# TA C.M.I. Binding
Via a "Schema API Page"
- Read values from output nodes
- Change values for controllable nodes
- Receive data from analog CAN outputs defined in TAPPS2
- Receive data from digital CAN outputs defined in TAPPS2
- Send ON/OFF to digital CAN inputs defined in TAPPS2
- Send numeric values to analog CAN inputs defined in TAPPS2
JSON API
- Read selected data via the JSON API (inputs, outputs, logging). See API documentation (opens new window) for details
# Supported Bridge and Things
- TA C.M.I. Schema API Connection - Thing
This Thing reflects one of our 'schema API page' as defined in the prerequisites. This Thing doesn't need the bridge. Multiple of these pages on different C.M.I.'s could be defined within an openHAB instance. - TA C.M.I. CoE Bridge
In order to get the CAN over Ethernet (CoE) environment working acoe-bridgehas to be created. The bridge itself opens the UDP port 5441 for communication with the C.M.I. devices. The bridge could be used for multiple C.M.I. devices. - TA C.M.I. CoE Connection - Thing
This Thing reflects a connection to a node behind a specific C.M.I. This node could be every CAN-capable device from TA which allows to define a CAN input. - TA C.M.I. JSON API Connection - Thing
This is a Thing connection that regularly polls the C.M.I. using the JSON API.
Auto-discovery is not supported. You have to define the Things manually.
# Schema API
The "Schema API page" is a special schema page created via TA's TA-Designer application available as download on their website. This page just needs to exist and be deployed on the C.M.I. but it doesn't need to be linked by the other schema pages you are using to control your TA installation.
All objects from this special 'API' page are automatically mapped as channels of this Thing, so the labels of the objects on this page have to follow a specific schema.
The text from the Pre-Text will be used to define the channel. The first word tempCollector (highlighted in the screenshot) will be used as channel name, so it has to be unique. Everything else till the final : will be used as channel description. Be sure to have at least 2 words in the Pre-Text as we need both - the channel name and a description. The binding will log an error otherwise. Also keep in mind: for the channel name we have to adhere to the openHAB channel name conventions - so just use letters and numbers without any special signs here. The type of the channel will be automatically determined by the type of the object added. Also don't forget the final colon - this is the separator between the label and the value. Without the colon the parser couldn't build up a working channel for this value.
# Connection Configuration
The Thing has the following configuration parameters:
| Parameter Label | Parameter ID | Description | Accepted values |
| C.M.I. IP Address | host | Host name or IP address of the C.M.I | host name or ip |
| Username | username | Username for authentication on the C.M.I. | string with username |
| Password | password | Password for authentication on the C.M.I. | string with password |
| API Schema ID | schemaId | ID of the schema API page | 1-256 |
| Poll Interval | pollInterval | Poll interval (in seconds) how often to poll the API Page | 1-300; default 10 |
This Thing doesn't need a bridge. Multiple of these things for different C.M.I.'s could be defined within an openHAB instance.
# TA C.M.I. schema API Channels
The channels provided by this Thing depend on the configuration of the "schema API page". All the channels are dynamically created to match it. Also when the API Page is updated, the channels are also updated during the next refresh.
The channels have a parameter allowing to configure their update behavior:
| Update Policy | updatePolicy | Update policy for this channel. Default means "On-Fetch" for read-only channels and "On-Change" for channels that can be modified. | 0 (Default), 1 (On-Fetch), 2 (On-Change) |
The behavior in detail:
Default(0): When the channel is 'read-only' the update policy defaults to On-Fetch. When the channel is linked to something that can be modified it defaults to On-Change.On-Fetch(1): This is the default for read-only values. This means the channel is updated every time the schema page is polled. Ideal for values you want to monitor and log into charts.On-Change(2): When channel values can be changed via openHAB it is better to only update the channel when the value changes. The binding will cache the previous value and only send an update when it changes from the previous known value. This is especially useful if you intend to link other things (like e.g. Zigbee or Shelly switches) to the TA via openHAB that can be controlled by different sources. This prevents unintended toggles or even toggle loops.
You might already have noticed that some state information is in German.
As I have set the Accept-Language HTTP header to en for all requests and found no other way to set a language for the schema pages I assume it is a lack of internationalization in the C.M.I.
You could circumvent this by creating map files to map things properly to your language.
If you want to see the possible options of a multi-state field you could open the schema API page with your web browser and click on the object. A popup with an option field will be shown showing all possible options, like in this screenshot:
Please be also aware that there are fields having more 'state' values than options, e.g. a manual output override: It has 'Auto/On', 'Auto/Off', 'Manual/On', 'Manual/Off' as state, but only 'Auto', 'Manual/On' and 'Manual/Off' as updateable options. You only set it to 'Auto' and the extension On/Off is added depending on the system's current state.
# CoE
# Configure your CMI for CoE
Now follow the user guide of the C.M.I. on how to setup CAN over Ethernet (CoE). Here you will map your outputs that you configured in the previous step. This can be accomplished via the GUI on the C.M.I. or via the coe.csv file. As the target device you need to put the IP of your openHAB server. Don't forget to reboot the C.M.I. after you uploaded the coe.csv file.
# TA C.M.I. CoE Connection
| Node | node | The CoE / CAN Node number openHAB should represent | 1-64 |
The Thing has no channels by default - they have to be added manually matching the configured inputs / outputs for the related CAN Node. Digital and Analog channels are supported. Please read TA's documentation related to the CAN-protocol - multiple analog (4) and digital (16) channels are combined so please be aware of this design limitation.
# CoE Connection Channels
Some comments on the CoE Connection and channel configuration: As you might already have taken notice when studying the TA's manual, there are always multiple CoE values updated within a single CoE message. This is a design decision made by TA. But this also means for CoE messages from openHAB to TA C.M.I. we have to send multiple values at once. But due to openHAB's design there is no default restore of previous values out of the box. So after openHAB startup the output Thing channels are either initialized with its configured default value or flagged as 'unknown' until the first update on the channel happens. You could either use some 'illegal' value as initial value and use CoE Value Validation on the TA side to detect invalid values. Another option would be to use only every 4th analog and 16th digital channel if you only need a few channels. Additionally you could use openHAB's persistence service (opens new window) and its option to restore the item states (opens new window) during openHAB startup. As this only restores the item states you have to write a rule issuing postUpdates on the items with the item's current value so the channel for the binding is updated.
| coe-digital-in | Switch (RO) | Digital input channel for digital state data received from the node |
| coe-digital-out | Switch | Digital output channel for digital state data sent to the node |
| coe-analog-in | Number (RO) | Analog input channel for numeric values received from the node |
| coe-analog-out | Number | Analog output channel for numeric values sent to the node |
Each channel has its own set of configuration parameters. Here is a list of possible parameters:
| Output | output | C.M.I. Network Output | 1-64 |
Channel coe-digital-out:
| Initial Value | initialValue | Initial value to set after startup (optional, defaults to uninitialized) | true (on) / false (off) |
Channel coe-analog-out:
| Measurement Type | type | Measurement type for this channel (see table below) | 0-21 |
| Initial Value | initialValue | Initial value to set after startup (optional, defaults to uninitialized) | floating point numeric |
| id | type | unit | description |
| 1 | Temperature | °C | Temperature value, multiplied by 0.1 |
| 2 | Energy Flux | W/m2 | e.g. for solar irradiation |
| 3 | Flow Rate | l/h | e.g. for flow meters such as TA FTS-xx |
| 4 | Time | s | |
| 5 | Time | min | |
| 6 | Flow Rate | l/min | standardized l/min flow rate |
| 7 | Temperature | K | Kelvin, e.g. for Temperature differences |
| 8 | Percentage | % | |
| 9 | unknown | : | might be another dimensionless unit |
| 10 | Power | kW | |
| 11 | Energy | kWh | |
| 12 | Energy | MWh | |
| 13 | el. Voltage | V | |
| 14 | el. Current | mA | |
| 15 | Time | hours | |
| 16 | dimensionless | [none] | use for multiplexers, etc |
| 17.. | repeating | again | from 1, e.g 17==1, 18==2, ... |
# Full Example (CoE/Schema API)
There is no common configuration as everything depends on the configuration of the TA devices. So we can just provide some samples providing the basics so you can build the configuration matching your system.
Example of a .thing file:
Sample .items-File:
# APIPage-items
String TACMI_Api_hc1OperationMode "Heating Circuit 1 Operation Mode [%s]" {channel="tacmi:cmiSchema:apiLab:hc1OperationMode"}
# COE-items
Number TACMI_Analog_In_1 "TA input value 1 [%.1f]" <temperature> {channel="tacmi:cmi:coe-bridge:cmiTest:analogInput1"}
Number TACMI_Analog_Out_1 "TA output value 1 [%.1f]" <temperature> {channel="tacmi:cmi:coe-bridge:cmiTest:analogOutput1"}
Switch TACMI_Digital_In_1 "TA input switch 1 [%s]" {channel="tacmi:cmi:coe-bridge:cmiTest:digitalInput1"}
Switch TACMI_Digital_Out_1 "TA output switch 1 [%s]" {channel="tacmi:cmi:coe-bridge:cmiTest:digitalOutput1"}
Sample .sitemap snippet
Text item=TACMI_Analog_In_1
# JSON API
Before setting up the JSON API, it is worth reading the API documentation (opens new window). Once configured, the exposed items should show up as channels.
# Configuring the JSON API
The TA C.M.I. JSON API Connection has to be manually configured.
| C.M.I. IP Address | host | Host name or IP address of the C.M.I. | Any String |
| User name | username | User name for authentication on the C.M.I. | Any String |
| Password | password | Password for authentication on the C.M.I. | Any String |
| Node Id | nodeId | The node ID of the device you want to monitor (C.M.I. → CAN-Bus) | An Integer that is not 0 |
| API-Parameters | params | Parameters to query (I, O, Sg, La, Ld). See API documentation (opens new window) for details: Inputs (I), Outputs (O), General (Sg), Logging Analog (La), Logging Digital (Ld) | Any String |
| Poll Interval | pollInterval | Poll interval in seconds. The documentation suggests 60s, but less is possible. | An integer between 10 and 900 |
← Systeminfo tado° →
