { ga="Awning" [ supportsDegrees=false ] }
  Rollershutter awningPosition  { ga="shutterPosition" }
  Dimmer        awningSlats     { ga="shutterRotation" }
Basic Examples:
# Simple devices (no rotation)
Rollershutter { ga="Awning" }
Switch        { ga="Door" }
Rollershutter { ga="Garage" }
Contact       { ga="Gate" }
Rollershutter { ga="Window" }
# Advanced devices with rotation support
Group shutterGroup { ga="Shutter" }
  Rollershutter ShutterPosition  { ga="shutterPosition" }
  Number        ShutterTilt      { ga="shutterRotation" }
Group blindsGroup { ga="Blinds" [ rotationDegreesRange="0,180" ] }
  Rollershutter blindsSlats     { ga="shutterRotation" }
# Charger
Device Type Charger (opens new window)
Supported Traits EnergyStorage (opens new window)
Supported Items Group as Charger with the following members:
(optional) Switch as chargerCharging
(optional) Switch as chargerPluggedIn
(optional) Number or Dimmer as chargerCapacityRemaining
(optional) Number or Dimmer as chargerCapacityUntilFull
(optional) isRechargeable=true/false
(optional) unit="PERCENTAGE"
The configuration option unit supports the following values: PERCENTAGE (default), SECONDS, MILES, KILOMETERS, KILOWATT_HOURS
The setting isRechargeable defaults to false if not explicitly set to true.
If no chargerCharging item is specified, the device will only support queries.
Group  chargerGroup { ga="Charger" [ isRechargeable=true, unit="KILOWATT_HOURS" ] }
Switch chargingItem         (chargerGroup) { ga="chargerCharging" }
Switch pluggedInItem        (chargerGroup) { ga="chargerPluggedIn" }
Number capacityRemainItem   (chargerGroup) { ga="chargerCapacityRemaining" }
Number capacityFullItem     (chargerGroup) { ga="chargerCapacityUntilFull" }
# TemperatureSensor
Device Type Sensor (opens new window)
Supported Traits TemperatureControl (opens new window), TemperatureSetting (opens new window)
Supported Items Number
Configuration (optional) useFahrenheit=true/false
(optional) temperatureRange="-10,50"
By default, the temperature range of a temperature sensor is set to -100 °C to 100 °C. The reported state values have to fall into that range! If you need to adjust the range, please add the config option temperatureRange="-20,40" to the item. Keep in mind that those values always have to be provided in Celsius!
Number { ga="TemperatureSensor" [ useFahrenheit=true, temperatureRange="-20,40" ] }
# HumiditySensor
Supported Traits HumiditySetting (opens new window)
Configuration (optional) maxHumidity=1-100
Number { ga="HumiditySensor" }
# ClimateSensor
Supported Traits HumiditySetting (opens new window), TemperatureControl (opens new window), TemperatureSetting (opens new window)
Supported Items Group as ClimateSensor with the following members:
(optional) Number as humidityAmbient
(optional) Number as temperatureAmbient
By default, the temperature range of a climate sensor is set to -100 °C to 100 °C. The reported state values have to fall into that range! If you need to adjust the range, please add the config option temperatureRange="-20,40" to the item. Keep in mind that those values always have to be provided in Celsius!
Group  sensorGroup { ga="ClimateSensor" [ useFahrenheit=true, temperatureRange="0,40" ] }
Number temperatureItem (sensorGroup) { ga="temperatureAmbient" }
Number humidityItem    (sensorGroup) { ga="humidityAmbient" }
# Thermostat
Device Type Thermostat (opens new window)
Supported Traits TemperatureSetting (opens new window)
Supported Items Group as Thermostat with the following members
Thermostat requires a group of items to be properly configured to be used with Google Assistant. The default temperature unit is Celsius. To change the temperature unit to Fahrenheit, add the config option useFahrenheit=true to the thermostat group. To set the temperature range your thermostat supports, add the config option thermostatTemperatureRange="10,30" to the thermostat group. Those values always have to be provided in Celsius! If your thermostat supports a range for the setpoint you can use both thermostatTemperatureSetpointLow and thermostatTemperatureSetpointHigh instead of the single thermostatTemperatureSetpoint item.
To map the default thermostat modes of Google (opens new window) (on, off, heat, cool, etc.) to custom ones for your specific setup, you can use the thermostatModes config option on the thermostat group. E.g. [ thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto" ] will enable the following five modes in Google Home "off, heat, eco, on, auto" that will be translated to "OFF, COMFORT, ECO, ON, auto". You can specify alternative conversions using the colon sign, so that in the former example "BOOST" in openHAB would also be translated to "heat" in Google. For the translation of Google modes to openHAB always the first option after the equal sign is used. By default, the integration will provide "off,heat,cool,on,heatcool,auto,eco".
You can also set up a Thermostat for using it as a temperature sensor. To do so, create a Thermostat group and only add one item member as "thermostatTemperatureAmbient". However, it is recommended to prefer the TemperatureSensor type for simple temperature reports (but currently there is no UI support in Google Home).
Group  thermostatGroup { ga="Thermostat" [ thermostatModes="off=OFF:WINDOW_OPEN,heat=COMFORT:BOOST,eco=ECO,on=ON,auto", thermostatTemperatureRange="10,30", useFahrenheit=false ] }
Number ambientItem      (thermostatGroup) { ga="thermostatTemperatureAmbient" }
Number humidityItem     (thermostatGroup) { ga="thermostatHumidityAmbient" }
Number setpointItem     (thermostatGroup) { ga="thermostatTemperatureSetpoint" }
Number setpointItemLow  (thermostatGroup) { ga="thermostatTemperatureSetpointLow" }
String modeItem         (thermostatGroup) { ga="thermostatMode" }
# Sensor
Supported Traits SensorState (opens new window)
Supported Items Number, Dimmer
Configuration sensorName="SmokeLevel"
valueUnit="PARTS_PER_MILLION"
states="no smoke=10,smoke detected=50,high=90"
# Additional Configuration
For devices supporting the OnOff trait, the attribute [ queryOnly=true ] can be configured. For devices supporting the OpenClose trait, the attributes [ queryOnly=true, discreteOnly=true ] can be configured.
  • queryOnly defaults to false. Is set to true for Contact items. Indicates if the device can only be queried for state information and cannot be controlled. Sensors that can only report open state should set this field to true.
  • discreteOnly defaults to false. When set to true, this indicates that the device must either be fully open or fully closed (that is, it does not support values between 0% and 100%). An example of such a device may be a valve.
All device types support checking the current state before sending an updated state by a command. This can be enabled by setting [ checkState=true ] in the metadata. When this is enabled, the current state of the target item is queried and compared to the potential new state triggered by the command. If it is identical, a special error message is triggered and communicated to the user.
  • add metadata via console:
    smarthome:metadata add BedroomLights ga Light
  • add metadata using the REST API:
    PUT /rest/items/BedroomLights/metadata/ga
      "value": "Light"
# Two-Factor-Authentication
For some actions, Google recommends to use TFA (Two-Factor-Authentication) to prevent accidental or unauthorized triggers of sensitive actions. See Two-factor authentication  |  Actions on Google Smart Home (opens new window).
Switch DoorLock   "Front Door"  { ga="Lock" [ ackNeeded=true ] }
# Setup & Usage of the Google Home App
  • Make sure Google Play Services is up to date.
  • Visit "Google Home" app entry in Google Play Store on Android.
  • Set up the voice-activated speaker or Android phone (version 6+) with your Google account.
  • Make sure you're the correct user.
  • Start the Google Home app on your phone.
  • Go to the settings part: Home > Settings.
openHAB Google App
  • Press the + Add device button in the Settings screen.
openHAB Google App
  • Choose Works with Google
openHAB Google App
  • Search and select openHAB.
openHAB Google App
  • Continue with linking your account.
openHAB Google App
  • Login at myopenhab.org with your username and password.
openHAB Google App
  • Make sure to assign your devices to rooms to properly use voice commands.
  • You can now control your devices from the Google Assistant and Google Home.
openHAB Google App
# Example Voice Commands
  • Turn on Office Lights.
  • Dim/Brighten Office Lights (increments 15%).
  • Set Office Lights to 35%.
  • Open/Close the blinds
  • Turn off Pool Waterfall.
  • Turn on House Fan.
  • Turn on Home Theater Scene.
  • Set Basement Thermostat to 15 degrees.
  • What is the current Basement Thermostat Temperature?
# Frequently Asked Question
  • Say: Hey Google, sync my devices
  • Check, recheck and after that check again your items!
  • The items that you want to expose to Google Assistant should have the right metadata assigned.
  • The items that you want to expose to Google Assistant must have a item label! Item Definition and Syntax (opens new window)
  • If none of the above solutions works for you:
    • Remove all the metadata.
    • Make a new .item file with 1 item to expose.
    Switch TestSwitch "Test Switch" { ga="Switch" }
    • Relink your account.
