# NeoHub Binding
The binding supports the following types of Thing:
| Thing Type | Description |
| NeoHub | The Heatmiser NeoHub bridge used to communicate with NeoStat and NeoPlug devices |
| NeoStat | Heatmiser Neostat Smart Thermostat |
| NeoPlug | Heatmiser NeoPlug Smart Plug |
| NeoContact | Heatmiser Contact Sensor, wireless door or window contact |
| NeoTemperatureSensor | Heatmiser Wireless Air Sensor, wireless temperature sensor |
The binding automatically searches for NeoHub devices and puts them in the Main UI Inbox. Alternatively you can manually create a (Bridge) Thing for the NeoHub. In either case, you need to enter any missing configuration parameters (see Thing Configuration for NeoHub below). Once the configuration parameters are all valid, the NeoHub Thing will automatically attempt to connect and sign on to the hub. If the sign-on succeeds, the Thing status changes to ONLINE; otherwise it will show an error status.
Once the NeoHub Thing has been created and it has successfully signed on, it will automatically interrogate the NeoHub to discover all the respective Heatmiser device Things connected to it. If in the future, you add additional Heatmiser devices to your system, the binding will discover them too.
The NeoHub Thing connects to the hub (bridge) to communicate with connected Heatmiser device Things. It signs on to the hub using the supplied connection parameters, and it polls the hub at regular intervals to read and write the data for each Heatmiser device. The NeoHub supports two APIs (an older legacy API and a modern one), and this binding can use either. Before the binding can communicate with the hub, the following Configuration Parameters must be entered.
| hostName | Host name (IP address) of the NeoHub (e.g., 192.168.1.123) |
| useWebSocket1) | Use secure WebSocket to connect to the NeoHub (e.g., true) |
| apiToken1) | API Access Token for secure connection to hub. Create the token in the Heatmiser mobile App |
| pollingInterval | Time (seconds) between polling requests to the NeoHub (Min=4, Max=60, Default=60) |
| socketTimeout | Time (seconds) to allow for TCP socket connections to the hub to succeed (Min=4, Max=20, Default=5) |
| preferLegacyApi | ADVANCED: Prefer to use older API calls; but if not supported, it switches to new calls (Default=false) |
| portNumber2) | ADVANCED: Port number for connection to the NeoHub (Default=0 (automatic)) |
1) If useWebSocket is false, the binding will connect via an older and less secure TCP connection, in which case apiToken is not required.
However see the chapter "Connection Refused Errors" below.
Whereas if you prefer to connect via more secure WebSocket connections then an API access token apiToken is required.
You can create an API access token in the Heatmiser mobile App (Settings | System | API Access).
2) Normally the port number is chosen automatically (for TCP it is 4242 and for WebSocket it is 4243). But you can override this in special cases if you want to use (say) port forwarding.
# Connection Refused Errors
From early 2022 Heatmiser introduced NeoHub firmware that can enable or disable connecting to it via a TCP port. If the TCP port is disabled the openHAB binding cannot connect and the binding will report a "Connection Refused" warning in the log. In prior firmware versions the TCP port was always enabled. But in the new firmware the TCP port is initially enabled on power up but if no communication occurs for 48 hours it is automatically disabled. Alternatively, the Heatmiser mobile app has a setting (Settings | System | API Access | Legacy API Enable | On) to permanently enable the TCP port.
The NeoHub Thing connects to the hub (bridge) to communicate with any Heatmiser devices that are connected to it. Each Heatmiser device is identified by a unique device name in the hub. The device name is automatically discovered by the NeoHub Thing, and it is also visible (and changeable) via the Heatmiser App.
| deviceNameInHub | Device name that identifies the Heatmiser device in the NeoHub and the Heatmiser App |
# Channels for "NeoHub"
| meshNetworkQoS | Number:Dimensionless | RF mesh network Quality-of-Service; this is the percentage of configured devices that are currently connected online via the RF mesh network |
| roomTemperature | Number:Temperature | Actual room temperature |
| floorTemperature | Number:Temperature | Actual floor temperature |
| thermostatOutputState | String | Status of whether the thermostat is Off, or calling for Heat |
| occupancyModePresent | Switch | The thermostat is in the Present Occupancy Mode (Off=Absent, On=Present) |
| batteryLowAlarm | Switch | The battery is low (only applies for battery powered thermostats) (Off=Ok, On=Alarm) |
| plugOutputState | Switch | The output state of the plug switch (Off, On) |
| plugAutoMode | Switch | The plug is in Automatic Mode (Off=Manual, On=Automatic) |
| contactState | Contact | The state of the contact |
| batteryLowAlarm | Switch | The battery is low (Off=Ok, On=Alarm) |
| sensorTemperature | Number:Temperature | Measured temperature |
Occasionally, a device might drop out of the mesh.
If a device drops out of the mesh, you can choose whether openHAB should either a) change the channel value to UNDEF, or b) hold the value it had prior to the drop-out.
The choice of a) or b) is determined by an optional Channel configuration parameter holdOnlineState as follows.
| holdOnlineState | Switch | If the device drops out of the RF mesh, the behavior is: - Off: openHAB changes the channel’s state to UNDEF- On: openHAB holds the channel’s state unchanged Default: Off |
The purpose of holdOnlineState is so you can choose to overlook value fluctuations if drop outs occur e.g. to "hold" the values in a temperature graph display.
Note: If a drop-out occurs, the Thing will always change its status to OFFLINE (regardless of the holdOnlineState setting).
# demo.things File
# demo.items File
# demo.sitemap File
Frame label="Thermostat" {
Frame label="Plug" {
Frame label="Contact" {
Frame label="Sensor" {
Text item=Kitchen_Temperature
