# JuiceNet Binding
The JuiceNet binding will interface with the cloud portal to get status and manage your JuiceBox EV charger(s). In addition to getting the status of various items from the EV charger, it is also possible to start and stop charging sessions.
This binding supports the following things:
thing type description
JuiceNet Account Bridge This represents the cloud account to interface with the JuiceNet API.
JuiceBox EV Charger Device This interfaces to a specific JuiceBox EV charger associated with the JuiceNet account.
This binding should work with multiple JuiceBox EV chargers associated with the account, however it is currently only tested with a single EV charger.
Once a JuiceNet Account bridge has been created, any JuiceBox EV Chargers associated with this account will be discovered.
The configuration required is to create a JuiceNet account thing and fill in the appropriate API token. The API token can be found on the Account page at https://home.juice.net/Manage (opens new window).
A JuiceBox EV Charger requires a unitID which can also be found in the device settings at the JuiceNet web page.
channel type read-only description
name String Y Name of device.
chargingState String N Current charging state (Start Charging, Smart Charging, Stop Charging).
state String Y This is the current device state (Available, Plugged-In, Charging, Error, Disconnected).
message String Y This is a message detailing the state of the EV charger.
override Switch N Smart charging is overridden. Set to "OFF" to remove override.
chargingTimeLeft Number:Time Y Charging time left (seconds).
plugUnplugTime DateTime Y Last time of either plug-in or plug-out.
targetTime DateTime N “Start charging” start time, or time to start when overriding smart charging.
unitTime DateTime Y Current time on the unit.
temperature Number:Temperature Y Current temperature at the unit.
currentLimit Number:ElectricCurrent N Max charging current allowed.
current Number:ElectricCurrent Y Current charging current.
voltage Number:ElectricPotential Y Current voltage.
energy Number:Energy Y Current amount of energy poured to the vehicle.
savings Number Y Current session EV savings.
power Number:Power Y Current charging power.
secondsCharging Number:Time Y Charging time since plug-in time.
energyAtPlugin Number:Energy Y Energy value at the plugging time.
energyToAdd Number:Energy N Amount of energy to be added in current session.
lifetimeEnergy Number:Energy Y Total energy delivered to vehicles during lifetime.
lifetimeSavings Number Y EV driving saving during lifetime.
gasCost Number Y Cost of gasoline used in savings calculations.
fuelConsumption Number Y Miles per gallon used in savings calculations.
ecost Number Y Cost of electricity from utility company. (currency/kWh)
energyPerMile Number Y Energy per mile.
carDescription String Y Car description of vehicle currently or last charged.
carBatterySize Number:Energy Y Car battery pack size.
carBatteryRange Number:Length Y Car range.
carChargingRate Number:Power Y Car charging rate.
# Things File
If configuring the binding with manual configuration an example thing file looks like this:
Bridge juicenet:account:myaccount [ apiToken="xxxx-xxxx-xxxx-xxxx-xxxxx" ] {
    Thing device JamesCharger [ unitID="xxxxxxx" ]
# Items File
An example of an items file is here.
String                  JuiceNet_Name               "Name"                                                      { channel="juicenet:device:myaccount:JamesCharger:name" }
String                  JuiceNet_State              "Device State"                                              { channel="juicenet:device:myaccount:JamesCharger:state" }
String                  JuiceNet_ChargingState      "Charging State"                                            { channel="juicenet:device:myaccount:JamesCharger:chargingState" }
String                  JuiceNet_Message            "State Message"                                             { channel="juicenet:device:myaccount:JamesCharger:message" }
Switch                  JuiceNet_Override           "Override State"                                            { channel="juicenet:device:myaccount:JamesCharger:override" }
DateTime                JuiceNet_PlutUnplugTime     "Plug/Unplug Time [%1$tB %1$te, %1$tY %1$tl:%1$tM %1$tp]"   { channel="juicenet:device:myaccount:JamesCharger:plugUnplugTime" }
DateTime                JuiceNet_TargetTime         "Target Time [%1$tB %1$te, %1$tY %1$tl:%1$tM %1$tp]"        { channel="juicenet:device:myaccount:JamesCharger:targetTime" }
Number:Time             JuiceNet_ChargingTimeLeft   "Charging Time Left [%.0f %unit%]"                          { channel="juicenet:device:myaccount:JamesCharger:chargingTimeLeft" }
DateTime                JuiceNet_UnitTime           "Unit Time [%1$tB %1$te, %1$tY %1$tl:%1$tM %1$tp]"          { channel="juicenet:device:myaccount:JamesCharger:unitTime" }
Number:Temperature      JuiceNet_Temperature        "Temperature [%.0f %unit%]"                                 { channel="juicenet:device:myaccount:JamesCharger:temperature" }
Number:ElectricCurrent  JuiceNet_CurrentLimit       "Current Limit [%d %unit%]"                                 { channel="juicenet:device:myaccount:JamesCharger:currentLimit" }
Number:ElectricCurrent  JuiceNet_Current            "Current [%.1f %unit%]"                                     { channel="juicenet:device:myaccount:JamesCharger:current" }
Number:ElectricPotential JuiceNet_Voltage           "Voltage [%d %unit%]"                                       { channel="juicenet:device:myaccount:JamesCharger:voltage" }
Number:Energy           JuiceNet_Energy             "Current Energy [%.1f %unit%]"                              { channel="juicenet:device:myaccount:JamesCharger:energy" }
Number:Power            JuiceNet_Power              "Charging Power [%.2f %unit%]"                              { channel="juicenet:device:myaccount:JamesCharger:power" }
Number                  JuiceNet_Savings            "Savings [$%.2f]"                                           { channel="juicenet:device:myaccount:JamesCharger:savings" }
Number:Time             JuiceNet_ChargingTime       "Charging Time [%.0f %unit%]"                               { channel="jjuicenet:device:myaccount:JamesCharger:chargingTime" }
Number:Energy           JuiceNet_EnergyToAdd        "Energy to Add [%.2f %unit%]"                               { channel="juicenet:device:myaccount:JamesCharger:energyToAdd" }
Number:Energy           JuiceNet_EnergyAtPlugin     "Energy at Plugin [%.2f %unit%]"                            { channel="juicenet:device:myaccount:JamesCharger:energyAtPlugin" }
Number:Energy           JuiceNet_LifetimeEnergy     "Lifetime Energy [%.2f %unit%]"                             { channel="juicenet:device:myaccount:JamesCharger:lifetimeEnergy" }
Number                  JuiceNet_GasCost            "Gas Cost [$%.2f]"                                          { channel="juicenet:device:myaccount:JamesCharger:gasCost" }
Number                  JuiceNet_FuelConsumption    "Fuel consumption [%.1f %unit%]"                            { channel="juicenet:device:myaccount:JamesCharger:fuelConsumption" }
Number                  JuiceNet_Ecost              "Utility Energy Cost [$%.2f]"                               { channel="juicenet:device:myaccount:JamesCharger:ecost" }
Number                  JuiceNet_LifetimeSavings    "Lifetime Savings [$%.2f]"                                  { channel="juicenet:device:myaccount:JamesCharger:lifetimeSavings" }
Number:Power            JuiceNet_EnergyPerMile      "Energy Hours Per Mile [%.2f %unit%]"                       { channel="juicenet:device:myaccount:JamesCharger:energyPerMile" }
String                  JuiceNet_CarDescription     "Car Description"                                           { channel="juicenet:device:myaccount:JamesCharger:carDescription" }
Number:Length           JuiceNet_CarBatteryRange    "Mileage Range [%d %unit%]"                                 { channel="juicenet:device:myaccount:JamesCharger:carBatteryRange" }
Number:Energy           JuiceNet_CarBatterySize     "Car Battery Pack Size [%.2f %unit%]"                       { channel="juicenet:device:myaccount:JamesCharger:carBatterySize" }
Number:Power            JuiceNet_CarChargineRage    "Car Charging Rate [%.2f %unit%]"                           { channel="juicenet:device:myaccount:JamesCharger:carChargingRate" }
# Widget
The following custom widget can be used with this binding.
JuiceBox Widget
uid: widget_JuiceBox
tags: []
props:
  parameters:
    - description: Prefix for the items with the data
      label: Item prefix
      required: false
      type: TEXT
  parameterGroups: []
timestamp: May 10, 2021, 2:38:55 PM
component: f7-card
  title: =items[props.prefix + "_Name"].state
    --f7-card-header-border-color: none
    - component: f7-card-content
          - component: f7-row
              class:
                - display-flex
                - align-content-stretch
                - align-items-center
                - component: f7-gauge
                    type: semicircle
                    value: =Number.parseFloat(items[props.prefix + "_CurrentEnergy"].state) / Number.parseFloat(items[props.prefix + "_CarBatteryPackSize"].state)
                    bg-color: transparent
                    border-bg-color: '=(items[props.prefix + "_DeviceState"].state === "charging") ? "#577543" : (items[props.prefix + "_DeviceState"].state === "plugged") ? "#8f6c2f" : "#595959"'
                    border-color: '=(items[props.prefix + "_DeviceState"].state === "charging") ? "#90d164" : (items[props.prefix + "_DeviceState"].state === "plugged") ? "#ed9c11" : "#adadad"'
                    borderWidth: 40
                    value-text: =items[props.prefix + "_CurrentEnergy"].displayState
                    value-text-color: '=(items[props.prefix + "_DeviceState"].state === "charging") ? "#90d164" : (items[props.prefix + "_DeviceState"].state === "plugged") ? "#ed9c11" : "#adadad"'
                    value-font-size: 20
                    value-font-weight: 500
                    label-text: =items[props.prefix + "_DeviceState"].displayState
                    label-text-color: white
                    label-font-size: 18
                    label-font-weight: 400
                    noBorder: true
                    outline: true
          - component: f7-row
              class:
                - display-flex
                - justify-content-center
                - margin-left
                - component: f7-segmented
                    strong: true
                      width: 80%
                      - component: oh-button
                          text: Start
                          color: blue
                          active: =(items[props.prefix + "_ChargingState"].state === "start")
                          action: command
                          actionItem: =props.prefix + "_ChargingState"
                          actionCommand: start
                          text: Smart
                          color: blue
                          active: =(items[props.prefix + "_ChargingState"].state === 'smart')
                          action: command
                          actionCommand: smart
                          text: Stop
                          color: blue
                          active: =(items[props.prefix + "_ChargingState"].state === "stop")
                          action: command
                          actionCommand: stop
          - component: f7-row
              class:
                - display-flex
                - justify-content-space-evenly
                - height: 40px
                --f7-chip-font-size: 14px
                --f7-chip-height: 28px
                padding-top: 12px
                - component: f7-chip
                    visible: =(items[props.prefix + "_DeviceState"].state === "charging")
                    text: '="Power: " + items[props.prefix + "_ChargingPower"].state'
                    iconF7: bolt_fill
                    media-bg-color: blue
                    bg-color: gray
                    label: hello
                      padding-rightc: 12px
                    text: '="Current: " + items[props.prefix + "_Current"].state'
                    iconF7: arrow_up_circl
                    bg-color: gray
                    text: '="Voltage: " + items[props.prefix + "_Voltage"].state'
                    iconF7: plusminus
                    bg-color: gray
                    visible: =(items[props.prefix + "_ChargingState"].state === 'smart')
                    text: '="Charge at: " + items[props.prefix + "_TargetTime"].displayState'
                    iconF7: clock
                    bg-color: gray
                    visible: =(items[props.prefix + "_DeviceState"].state === 'charging')
                    text: '="Charge Time Left: " + items[props.prefix + "_ChargingTimeLeft"].displayState'
                    iconF7: timer
                    bg-color: gray
    - component: f7-card-footer
          - component: Label
              text: =items[props.prefix + "_CarDescription"].state
