# Matter Binding
The Matter Binding for openHAB allows seamless integration with Matter-compatible devices.
It currently supports version 1.4.1 of the Matter specification and earlier.
# Supported functionality
This binding supports two different types of Matter functionality which operate independently of each other.
- This allows openHAB to discover and control other Matter devices like lights, thermostats, window coverings, locks, etc...
- This allows openHAB to expose items as Matter devices to other Matter clients. This allows local control of openHAB devices from other ecosystems like Apple Home, Amazon, and Google Home.
For more information on the Matter specification, see the Matter Ecosystem Overview section at the end of this document.
# Matter.JS Runtime
This binding uses the excellent matter.js (opens new window) implementation of the the Matter 1.4.1 protocol.
As such, this binding requires NodesJS 18+ and will attempt to download and cache an appropriate version when started if a version is not already installed on the system. Alpine Linux users (typically docker) and those on older Linux distributions will need to install this manually as the official NodeJS versions are not compatible.
# Matter and IPv6
Matter requires IPv6 to be enabled and be routable between openHAB and the Matter device. This means IPv6 needs to be enabled on the host openHAB is running, and the network must be able route IPv6 unicast and multicast messages. Docker, VLANs, subnets and other configurations can prohibit Matter from working if not configured correctly.
# Matter Client
This describes the Matter controller functionality for discovering and controlling Matter devices.
# Quick Start
- Install the Matter binding from the openHAB add-on store.
- Add a Matter "Controller" Thing to the inbox using the default settings.
- Use the "Pair Matter Device" action on the controller Thing to pair a device with the controller.
- Add the discovered device from the inbox as a new "Node" Thing.
Note: It is never necessary to remove or delete the "Controller" Thing when troubleshooting issues.
The Matter Binding supports the following types of things:
controller: The main controller that interfaces with Matter devices. It requires the configuration parameternodeIdwhich sets the local Matter node ID for this controller (must be unique in the fabric). This must be added manually.node: Represents an individual Node within the Matter network. The only configuration parameter isnodeId. A standard Node will map Matter endpoints to openHAB channel groups. This will be discovered automatically when a pairing code is used to scan for a device and should not be added manually.endpoint: Represents an standalone endpoint as a child of anodeThing. Only Endpoints exposed by Matter bridges will be added asendpointthings, otherwise Matter Endpoints are mapped on anodeThing as channel groups. AnendpointThing will be discovered automatically when a node is added that has multiple bridged endpoints and should not be added manually.
Matter controllers must be added manually.
Nodes (devices) will be discovered when a pairCode is used to search for a device to add.
Bridged endpoints will be added to the inbox once the parent Node is added as a Thing.
# Device Pairing: General
The pairing action can be found in the settings of the "Controller" Thing under the "Actions" -> "Pair Matter Device"
This action will give feedback on the pairing process, if successful a device will be added to the Inbox.
See Device Pairing: Code Types for more information on pairing codes and code formats.
The same codes can also be used in the openHAB Thing discovery UI, although feedback is limited and only a single controller is supported.
# Device Pairing: Code Types
In order to pair (commission in matter terminology) a device, you must have an 11 digit manual pairing code (eg 123-4567-8901 or 12345678901) or a QR Code (eg MT:ABCDEF1234567890123). If the device has not been paired before, use the code provided by the manufacturer and ensure the device is in pairing mode, refer to your devices instructions for pairing for more information. You can include dashes or omit them in a manual pairing code.
If the device is paired with another Matter ecosystem (Apple, Google, Amazon, etc..) you must use that ecosystem to generate a new pairing code and search for devices. The pairing code and device will only be available for commissioning for a limited time. Refer to the ecosystem that generated the code for the exact duration (typically 5-15 minutes). In this case, openHAB still talks directly to the device and is not associated with that existing ecosystem.
If the device seems to be found in the logs, but can not be added, its possible the device has been already paired. Hard resetting the device may help this case. See your device documentation for how to hard reset the device.
# Device Pairing: Thread Devices
Thread devices require a Thread Border Router and a bluetooth enabled device to facilitate the thread joining process (typically a mobile device). Until there is a supported thread border router integration in openHAB and the openHAB mobile apps, it's strongly recommended to pair the device to a commercial router with thread support first (Apple TV 4k, Google Nest Hub 2, Amazon Gen 4 Echo, etc... ), then generate a matter pairing code using that ecosystem and add the device normally. This will still allow openHAB to have direct access to the device using only the embedded thread border router and does not interact with the underlying providers home automation stack.
Support for using a OpenThread Border Router has been verified to work and will be coming soon to openHAB, but in some cases requires strong expertise in IPv6 routing as well as support in our mobile clients.
# Enabling IPv6 Thread Connectivity on Linux Hosts
It is important to make sure that Route Announcements (RA) and Route Information Options (RIO) are enabled on your host so that Thread boarder routers can announce routes to the Thread network. This is done by setting the following sysctl options:
net.ipv6.conf.wlan0.accept_rashould be at least1if ip forwarding is not enabled, and2otherwise.net.ipv6.conf.wlan0.accept_ra_rt_info_max_plenshould not be smaller than64.
the accept_ra is defaulted to 1 for most distributions.
There may be other network daemons which will override this option (for example, dhcpcd on Raspberry Pi will override accept_ra to 0).
You can check the accept_ra value with:
$ sudo sysctl -n net.ipv6.conf.wlan0.accept_ra
0
And set the value to 1 (or 2 in case IP forwarding is enabled) with:
$ sudo sysctl -w net.ipv6.conf.wlan0.accept_ra=1
Net.ipv6.conf.wlan0.accept_ra = 1
The accept_ra_rt_info_max_plen option on most Linux distributions is default to 0, set it to 64 with:
$ sudo sysctl -w net.ipv6.conf.wlan0.accept_ra_rt_info_max_plen=64
net.ipv6.conf.wlan0.accept_ra_rt_info_max_plen = 64
To make these changes permanent, add the following lines to /etc/sysctl.conf:
net.ipv6.conf.eth0.accept_ra=1
net.ipv6.conf.eth0.accept_ra_rt_info_max_plen=64
Raspberry Pi users may need to add the following lines to /etc/dhcpcd.conf to prevent dhcpcd from overriding the accept_ra value:
noipv6
noipv6rs
NOTE: Please ensure you use the right interface name for your network interface. The above examples use wlan0 and eth0 as examples.
You can find the correct interface name by running ip a and looking for the interface that has an IPv6 address assigned to it.
# Controller Thing Configuration
The controller Thing must be created manually before devices can be discovered.
| nodeId | number | The matter node ID for this controller | 0 | yes | no |
Note: The controller nodeId must not be changed after a controller is created.
# Node Thing Configuration
Nodes are discovered automatically (see Discovery for more information) and should not be added manually.
| nodeId | text | The node ID of the endpoint | N/A | yes | no |
# Endpoint Thing Configuration
Endpoints are discovered automatically once their parent Node has been added (see Discovery for more information) and should not be added manually.
| endpointId | number | The endpoint ID within the node | N/A | yes | no |
# Thing Actions
# Node Thing Actions
| Name | Description |
| Decommission Matter node from fabric | This will remove the device from the Matter fabric. If the device is online and reachable this will attempt to remove the credentials from the device first before removing it from the network. Once a device is removed, this Thing will go offline and can be removed. |
| Generate a new pairing code for a Matter device | Generates a new manual and QR pairing code to be used to pair the Matter device with an external Matter controller |
| List Connected Matter Fabrics | This will list all the Matter fabrics this node belongs to |
| Remove Connected Matter Fabric | This removes a connected Matter fabric from a device. Use the 'List connected Matter fabrics' action to retrieve the fabric index number |
| OTA: Check for firmware updates | Queries the Matter server for available firmware updates for this device |
| OTA: Start firmware update | Starts the firmware update process for this device. Check the Thing status for download progress. |
| OTA: Cancel firmware update | Cancels the firmware update process for this device if the download is in progress. Updates will not be possible for approximately 10 minutes after cancellation. |
For nodes that contain a Thread Border Router Management Cluster, the following additional actions will be present
| Thread: Load external operational dataset | Updates the local operational dataset configuration from a hex or JSON string for the node. Use the 'Push local operational dataset' action to push the dataset back to the device after loading. |
| Thread: Load operational dataset from device | Updates the local operational dataset configuration from the device. |
| Thread: Operational Dataset Generator | Generates a new operational dataset and optionally saves it locally. |
| Thread: Push local operational dataset | Pushes the local operational dataset configuration to the device. |
A Thread operational data set is a hex encoded string which contains a Thread border router's configuration. Using the same operational data set across multiple Thread border routers allows those routers to form a single network where Thread devices can roam from router to router. Some Thread border routers allow a "pending" operational dataset to be configured, this allows routers to coordinate the configuration change with current Thread devices without requiring those devices to be reconfigured (live migration).
# OTA (Over-The-Air) Firmware Updates
Matter devices support OTA firmware updates, allowing devices to be updated with the latest firmware without requiring physical access or manufacturer-specific applications. openHAB uses the official Matter Distributed Compliance Ledger (DCL), a cryptographically secure, distributed network that allows Matter device manufacturers and vendors to query and publish public firmware updates. This is the same method commercial Matter systems use to update their devices.
# Checking for Updates
openHAB will query the public DCL every 24 hours for available updates. To manually check if a firmware update is available for a device, use the "OTA: Check for firmware updates" action on the Node Thing. This will query the Matter server for available updates and update the Thing status if an update is found.
If an update is available, the otasoftwareupdaterequestor-updateavailable channel will be set to ON, and the Thing status will display "Firmware update available".
# Starting an Update
Once an update is available, use the "OTA: Start firmware update" action to begin the download and installation process. The Thing status will be updated with the current state of the update process:
- Downloading: The firmware is being downloaded from the Matter server. The status will show the download progress as a percentage.
- Applying: The firmware is being applied to the device.
- Delayed on apply: The device is waiting to apply the firmware (may require user intervention).
- Delayed on user consent: The device is waiting for user consent to proceed.
Note: During the update process, the device may become temporarily unavailable or unresponsive. Most devices will automatically reboot after the update is applied.
# Canceling an Update
If a firmware update is in progress and you need to cancel it, use the "OTA: Cancel firmware update" action. This will stop the download if it is in progress. If the update is in the applying state, then this action will not have any effect.
Important: After canceling an update, the device will enter a cool down period of approximately 10 minutes during which updates cannot be initiated.
# Update Available Channel
Devices that support OTA updates will have an otasoftwareupdaterequestor-updateavailable channel that indicates whether a firmware update is available.
This channel can be used in rules to automate notifications or actions when updates become available.
Example rule:
rules.when().item('Matter_Node_Ota_Update_Available').changed().toOn().then(e => {
console.log("Matter Node OTA Update Available!: {}", e);
}).build("Matter Node OTA Update Available Rule");
- No updates available: Not all Matter devices support OTA updates, and updates are only available when the device manufacturer provides them to the Matter network.
- Update fails: If an update fails, check the Thing status and logs for error messages. The device may need to be power cycled or reset.
- Update stuck: If an update appears to be stuck, you can try canceling it and restarting the update process after the cool down period.
# Controller Channels
Controllers have no channels.
# Node and Bridge Endpoint Channels
Channels are dynamically added based on the endpoint type and matter cluster supported. Each endpoint is represented as a channel group. Possible channels include:
# Endpoint Channels
| Channel ID | Type | Label | Description | Category | ReadOnly | Pattern | State Options |
| airquality-airquality | Number | Air Quality | Indicates the currently measured air quality | true | 0=Unknown, 1=Good, 2=Fair, 3=Moderate, 4=Poor, 5=Very Poor, 6=Extremely Poor | ||
| booleanstate-statevalue | Switch | Boolean State | Indicates a boolean state value | Status | true | ||
| carbondioxideconcentrationmeasurement-measuredvalue | Number:Dimensionless | CO2 Concentration | Indicates the measured carbon dioxide concentration | CarbonDioxide | true | %.2f ppm | |
| carbonmonoxideconcentrationmeasurement-measuredvalue | Number:Dimensionless | CO Concentration | Indicates the measured carbon monoxide concentration | Alarm | true | %.2f ppm | |
| concentrationmeasurement-averagemeasuredvalue | Number:Dimensionless | Average Concentration | Indicates the average concentration measured during the measurement window | Chart | true | %.2f | |
| concentrationmeasurement-levelvalue | Number | Concentration Level | Indicates the concentration level as an enumeration | QualityOfService | true | 0=Unknown, 1=Low, 2=Medium, 3=High, 4=Critical | |
| concentrationmeasurement-peakmeasuredvalue | Number:Dimensionless | Peak Concentration | Indicates the peak (maximum) concentration measured during the measurement window | Chart | true | %.2f | |
| colorcontrol-color | Color | Color | The color channel allows to control the color of a light. It is also possible to dim values and switch the light on and off. | ColorLight | |||
| colorcontrol-temperature | Dimmer | Color Temperature | Sets the color temperature of the light | ColorLight | |||
| colorcontrol-temperature-abs | Number:Temperature | Color Temperature | Sets the color temperature of the light in mirek | ColorLight | %.0f %unit% | ||
| doorlock-alarm | Trigger | Door Lock Alarm | Event that fires when a lock alarm occurs | 0=Lock Jammed, 1=Lock Factory Reset, 3=Lock Radio Power Cycled, 4=Wrong Code Entry Limit, 5=Front Escutcheon Removed, 6=Door Forced Open, 7=Door Ajar, 8=Forced User | |||
| doorlock-boltstate | Switch | Door Bolt State | Bolts and unbolts the door and maintains the bolt state | Door | |||
| doorlock-doorstate | Contact | Door Sensor State | Door Sensor State | Door | true | ||
| doorlock-lockoperationerror | Trigger | Lock Operation Error | Event that fires when a lock operation error occurs | 0=Lock, 1=Unlock, 2=Non Access User Event, 3=Forced User Event, 4=Unlatch | |||
| doorlock-lockstate | Switch | Door Lock State | Locks and unlocks the door and maintains the lock state. If the door lock supports unbolting, this will reflect the latched state. | Door | |||
| electricalenergymeasurement-cumulativeenergyexported-energy | Number:Energy | Cumulative Energy Exported | The cumulative energy exported measurement | Energy | true | %.1f %unit% | |
| electricalenergymeasurement-cumulativeenergyimported-energy | Number:Energy | Cumulative Energy Imported | The cumulative energy imported measurement | Energy | true | %.1f %unit% | |
| electricalenergymeasurement-energymeasurmement-energy | Number:Energy | Energy | The measured energy | Energy | true | %.1f %unit% | |
| electricalenergymeasurement-periodicenergyexported-energy | Number:Energy | Periodic Energy Exported | The periodic energy exported measurement | Energy | true | %.1f %unit% | |
| electricalenergymeasurement-periodicenergyimported-energy | Number:Energy | Periodic Energy Imported | The periodic energy imported measurement | Energy | true | %.1f %unit% | |
| electricalpowermeasurement-activecurrent | Number:ElectricCurrent | Active Current | The active current measurement in amperes | Energy | true | %.1f %unit% | |
| electricalpowermeasurement-activepower | Number:Power | Active Power | The active power measurement in watts | Energy | true | %.1f %unit% | |
| electricalpowermeasurement-voltage | Number:ElectricPotential | Voltage | The voltage measurement in volts | Energy | true | %.2f %unit% | |
| fancontrol-fanmode | Number | Fan Mode | Set the fan mode | HVAC | 0=Off, 1=Low, 2=Medium, 3=High, 4=On, 5=Auto | ||
| fancontrol-mode | Number | Fan Control Mode | The current mode of the fan | HVAC | |||
| fancontrol-percent | Dimmer | Fan Control Percent | The current fan speed percentage level | HVAC | true | %.0f %% | |
| formaldehydeconcentrationmeasurement-measuredvalue | Number:Dimensionless | Formaldehyde Concentration | Indicates the measured formaldehyde (HCHO) concentration | Gas | true | %.2f ppm | |
| illuminancemeasurement-measuredvalue | Number:Illuminance | Illuminance | The measured illuminance in Lux | Illuminance | true | %d %unit% | |
| levelcontrol-level | Dimmer | Dimmer | Sets the level of the light | Light | |||
| modeselect-mode | Number | Mode Select | Selection of 1 or more states | %d | |||
| nitrogendioxideconcentrationmeasurement-measuredvalue | Number:Dimensionless | NO2 Concentration | Indicates the measured nitrogen dioxide concentration | Gas | true | %.2f ppm | |
| occupancysensing-occupied | Switch | Occupancy | Indicates if an occupancy sensor is triggered | Presence | true | ||
| onoffcontrol-onoff | Switch | Switch | Switches the power on and off | Light | |||
| otasoftwareupdaterequestor-updateavailable | Switch | Update Available | Indicates if there is a firmware update available for the device. Use the "Start Firmware Update" Thing action to start the update process. | Status | true | ||
| ozoneconcentrationmeasurement-measuredvalue | Number:Dimensionless | Ozone Concentration | Indicates the measured ozone (O₃) concentration | Gas | true | %.2f ppm | |
| pm1concentrationmeasurement-measuredvalue | Number:Dimensionless | PM1 Concentration | Indicates the measured PM1 particulate matter concentration | QualityOfService | true | %.1f µg/m³ | |
| pm10concentrationmeasurement-measuredvalue | Number:Dimensionless | PM10 Concentration | Indicates the measured PM10 particulate matter concentration | QualityOfService | true | %.1f µg/m³ | |
| pm25concentrationmeasurement-measuredvalue | Number:Dimensionless | PM2.5 Concentration | Indicates the measured PM2.5 particulate matter concentration | QualityOfService | true | %.1f µg/m³ | |
| powersource-batchargelevel | Number | Battery Charge Level | Indicates a coarse ranking of the charge level of the battery, used to indicate when intervention is required | Energy | true | 0=Ok, 1=Warning, 2=Critical | |
| powersource-batpercentremaining | Number:Dimensionless | Battery Percent Remaining | Indicates the estimated percentage of battery charge remaining until the battery will no longer be able to provide power to the Node | Energy | true | %d %% | |
| radonconcentrationmeasurement-measuredvalue | Number:Dimensionless | Radon Concentration | Indicates the measured radon concentration | Gas | true | %.2f | |
| relativehumiditymeasurement-measuredvalue | Number:Dimensionless | Humidity | The measured humidity | Humidity | true | %.0f %% | |
| rvccleanmode-mode | Number | Clean Mode | Selects the cleaning mode (vacuum, mop etc.) of the robotic vacuum cleaner | %d | |||
| rvcoperationalstate-gohome | Switch | Go Home | Sends the robotic vacuum cleaner back to the dock | ||||
| rvcoperationalstate-state | Number | Operational State | Reports the operational state of the robotic vacuum cleaner | true | %d | ||
| rvcrunmode-mode | Number | Run Mode | Selects the run mode (idle, cleaning, mapping) of the robotic vacuum cleaner | %d | |||
| servicearea-selectedarea | Switch | Area Selection | Toggle to enable a mapped area for cleaning | ||||
| smokecoalarm-batteryalert | Number | Battery Alert | Indicates whether the battery power resource fault detection is triggered | Alarm | true | 0=Normal, 1=Warning, 2=Critical | |
| smokecoalarm-contaminationstate | Number | Contamination State | Indicates the contamination level of the smoke sensor | Alarm | true | 0=Normal, 1=Low, 2=Warning, 3=Critical | |
| smokecoalarm-costate | Number | CO Alarm | Indicates whether the CO sensor is currently triggering an alarm | Alarm | true | 0=Normal, 1=Warning, 2=Critical | |
| smokecoalarm-devicemuted | Number | Device Muted | Indicates whether the audible expression of the device is currently muted | Alarm | true | 0=Not Muted, 1=Muted | |
| smokecoalarm-endofservice | Number | End Of Service | Indicates whether the end-of-service has been triggered at the device | Alarm | true | 0=Normal, 1=Expired | |
| smokecoalarm-expressedstate | Number | Expressed State | The visibly and audibly expressed alarm state with the highest priority | Alarm | true | 0=Normal, 1=Smoke Alarm, 2=CO Alarm, 3=Battery Alert, 4=Testing, 5=Hardware Fault, 6=End Of Service, 7=Interconnect Smoke, 8=Interconnect CO | |
| smokecoalarm-expirydate | DateTime | Expiry Date | Indicates the date when the device reaches its stated expiry date | Time | true | ||
| smokecoalarm-hardwarefault | Switch | Hardware Fault | Indicates whether the hardware fault detection mechanism is triggered | Alarm | true | ||
| smokecoalarm-interconnectco | Number | Interconnect CO Alarm | Indicates whether the interconnected CO alarm is currently triggering from another device | Alarm | true | 0=Normal, 1=Warning, 2=Critical | |
| smokecoalarm-interconnectsmoke | Number | Interconnect Smoke Alarm | Indicates whether the interconnected smoke alarm is currently triggering from another device | Alarm | true | 0=Normal, 1=Warning, 2=Critical | |
| smokecoalarm-smokesensitivity | Number | Smoke Sensitivity | Indicates the sensitivity level of the smoke sensor | Alarm | 0=High, 1=Standard, 2=Low | ||
| smokecoalarm-smokestate | Number | Smoke Alarm | Indicates whether the smoke sensor is currently triggering an alarm | Alarm | true | 0=Normal, 1=Warning, 2=Critical | |
| smokecoalarm-testinprogress | Switch | Test In Progress | Indicates whether the device self-test is currently activated | Alarm | true | ||
| totalvolatileorganiccompoundsconcentrationmeasurement-measuredvalue | Number:Dimensionless | TVOC Concentration | Indicates the measured total volatile organic compounds concentration | Gas | true | %.2f ppm | |
| switch-initialpress | Trigger | Initial Press Trigger | This trigger shall indicate the new value of the CurrentPosition attribute as a JSON object, i.e. while pressed. | ||||
| switch-longpress | Trigger | Long Press Trigger | This trigger shall indicate the new value of the CurrentPosition attribute as a JSON object, i.e. while pressed. | ||||
| switch-longrelease | Trigger | Long Release Trigger | This trigger shall indicate the previous value of the CurrentPosition attribute as a JSON object, i.e. just prior to release. | ||||
| switch-multipresscomplete | Trigger | Multi-Press Complete Trigger | This trigger shall indicate 2 numeric fields as a JSON object. The first is the new value of the CurrentPosition attribute, i.e. while pressed. The second is how many times the momentary switch has been pressed in a multi-press sequence. | ||||
| switch-multipressongoing | Trigger | Multi-Press Ongoing Trigger | This trigger shall indicate 2 numeric fields as a JSON object. The first is the new value of the CurrentPosition attribute, i.e. while pressed. The second is the multi press code with a value of N when the Nth press of a multi-press sequence has been detected. | ||||
| switch-shortrelease | Trigger | Short Release Trigger | This trigger shall indicate the previous value of the CurrentPosition attribute as a JSON object, i.e. just prior to release. | ||||
| switch-switch | Number | Switch | Indication of a switch or remote being activated | true | %d | ||
| switch-switchlatched | Trigger | Switched Latched Trigger | This trigger shall indicate the new value of the CurrentPosition attribute as a JSON object, i.e. after the move. | ||||
| temperaturemeasurement-measuredvalue | Number:Temperature | Temperature | The measured temperature | Temperature | true | %.1f %unit% | |
| thermostat-localtemperature | Number:Temperature | Local Temperature | Indicates the local temperature provided by the thermostat | HVAC | true | %.1f %unit% | |
| thermostat-occupiedcooling | Number:Temperature | Occupied Cooling Setpoint | Set the cooling temperature when the room is occupied | HVAC | %.1f %unit% | ||
| thermostat-occupiedheating | Number:Temperature | Occupied Heating Setpoint | Set the heating temperature when the room is occupied | HVAC | %.1f %unit% | ||
| thermostat-outdoortemperature | Number:Temperature | Outdoor Temperature | Indicates the outdoor temperature provided by the thermostat | HVAC | true | %.1f %unit% | |
| thermostat-runningmode | Number | Running Mode | The running mode of the thermostat | HVAC | true | 0=Off, 3=Cool, 4=Heat | |
| thermostat-systemmode | Number | System Mode | Set the system mode of the thermostat | HVAC | 0=Off, 1=Auto, 3=Cool, 4=Heat, 5=Emergency Heating, 6=Precooling, 7=Fan Only, 8=Dry, 9=Sleep | ||
| thermostat-unoccupiedcooling | Number:Temperature | Unoccupied Cooling Setpoint | Set the cooling temperature when the room is unoccupied | HVAC | %.1f %unit% | ||
| thermostat-unoccupiedheating | Number:Temperature | Unoccupied Heating Setpoint | Set the heating temperature when the room is unoccupied | HVAC | %.1f %unit% | ||
| threadborderroutermanagement-activedataset | String | Active Dataset | The active Thread network dataset configuration | Network | |||
| threadborderroutermanagement-activedatasettimestamp | Number | Active Dataset Timestamp | Timestamp of the active Thread network dataset | Network | true | %d | |
| threadborderroutermanagement-borderagentid | String | Border Agent ID | The unique identifier of the Thread border agent | Network | true | ||
| threadborderroutermanagement-borderroutername | String | Border Router Name | The name of the Thread border router | Network | true | ||
| threadborderroutermanagement-interfaceenabled | Switch | Interface Enabled | Whether the Thread border router interface is enabled | Network | |||
| threadborderroutermanagement-pendingdataset | String | Pending Dataset | The pending Thread network dataset configuration (only available if PAN change feature is supported) | Network | |||
| threadborderroutermanagement-pendingdatasettimestamp | Number | Pending Dataset Timestamp | Timestamp of the pending Thread network dataset (only available if PAN change feature is supported) | Network | true | %d | |
| threadborderroutermanagement-threadversion | Number | Thread Version | The version of Thread protocol being used | Network | true | %d | |
| threadnetworkdiagnostics-channel | Number | Channel | The Thread network channel | Network | true | %d | |
| threadnetworkdiagnostics-extendedpanid | Number | Extended PAN ID | The Thread network extended PAN ID | Network | true | %d | |
| threadnetworkdiagnostics-networkname | String | Network Name | The Thread network name | Network | true | ||
| threadnetworkdiagnostics-panid | Number | PAN ID | The Thread network PAN ID | Network | true | %d | |
| threadnetworkdiagnostics-rloc16 | Number | RLOC16 | The Thread network RLOC16 address | Network | true | %d | |
| threadnetworkdiagnostics-routingrole | Number | Routing Role | The Thread routing role | Network | true | %d | 0=Unspecified, 1=Unassigned, 2=Sleepy End Device, 3=End Device, 4=Reed, 5=Router, 6=Leader |
| wifinetworkdiagnostics-rssi | Number:Power | Signal | Wi-Fi signal strength indicator. | QualityOfService | true | %d %unit% | |
| windowcovering-lift | Rollershutter | Window Covering Lift | Sets the window covering level - supporting open/close and up/down type commands | Blinds | %.0f %% |
# Supported Matter Device Types
The following is a list of known Matter device types supported by openHAB as defined in the Matter Device Library Specification Version 1.4.1. Other device types may be supported, but with limited or missing functionality.
| Device Type Name | Matter Device ID | Supported Clusters |
| Power Source | 0x0011 | Power Source (0x002F) |
| Bridged Node | 0x0013 | Bridged Device Basic Information (0x0039) |
| Electrical Sensor | 0x0510 | Power Topology (0x009C), Electrical Power Measurement (0x0090), Electrical Energy Measurement (0x0091) |
| On/Off Light | 0x0100 | On/Off (0x0006) |
| Dimmable Light | 0x0101 | On/Off (0x0006), Level Control (0x0008) |
| Color Temperature Light | 0x010C | On/Off (0x0006), Level Control (0x0008), Color Control (0x0300) |
| Extended Color Light | 0x010D | On/Off (0x0006), Level Control (0x0008), Color Control (0x0300) |
| On/Off Plug-in Unit | 0x010A | On/Off (0x0006) |
| Dimmable Plug-In Unit | 0x010B | On/Off (0x0006), Level Control (0x0008) |
| Mounted On/Off Control | 0x010F | On/Off (0x0006) |
| Mounted Dimmable Load Control | 0x0110 | On/Off (0x0006), Level Control (0x0008) |
| On/Off Light Switch | 0x0103 | On/Off (0x0006) |
| Dimmer Switch | 0x0104 | On/Off (0x0006), Level Control (0x0008) |
| Color Dimmer Switch | 0x0105 | On/Off (0x0006), Level Control (0x0008), Color Control (0x0300) |
| Generic Switch | 0x000F | Switch (0x003B) |
| Contact Sensor | 0x0015 | Boolean State (0x0045) |
| Light Sensor | 0x0106 | Illuminance Measurement (0x0400) |
| Occupancy Sensor | 0x0107 | Occupancy Sensing (0x0406) |
| Temperature Sensor | 0x0302 | Temperature Measurement (0x0402), Identify (0x0003) |
| Humidity Sensor | 0x0307 | Relative Humidity Measurement (0x0405) |
| On/Off Sensor | 0x0850 | On/Off (0x0006) |
| Air Quality Sensor | 0x002C | Air Quality (0x005B) |
| Smoke CO Alarm | 0x0076 | Smoke CO Alarm (0x005C), Relative Humidity Measurement (0x0405), Temperature Measurement (0x0402), Concentration Measurement Clusters |
| Water Freeze Detector | 0x0041 | Boolean State (0x0045) |
| Water Leak Detector | 0x0043 | Boolean State (0x0045) |
| Rain Sensor | 0x0044 | Boolean State (0x0045) |
| Door Lock | 0x000A | Door Lock (0x0101) |
| Window Covering | 0x0202 | Window Covering (0x0102) |
| Thermostat | 0x0301 | Thermostat (0x0201) |
| Fan | 0x002B | Fan Control (0x0202) |
| Air Purifier | 0x002D | Fan Control (0x0202) |
| Robotic Vacuum Cleaner | 0x0074 | RVC Run Mode (0x0054), RVC Operational State (0x0061), RVC Clean Mode (0x0055), Service Area (0x0150) |
| Room Air Conditioner | 0x0072 | On/Off (0x0006), Thermostat (0x0201) |
| Solar Power | 0x0017 | Electrical Power Measurement (0x0090), Electrical Energy Measurement (0x0091) |
| Battery Storage | 0x0018 | Electrical Power Measurement (0x0090), Electrical Energy Measurement (0x0091), Power Source (0x002F) |
| Thread Border Router | 0x0091 | Thread Network Diagnostics (0x0035), Thread Border Router Management (0x0452) |
# Door Lock Management
Matter door locks support user and credential management directly from openHAB. This allows you to create, modify, and delete users and their PIN codes without needing the lock manufacturer's app.
# Lock Configuration
Door locks expose several configuration options in the Thing configuration:
| Setting | Description |
| Operating Mode | The lock's operating mode (Normal, Vacation, Privacy, No Remote Lock/Unlock, Passage) |
| Auto Relock Time | Number of seconds to wait after unlocking before automatically relocking (0 to disable) |
| One Touch Locking | Enable or disable the ability to lock the door with a single touch |
| Default Lock PIN | PIN code to use for remote lock/unlock operations when the lock requires a PIN for remote operations |
# User Management
Door locks that support the "User" feature will display user configuration groups. The configuration shows all existing users plus up to 5 additional empty slots for adding new users. As you add more users, additional empty slots will automatically appear after saving to allow further expansion (up to the lock's maximum supported users).
Each user slot allows you to:
- User Name: Set a descriptive name for the user (max 10 characters)
- User Type: Set the user type (Unrestricted, Schedule Restricted, etc.)
- PIN Code: Set a PIN credential for the user. After saving, the PIN is sent to the lock and cleared from the configuration for security
- Enabled: Enable or disable the user. A disabled user cannot unlock the door with their credentials.
- Delete User: Enable this checkbox and save to delete the user from the lock
# Fabric Ownership
Matter locks track which controller (fabric) created each user. Users created by other Matter controllers (e.g., Apple Home, Google Home, Amazon Alexa) will appear as "Managed by Other Fabric" in the configuration. These users can only be deleted, enabled, or disabled from openHAB - editing their name, type, or PIN requires using the controller that originally created them.
# Lock Events
Door locks can emit events through trigger channels:
| Trigger Channel | Description |
| doorlock-alarm | Fires when a lock alarm occurs (jammed, factory reset, wrong code limit, door forced open, etc.) |
| doorlock-lockoperationerror | Fires when a lock operation error occurs (failed lock/unlock attempts) |
Example rule to handle lock alarms:
rule "Door Lock Alarm"
Channel "matter:node:main:12345678901234567890:1#doorlock-alarm" triggered
logInfo("DoorLock", "Lock alarm triggered with code: " + receivedEvent)
// Alarm codes: 0=Jammed, 1=Factory Reset, 3=Radio Power Cycled, 4=Wrong Code Limit,
// 5=Escutcheon Removed, 6=Door Forced Open, 7=Door Ajar, 8=Forced User
// Thing configuration example for the Matter controller:
Thing matter:controller:main [ nodeId="1" ]
// Thing configuration example for a Matter node:
Thing matter:node:main:12345678901234567890 [ nodeId="12345678901234567890"]
// Thing configuration example for a Matter bridge endpoint:
Thing matter:endpoint:main:12345678901234567890:2 [ endpointId=2]
Dimmer MyDimmer "My Endpoint Dimmer" { channel="matter:node:main:12345678901234567890:1#levelcontrol-level" }
Dimmer MyBridgedDimmer "My Bridged Dimmer" { channel="matter:endpoint:main:12345678901234567890:2#levelcontrol-level" }
# Sitemap Configuration
Optional Sitemap configuration:
sitemap home label="Home"
Frame label="Matter Devices"
Dimmer item=MyEndpointDimmer
# Matter Bridge
openHAB can also expose Items and Item groups as Matter devices to 3rd party Matter clients like Google Home, Apple Home and Amazon Alexa. This allows local control for those ecosystems and can be used instead of cloud based integrations for features like voice assistants.
Note: The openHAB Matter bridge is unrelated to the Matter Controller Thing. Adding, modifying or removing a Matter "Controller" Thing, or any Matter "Node" Thing will have no affect on the bridge.
There are two ways in which to configure the Matter bridge:
- Using the "Matter Bridge Configuration" settings page (Main UI -> Settings -> Add-on Settings -> Matter Binding) for bridge status, general configuration and pairing 3rd party clients.
- Adding Matter metadata tags to Groups and Items either through the Main UI or through item files.
The openHAB matter bridge uses metadata tags with the key "matter", similar to the Alexa, Google Assistant and Apple Homekit integrations. Matter Metadata tag values generally follow the Matter "Device Type" and "Cluster" specification as much as possible.
Items and item groups are initially tagged with a Matter "Device Type", which are Matter designations for common device types like lights, thermostats, locks, window coverings, etc... For single items, like a light switch or dimmer, simply tagging the item with the Matter device type is enough.
Dimmer MyDimmer "My Dimmer" { matter="DimmableLight" }
For more complicated devices, like thermostats, A group item is tagged with the device type, and its child members are tagged with the cluster attribute(s) that it will be associated with.
Multiple attributes use a comma delimited format like attribute1, attribute2, ... attributeN.
Group ThermostatGroup "Thermostat" { matter="Thermostat" }
Number:Temperature ThermostatGroup_Temperature "Temperature" (ThermostatGroup) { matter="thermostat.localTemperature" }
Number:Temperature ThermostatGroup_HeatSetpoint "Heat Setpoint" (ThermostatGroup) { matter="thermostat.occupiedHeatingSetpoint" }
Number:Temperature ThermostatGroup_CoolSetpoint "Cool Setpoint" (ThermostatGroup) { matter="thermostat.occupiedCoolingSetpoint" }
Number ThermostatGroup_Mode "Mode" (ThermostatGroup) { matter="thermostat.systemMode" [OFF=0, HEAT=1, COOL=2, AUTO=3]}
For devices like fans that support groups with multiple items, but you are only using one item to control (like On/Off or Speed), you can tag the regular item with both the device type and the cluster attribute(s) separated by a comma.
Switch TestFanSingleItem "On/Off" { matter="Fan, fanControl.fanMode" }
If there are issues starting the bridge, check the status field in the bridge settings page to see if there are any errors.
# Pairing 3rd Party Clients
Pairing codes and other options can be found in the MainUI under "Settings -> Add-on Settings -> Matter Binding"
When the matter bridge starts, if no 3rd party clients are paired, it will automatically open the "Commissioning Window", meaning you can use the QR code or manual pair code found in the bridge settings page to pair a new client like Alexa, Google Home or Apple Home.
Once a client is paired, the bridge will default to having its "Commissioning Window" closed and can not be paired with until the window is opened again in the settings.
To pair additional clients, you can open the commissioning window again in the settings by enabling "Allow Commissioning", clicking save, and then and pair a new client within the 15 minute window using the QR code or manual pair code.
Once a new client is paired, or the 15 minute window expires, the bridge will default to having its "Commissioning Window" closed and can not be paired with until the window is opened again in the settings.
# Resetting the Bridge
If you need to reset the bridge, you can do so by enabling the "Reset Bridge" button in the bridge settings page (advanced options) and clicking save.
Note that this will leave 3rd party clients paired to the bridge still in a "paired" state, and you will need to unpair the now orphaned openHAB Matter bridge in their respective apps.
Resetting the bridge is almost never needed, and should only be used if advised to do so by a developer.
# Device Types
The following is a list of supported Matter device types and their corresponding openHAB item types and tags.
| Type | Item Type | Tag | Option |
| OnOff Light | Switch, Dimmer | OnOffLight | |
| Dimmable Light | Dimmer | DimmableLight | |
| Color Light | Color | ColorLight | |
| On/Off Plug In Unit | Switch, Dimmer | OnOffPlugInUnit | |
| Thermostat | Group | Thermostat | |
| Window Covering | Rollershutter, Dimmer, String, Switch | WindowCovering | String types: [OPEN="OPEN", CLOSED="CLOSED"], Switch types: [invert=true/false] |
| Temperature Sensor | Number | TemperatureSensor | |
| Humidity Sensor | Number | HumiditySensor | |
| Occupancy Sensor | Switch, Contact | OccupancySensor | |
| Contact Sensor | Switch, Contact | ContactSensor | |
| Door Lock | Switch | DoorLock | |
| Fan | Group, Switch, String, Dimmer | Fan | |
| Mode Select | Number, String, Switch, Rollershutter | ModeSelect | Requires modes option, see below |
# Global Options
- Endpoint Labels
- By default, the Item label is used as the Matter label but can be overridden by adding a
labelkey as a metadata option, either by itself or part of other options required for a device. - Example:
[label="My Custom Label"]
- Fixed Labels
- Matter has a concept of "Fixed Labels" which allows devices to expose arbitrary label names and values which can be used by clients for tasks like grouping devices in rooms.
- Example:
[fixedLabels="room=Office, floor=1"]
# Thermostat group member tags
| Type | Item Type | Tag | Options |
| Current Temperature | Number | thermostat.localTemperature | |
| Outdoor Temperature | Number | thermostat.outdoorTemperature | |
| Heating Setpoint | Number | thermostat.occupiedHeatingSetpoint | |
| Cooling Setpoint | Number | thermostat.occupiedCoolingSetpoint | |
| System Mode | Number, String, Switch | thermostat.systemMode | [OFF=0,AUTO=1,COOL=3,HEAT=4,EMERGENCY_HEAT=5,PRECOOLING=6,FAN_ONLY=7,DRY=8,SLEEP=9] |
| Running Mode | Number, String | thermostat.runningMode |
The following attributes can be set in the options of any thermostat member or on the Group item to set temperature options.
| Setting | Description | Value (in 0.01°C) |
thermostat-minHeatSetpointLimit | The minimum allowable heat setpoint limit. | 0 |
thermostat-maxHeatSetpointLimit | The maximum allowable heat setpoint limit. | 3500 |
thermostat-absMinHeatSetpointLimit | The absolute minimum heat setpoint limit that cannot be exceeded by the minHeatSetpointLimit. | 0 |
thermostat-absMaxHeatSetpointLimit | The absolute maximum heat setpoint limit that cannot be exceeded by the maxHeatSetpointLimit. | 3500 |
thermostat-minCoolSetpointLimit | The minimum allowable cool setpoint limit. | 0 |
thermostat-maxCoolSetpointLimit | The maximum allowable cool setpoint limit. | 3500 |
thermostat-absMinCoolSetpointLimit | The absolute minimum cool setpoint limit that cannot be exceeded by the minCoolSetpointLimit. | 0 |
thermostat-absMaxCoolSetpointLimit | The absolute maximum cool setpoint limit that cannot be exceeded by the maxCoolSetpointLimit. | 3500 |
thermostat-minSetpointDeadBand | The minimum deadband (temperature gap) between heating and cooling setpoints. | 0 |
# Fan group member tags
| Fan Mode | Number, String, Switch | fanControl.fanMode | [OFF=0, LOW=1, MEDIUM=2, HIGH=3, ON=4, AUTO=5, SMART=6] |
| Fan Percentage | Dimmer | fanControl.percentSetting | |
| Fan OnOff | Switch | onOff.onOff |
The following attributes can be set on the Fan Mode item or the Group item to set fan options.
| Setting | Description | Value |
fanControl-fanModeSequence | The sequence of fan modes to cycle through. See Fan Mode Sequence Options | 5 |
# Fan Mode Sequence Options
| Value | Description |
| 0 | OffLowMedHigh |
| 1 | OffLowHigh |
| 2 | OffLowMedHighAuto |
| 3 | OffLowHighAuto |
| 4 | OffHighAuto |
| 5 | OffHigh |
# Mode Select options
ModeSelect is considered experimental and is not supported by Apple Home, Google Home and Amazon Alexa (yet).
Mode Select Details
A ModeSelect device exposes a device which responds to user defined selectable modes.
This can be used to model items which may not conform to other devices types.
ModeSelect items (or groups) must provide a mapping of Matter modes to openHAB state values via the metadata option modes. The format is a comma-separated list where each entry follows:
<stateValue>:<label>[:<semanticTag>[:<semanticTag>...]]
stateValue– the exact openHAB state string you will send/receive (e.g.off,auto,heat, '0').label– human-readable label presented to Matter clients.semanticTag– optional semantic hint innamespace.tagform (see the Semantic Tags appendix for valid values).
At least one mode must be supplied.
Example (exposes four modes, 'off', 'next', 'previous' and 'play'):
String BlueRayPlayer "BlueRay Player" { matter="ModeSelect" [
modes="off:Off:switches.off,next:Next:switches.next,previous:Previous:switches.previous,play:Play:switches.on"
A note on semantic tags:
- If used, you can not mix different semantic namespaces as seen in the example above where
switchesis the base namespace being used for all tags. - These are provided by the Matter spec, but its up to clients (like Apple, Alexa, Google....) to interpret these tags (or not).
- Each ecosystem will likely differ in its use of these tags.
- They are provided here for maximum flexibility but are not guarenteed to have any affect.
# Bridged Device Examples
Dimmer TestDimmer "Test Dimmer [%d%%]" {matter="DimmableLight" [label="My Custom Dimmer", fixedLabels="room=Bedroom 1, floor=2, direction=up, customLabel=Custom Value"]}
Group TestHVAC "Thermostat" ["HVAC"] {matter="Thermostat" [thermostat-minHeatSetpointLimit=0, thermostat-maxHeatSetpointLimit=3500]}
Number:Temperature TestHVAC_Temperature "Temperature [%d °F]" (TestHVAC) ["Measurement","Temperature"] {matter="thermostat.localTemperature"}
Number:Temperature TestHVAC_HeatSetpoint "Heat Setpoint [%d °F]" (TestHVAC) ["Setpoint", "Temperature"] {matter="thermostat.occupiedHeatingSetpoint"}
Number:Temperature TestHVAC_CoolSetpoint "Cool Setpoint [%d °F]" (TestHVAC) ["Setpoint", "Temperature"] {matter="thermostat.occupiedCoolingSetpoint"}
Number TestHVAC_Mode "Mode [%s]" (TestHVAC) ["Control" ] {matter="thermostat.systemMode" [OFF=0, HEAT=1, COOL=2, AUTO=3]}
Switch TestDoorLock "Door Lock" {matter="DoorLock"}
Rollershutter TestShade "Window Shade" {matter="WindowCovering"}
Number:Temperature TestTemperatureSensor "Temperature Sensor" {matter="TemperatureSensor"}
Number TestHumiditySensor "Humidity Sensor" {matter="HumiditySensor"}
Switch TestOccupancySensor "Occupancy Sensor" {matter="OccupancySensor"}
### Fan with group item control
Group TestFan "Test Fan" {matter="Fan" [fanControl-fanModeSequence=3]}
Dimmer TestFanSpeed "Speed" (TestFan) {matter="fanControl.percentSetting"}
Switch TestFanOnOff "On/Off" (TestFan) {matter="fanControl.fanMode"}
Number TestFanMode "Mode" (TestFan) {matter="fanControl.fanMode" [OFF=0, LOW=1, MEDIUM=2, HIGH=3, ON=4, AUTO=5, SMART=6]}
### Fan with single item control , so no group item is needed
Switch TestFanSingleItem "On/Off" {matter="Fan, fanControl.fanMode"}
# Bridge FAQ
- Alexa: When pairing, after a minute Alexa reports "Something went wrong"
- Alexa can take 3-4 seconds per device to process which can take longer then the Alexa UI is willing to wait. Eventually the pairing will complete, which for a large number of devices may be a few minutes.
- Alexa: Suddenly stops working and says it could not connect to a device or device not responding.
- Check the Settings page in the Main UI to confirm the bridge is running
- Ensure the openHAB item has the proper matter tag, or that the item is being loaded at all (check item file errors)
- Rarely, you may need to reboot the Alexa device. If you have multiple devices and not sure which is the primary matter connection, you may need to reboot all of them.
# Matter Ecosystem Overview
Matter is an open-source connectivity standard for smart home devices, allowing seamless communication between a wide range of devices, controllers, and ecosystems.
Below is a high-level overview of the Matter ecosystem as well as common terminology used in the Matter standard.
# Matter Devices
# Nodes and Endpoints
In the Matter ecosystem, a node represents a single device that joins a Matter network and will have a locally routable IPv6 address. A node can have multiple endpoints, which are logical representations of specific features or functionalities of the device. For example, a smart thermostat (node) may have an endpoint for general thermostat control (heating, cooling, current temperature, operating state, etc....) and another endpoint for humidity sensing. Many devices will only have a single endpoint. Matter Bridges will expose multiple endpoints for each device they are bridging, and the bridge itself will be a node.
- A Thermostat node with an endpoint for general temperature control and another endpoint for a remote temperature or humidity sensor.
# Controllers
A controller manages the interaction between Matter devices and other parts of the network. Controllers can send commands, receive updates, and facilitate device communication. They also handle the commissioning process when new devices are added to the network.
- openHAB or another smart home hub or a smartphone app that manages your smart light bulbs, door locks, and sensors (Google Home, Apple Home, Amazon Alexa, etc...)
# Bridges
A bridge is a special type of node that connects non-Matter devices to a Matter network, effectively translating between protocols. Bridges allow legacy devices to be controlled via the Matter standard.
openHAB fully supports connecting to Matter bridges. In addition, openHAB has support for running its own Matter bridge service, exposing openHAB items as Matter endpoints to 3rd party systems. See Matter Bridge for information on running a Bridge server.
- A bridge that connects Zigbee or Z-Wave devices, making them accessible within a Matter ecosystem. The IKEA Dirigera and Philips Hue Bridge both act as matter bridges and are supported in openHAB.
# Thread Border Routers
A Thread Border Router is a device that allows devices connected via Thread (a low-power wireless protocol) to communicate with devices on other networks, such as Wi-Fi or Ethernet. It facilitates IPv6-based communication between Thread networks and the local IP network.
- An OpenThread Boarder Router (open source) as well as recent versions of Apple TVs, Amazon Echos and Google Nest Hubs all have embedded thread boarder routers.
# IPv6 and Network Connectivity
Matter devices operate over an IPv6 network, and obtaining an IPv6 address is required for communication. Devices can connect to the network via different interfaces:
# Ethernet
Ethernet-connected Matter devices receive an IPv6 address through standard DHCPv6 or stateless address auto-configuration (SLAAC).
# Wi-Fi
Wi-Fi-enabled Matter devices also receive an IPv6 address using DHCPv6 or SLAAC. They rely on the existing Wi-Fi infrastructure for communication within the Matter ecosystem.
# Thread
Thread-based Matter devices connect to the network via a Thread Border Router. They receive an IPv6 address from the Thread router.
# IPv6 Requirements
For Matter devices to function correctly, IPv6 must be enabled and supported in both the local network (router) and the Matter controllers. Without IPv6, devices won't be able to communicate properly within the Matter ecosystem. Ensure that your router has IPv6 enabled and that any Matter controllers (like smart hubs, apps or openHAB) are configured to support IPv6 as well.
Note: environments like Docker require special configurations to enable IPv6.
# Matter Commissioning and Pairing Codes
Commissioning a Matter device involves securely adding it to the network using a pairing code. This process ensures that only authorized devices can join the network.
# Pairing Code from the Device
When commissioning a new Matter device, it typically has a printed QR code or numeric pairing code that you scan or enter during setup. This pairing code allows the controller to establish a secure connection to the device and add it to the network. Once a device pairing code is in use, it typically can not be used again to pair other controllers.
# Additional Pairing Code from a Controller
If a device has already been commissioned and you want to add it to another Matter controller, the existing controller can generate an additional pairing code. This is useful when sharing access to a device across multiple hubs or apps. Apple Home, Google Home, Amazon Alexa and openHAB all support generating pairing codes for existing paired devices.
# Example:
- When setting up a smart lock, you may scan a QR code directly from the lock, or use the 11 digit pairing code printed on it to pair it with openHAB.
- If you later want to control the lock from another app or hub, you would retrieve a new pairing code directly from openHAB.
# Apendixes
# Semantic Tags
| Namespace | Tag Name | Key |
| Area | Aisle | area.aisle |
| Area | Attic | area.attic |
| Area | Back Door | area.back-door |
| Area | Back Yard | area.back-yard |
| Area | Balcony | area.balcony |
| Area | Ballroom | area.ballroom |
| Area | Bathroom | area.bathroom |
| Area | Bedroom | area.bedroom |
| Area | Border | area.border |
| Area | Boxroom | area.boxroom |
| Area | Breakfast Room | area.breakfast-room |
| Area | Carport | area.carport |
| Area | Cellar | area.cellar |
| Area | Cloakroom | area.cloakroom |
| Area | Closet | area.closet |
| Area | Conservatory | area.conservatory |
| Area | Corridor | area.corridor |
| Area | Craft Room | area.craft-room |
| Area | Cupboard | area.cupboard |
| Area | Deck | area.deck |
| Area | Den | area.den |
| Area | Dining | area.dining |
| Area | Drawing Room | area.drawing-room |
| Area | Dressing Room | area.dressing-room |
| Area | Driveway | area.driveway |
| Area | Elevator | area.elevator |
| Area | Ensuite | area.ensuite |
| Area | Entrance | area.entrance |
| Area | Entryway | area.entryway |
| Area | Family Room | area.family-room |
| Area | Foyer | area.foyer |
| Area | Front Door | area.front-door |
| Area | Front Yard | area.front-yard |
| Area | Game Room | area.game-room |
| Area | Garage | area.garage |
| Area | Garage Door | area.garage-door |
| Area | Garden | area.garden |
| Area | Garden Door | area.garden-door |
| Area | Guest Bathroom | area.guest-bathroom |
| Area | Guest Bedroom | area.guest-bedroom |
| Area | Guest Room | area.guest-room |
| Area | Gym | area.gym |
| Area | Hallway | area.hallway |
| Area | Hearth Room | area.hearth-room |
| Area | Kids Room | area.kids-room |
| Area | Kids Bedroom | area.kids-bedroom |
| Area | Kitchen | area.kitchen |
| Area | Laundry Room | area.laundry-room |
| Area | Lawn | area.lawn |
| Area | Library | area.library |
| Area | Living Room | area.living-room |
| Area | Lounge | area.lounge |
| Area | Media/TV Room | area.media-tv-room |
| Area | Mud Room | area.mud-room |
| Area | Music Room | area.music-room |
| Area | Nursery | area.nursery |
| Area | Office | area.office |
| Area | Outdoor Kitchen | area.outdoor-kitchen |
| Area | Outside | area.outside |
| Area | Pantry | area.pantry |
| Area | Parking Lot | area.parking-lot |
| Area | Parlor | area.parlor |
| Area | Patio | area.patio |
| Area | Play Room | area.play-room |
| Area | Pool Room | area.pool-room |
| Area | Porch | area.porch |
| Area | Primary Bathroom | area.primary-bathroom |
| Area | Primary Bedroom | area.primary-bedroom |
| Area | Ramp | area.ramp |
| Area | Reception Room | area.reception-room |
| Area | Recreation Room | area.recreation-room |
| Area | Roof | area.roof |
| Area | Sauna | area.sauna |
| Area | Scullery | area.scullery |
| Area | Sewing Room | area.sewing-room |
| Area | Shed | area.shed |
| Area | Side Door | area.side-door |
| Area | Side Yard | area.side-yard |
| Area | Sitting Room | area.sitting-room |
| Area | Snug | area.snug |
| Area | Spa | area.spa |
| Area | Staircase | area.staircase |
| Area | Steam Room | area.steam-room |
| Area | Storage Room | area.storage-room |
| Area | Studio | area.studio |
| Area | Study | area.study |
| Area | Sun Room | area.sun-room |
| Area | Swimming Pool | area.swimming-pool |
| Area | Terrace | area.terrace |
| Area | Toilet | area.toilet |
| Area | Utility Room | area.utility-room |
| Area | Ward | area.ward |
| Area | Workshop | area.workshop |
| Closure | Opening | closure.opening |
| Closure | Closing | closure.closing |
| Closure | Stop | closure.stop |
| CompassDirection | Northward | compassdirection.northward |
| CompassDirection | North-Eastward | compassdirection.north-eastward |
| CompassDirection | Eastward | compassdirection.eastward |
| CompassDirection | South-Eastward | compassdirection.south-eastward |
| CompassDirection | Southward | compassdirection.southward |
| CompassDirection | South-Westward | compassdirection.south-westward |
| CompassDirection | Westward | compassdirection.westward |
| CompassDirection | North-Westward | compassdirection.north-westward |
| CompassLocation | North | compasslocation.north |
| CompassLocation | North-East | compasslocation.north-east |
| CompassLocation | East | compasslocation.east |
| CompassLocation | South-East | compasslocation.south-east |
| CompassLocation | South | compasslocation.south |
| CompassLocation | South-West | compasslocation.south-west |
| CompassLocation | West | compasslocation.west |
| CompassLocation | North-West | compasslocation.north-west |
| Direction | Upward | direction.upward |
| Direction | Downward | direction.downward |
| Direction | Leftward | direction.leftward |
| Direction | Rightward | direction.rightward |
| Direction | Forward | direction.forward |
| Direction | Backward | direction.backward |
| ElectricalMeasurement | DC | electricalmeasurement.dc |
| ElectricalMeasurement | AC | electricalmeasurement.ac (opens new window) |
| ElectricalMeasurement | ACPhase1 | electricalmeasurement.acphase1 |
| ElectricalMeasurement | ACPhase2 | electricalmeasurement.acphase2 |
| ElectricalMeasurement | ACPhase3 | electricalmeasurement.acphase3 |
| Landmark | Air Conditioner | landmark.air-conditioner |
| Landmark | Air Purifier | landmark.air-purifier |
| Landmark | Back Door | landmark.back-door |
| Landmark | Bar Stool | landmark.bar-stool |
| Landmark | Bath Mat | landmark.bath-mat |
| Landmark | Bathtub | landmark.bathtub |
| Landmark | Bed | landmark.bed |
| Landmark | Bookshelf | landmark.bookshelf |
| Landmark | Chair | landmark.chair |
| Landmark | Christmas Tree | landmark.christmas-tree |
| Landmark | Coat Rack | landmark.coat-rack |
| Landmark | Coffee Table | landmark.coffee-table |
| Landmark | Cooking Range | landmark.cooking-range |
| Landmark | Couch | landmark.couch |
| Landmark | Countertop | landmark.countertop |
| Landmark | Cradle | landmark.cradle |
| Landmark | Crib | landmark.crib |
| Landmark | Desk | landmark.desk |
| Landmark | Dining Table | landmark.dining-table |
| Landmark | Dishwasher | landmark.dishwasher |
| Landmark | Door | landmark.door |
| Landmark | Dresser | landmark.dresser |
| Landmark | Laundry Dryer | landmark.laundry-dryer |
| Landmark | Fan | landmark.fan |
| Landmark | Fireplace | landmark.fireplace |
| Landmark | Freezer | landmark.freezer |
| Landmark | Front Door | landmark.front-door |
| Landmark | High Chair | landmark.high-chair |
| Landmark | Kitchen Island | landmark.kitchen-island |
| Landmark | Lamp | landmark.lamp |
| Landmark | Litter Box | landmark.litter-box |
| Landmark | Mirror | landmark.mirror |
| Landmark | Nightstand | landmark.nightstand |
| Landmark | Oven | landmark.oven |
| Landmark | Pet Bed | landmark.pet-bed |
| Landmark | Pet Bowl | landmark.pet-bowl |
| Landmark | Pet Crate | landmark.pet-crate |
| Landmark | Refrigerator | landmark.refrigerator |
| Landmark | Scratching Post | landmark.scratching-post |
| Landmark | Shoe Rack | landmark.shoe-rack |
| Landmark | Shower | landmark.shower |
| Landmark | Side Door | landmark.side-door |
| Landmark | Sink | landmark.sink |
| Landmark | Sofa | landmark.sofa |
| Landmark | Stove | landmark.stove |
| Landmark | Table | landmark.table |
| Landmark | Toilet | landmark.toilet |
| Landmark | Trash Can | landmark.trash-can |
| Landmark | Laundry Washer | landmark.laundry-washer |
| Landmark | Window | landmark.window |
| Landmark | Wine Cooler | landmark.wine-cooler |
| Laundry | Normal | laundry.normal |
| Laundry | Light Dry | laundry.light-dry |
| Laundry | Extra Dry | laundry.extra-dry |
| Laundry | No Dry | laundry.no-dry |
| Level | Low | level.low |
| Level | Medium | level.medium |
| Level | High | level.high |
| Location | Indoor | location.indoor |
| Location | Outdoor | location.outdoor |
| Location | Inside | location.inside |
| Location | Outside | location.outside |
| Number | Zero | number.zero |
| Number | One | number.one |
| Number | Two | number.two |
| Number | Three | number.three |
| Number | Four | number.four |
| Number | Five | number.five |
| Number | Six | number.six |
| Number | Seven | number.seven |
| Number | Eight | number.eight |
| Number | Nine | number.nine |
| Number | Ten | number.ten |
| Position | Left | position.left |
| Position | Right | position.right |
| Position | Top | position.top |
| Position | Bottom | position.bottom |
| Position | Middle | position.middle |
| Position | Row | position.row |
| Position | Column | position.column |
| PowerSource | Unknown | powersource.unknown |
| PowerSource | Grid | powersource.grid |
| PowerSource | Solar | powersource.solar |
| PowerSource | Battery | powersource.battery |
| PowerSource | Ev | powersource.ev |
| Refrigerator | Refrigerator | refrigerator.refrigerator |
| Refrigerator | Freezer | refrigerator.freezer |
| RelativePosition | Under | relativeposition.under |
| RelativePosition | Next To | relativeposition.next-to |
| RelativePosition | Around | relativeposition.around |
| RelativePosition | On | relativeposition.on |
| RelativePosition | Above | relativeposition.above |
| RelativePosition | Front Of | relativeposition.front-of |
| RelativePosition | Behind | relativeposition.behind |
| RoomAirConditioner | Evaporator | roomairconditioner.evaporator |
| RoomAirConditioner | Condenser | roomairconditioner.condenser |
| Switches | On | switches.on |
| Switches | Off | switches.off |
| Switches | Toggle | switches.toggle |
| Switches | Up | switches.up |
| Switches | Down | switches.down |
| Switches | Next | switches.next |
| Switches | Previous | switches.previous |
| Switches | Enter/OK/Select | switches.enter-ok-select |
| Switches | Custom | switches.custom |
